[GeoNode-users] Permissions - Cannot download layers
Paolo Pasquali paolo.pasquali at gmail.com
Mon Dec 16 04:09:01 PST 2019
Is there a chance to restore the download link in the db?
In what table can I find this value?
Thanks.
On Mon, Dec 16, 2019 at 11:38 AM Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> @Paolo Pasquali <paolo.pasquali at gmail.com> the  "Request Download" button
> appears because the resource does not have any "download link" configured
> on the DB.
> Not sure why they have been deleted/removed.
> Il giorno lun 16 dic 2019 alle ore 11:30 Paolo Pasquali <
> paolo.pasquali at gmail.com> ha scritto:
>> Should be 2.10.0 or something like that but less than 2.10.1
>> For instance, in the Django admin I don't get the "Set Layer permissions"
>> action from the drop down menu.
>> Anyway, If I run
>> python manage.py set_layers_permissions -p download -g SomeGroup
>> Should the expected result be that all the layers are downloadable for
>> that group. But it does not seem to work.
>> Is there a way to set a permission for all the users and not filtered by
>> a group or user?
>> Thanks.
>> Please note that if I upload a new layer, the permissions are properly
>> set.
>> Ciao
>> P.
>> On Mon, Dec 16, 2019 at 10:41 AM Alessio Fabiani <
>>> Uhm,
>>> I don't get this message. Just tried to run the command and it started
>>> scanning the layers. Which version are you using?
>>> Moreover, if you want to batch set/unset the permissions you might want
>>> to consider also this command here
>>> http://docs.geonode.org/en/master/admin/mgmt_commands/index.html#batch-sync-permissions
>>> I'm using 2.10.x branch now.
>>> Il giorno lun 16 dic 2019 alle ore 09:50 Paolo Pasquali <
>>>> Ciao Alessio,
>>>> Thanks for the reply.
>>>> I've already followed this documentation section but without success.
>>>> If I run:
>>>> python manage.py sync_geonode_layers --updatepermissions
>>>> I get:
>>>> manage.py sync_geonode_layers: error: argument --updatepermissions:
>>>> expected one argument
>>>> Which argument should I specify?
>>>> Thanks,
>>>> P.
>>>> On Mon, Dec 16, 2019 at 9:38 AM Alessio Fabiani <
>>>>> Hello Paolo,
>>>>> probably this section of the docs might be helpful
>>>>> http://docs.geonode.org/en/master/admin/mgmt_commands/index.html#update-permissions-metadata-legends-and-download-links
>>>>> Il giorno ven 13 dic 2019 alle ore 17:05 Paolo Pasquali <
>>>>>> Dear all,
>>>>>> I'm still struggling with the permission system (again).
>>>>>> I have migrated several layers from an old version into a GeoNode
>>>>>> 2.10. I have launched the updatelayers and sync_geonode_layers commands but
>>>>>> for all these layers I have the "Request Download" button instead of the
>>>>>> "Download Layer" button.
>>>>>> The problem is that my user is administrator and "Anyone" is flagged
>>>>>> for "Who can download this layer?" in the permission modal.
>>>>>> Could you suggest how to fix this issue?
>>>>>> Please note that some commands mentioned in the docs such as
>>>>>> set_layer_permissions are not available in my 2.10 version.
>>>>>> If I upload a new layer everything is fine.
>>>>>> Thanks.
>>>>>> Best,
>>>>>> Paolo
>>>>>> _______________________________________________
>>>>>> geonode-users mailing list
>>>>>> geonode-users at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>> GeoServer Professional Services from the experts! Visit
>>>>> http://goo.gl/it488V for more information.
>>>>> Ing. Alessio Fabiani
>>>>> @alfa7691
>>>>> Founder/Technical Lead
>>>>> GeoSolutions S.A.S.
>>>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>>>> phone: +39 0584 962313
>>>>> fax:     +39 0584 1660272
>>>>> mob:   +39 331 6233686
>>>>> http://www.geo-solutions.it
>>>>> http://twitter.com/geosolutions_it
>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>> This email is intended only for the person or entity to which it is
>>>>> addressed and may contain information that is privileged, confidential or
>>>>> otherwise protected from disclosure. We remind that - as provided by
>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>> e-mail or the information herein by anyone other than the intended
>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>> notify us immediately by telephone or e-mail.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191216/3dae5371/attachment-0001.html>
More information about the geonode-users mailing list
