[GeoNode-users] Permissions - Cannot download layers
Paolo Pasquali paolo.pasquali at gmail.com
Mon Dec 16 05:02:15 PST 2019
Great! It works.
Thank you so much. I owe a beer.
Ciao
P.
On Mon, Dec 16, 2019 at 1:14 PM Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Probably the "set_all_layers_metadata -d" management command, but I'm
> not sure the most updated version is present on your current platform.
> Il giorno lun 16 dic 2019 alle ore 13:09 Paolo Pasquali <
> paolo.pasquali at gmail.com> ha scritto:
>> Is there a chance to restore the download link in the db?
>> In what table can I find this value?
>> Thanks.
>> On Mon, Dec 16, 2019 at 11:38 AM Alessio Fabiani <
>>> @Paolo Pasquali <paolo.pasquali at gmail.com> the  "Request
>>> Download" button appears because the resource does not have any "download
>>> link" configured on the DB.
>>> Not sure why they have been deleted/removed.
>>> Il giorno lun 16 dic 2019 alle ore 11:30 Paolo Pasquali <
>>>> Should be 2.10.0 or something like that but less than 2.10.1
>>>> For instance, in the Django admin I don't get the "Set Layer
>>>> permissions" action from the drop down menu.
>>>> Anyway, If I run
>>>> python manage.py set_layers_permissions -p download -g SomeGroup
>>>> Should the expected result be that all the layers are downloadable for
>>>> that group. But it does not seem to work.
>>>> Is there a way to set a permission for all the users and not filtered
>>>> by a group or user?
>>>> Thanks.
>>>> Please note that if I upload a new layer, the permissions are properly
>>>> set.
>>>> Ciao
>>>> P.
>>>> On Mon, Dec 16, 2019 at 10:41 AM Alessio Fabiani <
>>>>> Uhm,
>>>>> I don't get this message. Just tried to run the command and it started
>>>>> scanning the layers. Which version are you using?
>>>>> Moreover, if you want to batch set/unset the permissions you might
>>>>> want to consider also this command here
>>>>> http://docs.geonode.org/en/master/admin/mgmt_commands/index.html#batch-sync-permissions
>>>>> I'm using 2.10.x branch now.
>>>>> Il giorno lun 16 dic 2019 alle ore 09:50 Paolo Pasquali <
>>>>>> Ciao Alessio,
>>>>>> Thanks for the reply.
>>>>>> I've already followed this documentation section but without success.
>>>>>> If I run:
>>>>>> python manage.py sync_geonode_layers --updatepermissions
>>>>>> I get:
>>>>>> manage.py sync_geonode_layers: error: argument --updatepermissions:
>>>>>> expected one argument
>>>>>> Which argument should I specify?
>>>>>> Thanks,
>>>>>> P.
>>>>>> On Mon, Dec 16, 2019 at 9:38 AM Alessio Fabiani <
>>>>>>> Hello Paolo,
>>>>>>> probably this section of the docs might be helpful
>>>>>>> http://docs.geonode.org/en/master/admin/mgmt_commands/index.html#update-permissions-metadata-legends-and-download-links
>>>>>>> Il giorno ven 13 dic 2019 alle ore 17:05 Paolo Pasquali <
>>>>>>>> Dear all,
>>>>>>>> I'm still struggling with the permission system (again).
>>>>>>>> I have migrated several layers from an old version into a GeoNode
>>>>>>>> 2.10. I have launched the updatelayers and sync_geonode_layers commands but
>>>>>>>> for all these layers I have the "Request Download" button instead of the
>>>>>>>> "Download Layer" button.
>>>>>>>> The problem is that my user is administrator and "Anyone" is
>>>>>>>> flagged for "Who can download this layer?" in the permission modal.
>>>>>>>> Could you suggest how to fix this issue?
>>>>>>>> Please note that some commands mentioned in the docs such as
>>>>>>>> set_layer_permissions are not available in my 2.10 version.
>>>>>>>> If I upload a new layer everything is fine.
>>>>>>>> Thanks.
>>>>>>>> Best,
>>>>>>>> Paolo
>>>>>>>> _______________________________________________
>>>>>>>> geonode-users mailing list
>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>> http://goo.gl/it488V for more information.
>>>>>>> Ing. Alessio Fabiani
>>>>>>> @alfa7691
>>>>>>> Founder/Technical Lead
>>>>>>> GeoSolutions S.A.S.
>>>>>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>>>>>> phone: +39 0584 962313
>>>>>>> fax:     +39 0584 1660272
>>>>>>> mob:   +39 331 6233686
>>>>>>> http://www.geo-solutions.it
>>>>>>> http://twitter.com/geosolutions_it
>>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>>>> This email is intended only for the person or entity to which it is
>>>>>>> addressed and may contain information that is privileged, confidential or
>>>>>>> otherwise protected from disclosure. We remind that - as provided by
>>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>>>> e-mail or the information herein by anyone other than the intended
>>>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>>>> notify us immediately by telephone or e-mail.
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191216/d5605870/attachment-0001.html>
More information about the geonode-users mailing list
