[GeoNode-users] CSS, HTML in docker
Matheus Ximenes
Matheus.ximenes2016 at outlook.com
Mon Dec 16 09:58:08 PST 2019
Cool, thanks!
Alessio, hi
before answer works, but the file that change is index.html.
now i would like to know is:
How can i disable these parts:
"Search for Data" and "Discover the available datasets"
i think it's not just removing this part of index.html
[cid:6533159d-9c4e-4fa4-8ad3-b0ab84fa971b]
De: Alessio Fabiani <alessio.fabiani at geo-solutions.it>
Enviado: segunda-feira, 16 de dezembro de 2019 06:22
Para: Matheus Ximenes <Matheus.ximenes2016 at outlook.com>
Cc: geonode-users at lists.osgeo.org <geonode-users at lists.osgeo.org>; geonode-users <geonode-users-bounces at lists.osgeo.org>; geonode-devel <geonode-devel at lists.osgeo.org>
Assunto: Re: [GeoNode-users] CSS, HTML in docker
Dear Matheus,
all HTML files are located into the various "templates" folders. If I correctly understood your needs, most probably you will need to change the "base.html" template file.
CSS and Javascripts are located in the "static" folder instead.
Il giorno ven 13 dic 2019 alle ore 19:33 Matheus Ximenes <Matheus.ximenes2016 at outlook.com<mailto:Matheus.ximenes2016 at outlook.com>> ha scritto:
hi,
First i installed the geonode core, after the geonode from docker, now i want to make a modification in major html of my geonode and wolud like to know where this directory is.
How i installed the geonode from docker in geonode core, they are the same directory? for example:
if i acess this way:
/opt/geonode/geonode/static
and change anything, will that change my GeoNode that runs on localhost?
i would need to find directory that give chance to change this:
[cid:16f0f1508394c18a6881]
The name in the new tab.
I can't find this folder, if anyone helps me, it will be very important to me,
thanks,
Matheus Ximenes
geonode-users mailing list
geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191216/d636207b/attachment-0001.html>
Type: image/png
Desc: Outlook-mxki2wnm.png
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191216/d636207b/attachment-0002.png>
Type: image/png
Desc: Outlook-ydqxmyug.png
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191216/d636207b/attachment-0003.png>
More information about the geonode-users
