[GeoNode-users] Permissions - Cannot download layers
Paolo Pasquali paolo.pasquali at gmail.com
Mon Dec 16 02:34:41 PST 2019
In addition, if I check the permissions in the layer detail page, I see
that they are properly set. Still, I get the "Request Download" button.
On Mon, Dec 16, 2019 at 11:30 AM Paolo Pasquali <paolo.pasquali at gmail.com>
wrote:
> Should be 2.10.0 or something like that but less than 2.10.1
> For instance, in the Django admin I don't get the "Set Layer permissions"
> action from the drop down menu.
> Anyway, If I run
> python manage.py set_layers_permissions -p download -g SomeGroup
> Should the expected result be that all the layers are downloadable for
> that group. But it does not seem to work.
> Is there a way to set a permission for all the users and not filtered by a
> group or user?
> Thanks.
> Please note that if I upload a new layer, the permissions are properly set.
> Ciao
> P.
> On Mon, Dec 16, 2019 at 10:41 AM Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> Uhm,
>> I don't get this message. Just tried to run the command and it started
>> scanning the layers. Which version are you using?
>> Moreover, if you want to batch set/unset the permissions you might want
>> to consider also this command here
>> http://docs.geonode.org/en/master/admin/mgmt_commands/index.html#batch-sync-permissions
>> I'm using 2.10.x branch now.
>> Il giorno lun 16 dic 2019 alle ore 09:50 Paolo Pasquali <
>> paolo.pasquali at gmail.com> ha scritto:
>>> Ciao Alessio,
>>> Thanks for the reply.
>>> I've already followed this documentation section but without success.
>>> If I run:
>>> python manage.py sync_geonode_layers --updatepermissions
>>> I get:
>>> manage.py sync_geonode_layers: error: argument --updatepermissions:
>>> expected one argument
>>> Which argument should I specify?
>>> Thanks,
>>> P.
>>> On Mon, Dec 16, 2019 at 9:38 AM Alessio Fabiani <
>>>> Hello Paolo,
>>>> probably this section of the docs might be helpful
>>>> http://docs.geonode.org/en/master/admin/mgmt_commands/index.html#update-permissions-metadata-legends-and-download-links
>>>> Il giorno ven 13 dic 2019 alle ore 17:05 Paolo Pasquali <
>>>>> Dear all,
>>>>> I'm still struggling with the permission system (again).
>>>>> I have migrated several layers from an old version into a GeoNode
>>>>> 2.10. I have launched the updatelayers and sync_geonode_layers commands but
>>>>> for all these layers I have the "Request Download" button instead of the
>>>>> "Download Layer" button.
>>>>> The problem is that my user is administrator and "Anyone" is flagged
>>>>> for "Who can download this layer?" in the permission modal.
>>>>> Could you suggest how to fix this issue?
>>>>> Please note that some commands mentioned in the docs such as
>>>>> set_layer_permissions are not available in my 2.10 version.
>>>>> If I upload a new layer everything is fine.
>>>>> Thanks.
>>>>> Best,
>>>>> Paolo
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>> GeoServer Professional Services from the experts! Visit
>>>> http://goo.gl/it488V for more information.
>>>> Ing. Alessio Fabiani
>>>> @alfa7691
>>>> Founder/Technical Lead
>>>> GeoSolutions S.A.S.
>>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>>> phone: +39 0584 962313
>>>> fax:     +39 0584 1660272
>>>> mob:   +39 331 6233686
>>>> http://www.geo-solutions.it
>>>> http://twitter.com/geosolutions_it
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>>> precisa che ogni circostanza inerente alla presente email (il suo
>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>> This email is intended only for the person or entity to which it is
>>>> addressed and may contain information that is privileged, confidential or
>>>> otherwise protected from disclosure. We remind that - as provided by
>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>> e-mail or the information herein by anyone other than the intended
>>>> recipient is prohibited. If you have received this email by mistake, please
>>>> notify us immediately by telephone or e-mail.
>> @alfa7691
>> GeoSolutions S.A.S.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191216/bfa6ae23/attachment-0001.html>
More information about the geonode-users mailing list
