[GeoNode-users] Permissions - Cannot download layers
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Mon Dec 16 04:14:32 PST 2019
Probably the "set_all_layers_metadata -d" management command, but I'm
not sure the most updated version is present on your current platform.
Il giorno lun 16 dic 2019 alle ore 13:09 Paolo Pasquali <
paolo.pasquali at gmail.com> ha scritto:
> Is there a chance to restore the download link in the db?
> In what table can I find this value?
> Thanks.
> On Mon, Dec 16, 2019 at 11:38 AM Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> @Paolo Pasquali <paolo.pasquali at gmail.com> the "Request
>> Download" button appears because the resource does not have any "download
>> link" configured on the DB.
>> Not sure why they have been deleted/removed.
>> Il giorno lun 16 dic 2019 alle ore 11:30 Paolo Pasquali <
>>> Should be 2.10.0 or something like that but less than 2.10.1
>>> For instance, in the Django admin I don't get the "Set Layer
>>> permissions" action from the drop down menu.
>>> Anyway, If I run
>>> python manage.py set_layers_permissions -p download -g SomeGroup
>>> Should the expected result be that all the layers are downloadable for
>>> that group. But it does not seem to work.
>>> Is there a way to set a permission for all the users and not filtered by
>>> a group or user?
>>> Thanks.
>>> Please note that if I upload a new layer, the permissions are properly
>>> set.
>>> Ciao
>>> P.
>>> On Mon, Dec 16, 2019 at 10:41 AM Alessio Fabiani <
>>>> Uhm,
>>>> I don't get this message. Just tried to run the command and it started
>>>> scanning the layers. Which version are you using?
>>>> Moreover, if you want to batch set/unset the permissions you might want
>>>> to consider also this command here
>>>> http://docs.geonode.org/en/master/admin/mgmt_commands/index.html#batch-sync-permissions
>>>> I'm using 2.10.x branch now.
>>>> Il giorno lun 16 dic 2019 alle ore 09:50 Paolo Pasquali <
>>>>> Ciao Alessio,
>>>>> Thanks for the reply.
>>>>> I've already followed this documentation section but without success.
>>>>> If I run:
>>>>> python manage.py sync_geonode_layers --updatepermissions
>>>>> I get:
>>>>> manage.py sync_geonode_layers: error: argument --updatepermissions:
>>>>> expected one argument
>>>>> Which argument should I specify?
>>>>> Thanks,
>>>>> P.
>>>>> On Mon, Dec 16, 2019 at 9:38 AM Alessio Fabiani <
>>>>>> Hello Paolo,
>>>>>> probably this section of the docs might be helpful
>>>>>> http://docs.geonode.org/en/master/admin/mgmt_commands/index.html#update-permissions-metadata-legends-and-download-links
>>>>>> Il giorno ven 13 dic 2019 alle ore 17:05 Paolo Pasquali <
>>>>>>> Dear all,
>>>>>>> I'm still struggling with the permission system (again).
>>>>>>> I have migrated several layers from an old version into a GeoNode
>>>>>>> 2.10. I have launched the updatelayers and sync_geonode_layers commands but
>>>>>>> for all these layers I have the "Request Download" button instead of the
>>>>>>> "Download Layer" button.
>>>>>>> The problem is that my user is administrator and "Anyone" is flagged
>>>>>>> for "Who can download this layer?" in the permission modal.
>>>>>>> Could you suggest how to fix this issue?
>>>>>>> Please note that some commands mentioned in the docs such as
>>>>>>> set_layer_permissions are not available in my 2.10 version.
>>>>>>> If I upload a new layer everything is fine.
>>>>>>> Thanks.
>>>>>>> Best,
>>>>>>> Paolo
>>>>>>> _______________________________________________
>>>>>>> geonode-users mailing list
>>>>>>> geonode-users at lists.osgeo.org
>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>> http://goo.gl/it488V for more information.
>>>>>> Ing. Alessio Fabiani
>>>>>> @alfa7691
>>>>>> Founder/Technical Lead
>>>>>> GeoSolutions S.A.S.
>>>>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>>>>> phone: +39 0584 962313
>>>>>> fax: +39 0584 1660272
>>>>>> mob: +39 331 6233686
>>>>>> http://www.geo-solutions.it
>>>>>> http://twitter.com/geosolutions_it
>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>>> This email is intended only for the person or entity to which it is
>>>>>> addressed and may contain information that is privileged, confidential or
>>>>>> otherwise protected from disclosure. We remind that - as provided by
>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>>> e-mail or the information herein by anyone other than the intended
>>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>>> notify us immediately by telephone or e-mail.
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> @alfa7691
>> GeoSolutions S.A.S.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191216/3ca2ed60/attachment-0001.html>
More information about the geonode-users
