[GeoNode-users] Command updatelayers and createsuperuser in docker-compose
Andres Juarez
albertoandres.juarez at gmail.com
Mon Feb 4 17:04:58 PST 2019
Hello
It worked, I was able to create the superuser and publish the layers from
geoserver.
Thank you very much for the help...
regards
El lun., 4 feb. 2019 a las 20:47, MDG DEE (<kula009 at gmail.com>) escribió:
> Hello,
> I had a similar issue before. Here is the solution someone offered and it
> worked for me:
> Log into your django container docker exec -it ...and try:
> mkdir -p /usr/src/app/; \
> source $HOME/.override_env; \
> echo DATABASE_URL=$DATABASE_URL; \
> echo GEODATABASE_URL=$GEODATABASE_URL; \
> echo SITEURL=$SITEURL; \
> echo ALLOWED_HOSTS=$ALLOWED_HOSTS; \
> echo GEOSERVER_PUBLIC_LOCATION=$GEOSERVER_PUBLIC_LOCATION; \
> django-admin createsuperuser
> this will create your new superuser correctly.
> Ran
> On Mon, Feb 4, 2019 at 3:38 PM Andres Juarez <
> albertoandres.juarez at gmail.com> wrote:
>> Hello Francesco, thanks for the reply
>> I access the container django4my_geonode with
>> docker exec -i -t django4my_geonode bash
>> then I execute
>> python manage.py migrate
>> (because without this it did not allow to create the superuser), then
>> python manage.py createsuperuser
>> and after loading the layers in geoserver run
>> python manage.py updatelayers
>> regards
>> and thanks again ...
>> El lun., 4 feb. 2019 a las 18:36, Francesco Bartoli (<
>> xbartolone at gmail.com>) escribió:
>>> Can you briefly show which commands have been executed and against which
>>> container?
>>> Regards,
>>> Francesco
>>> Il 4 feb 2019, 21:43 +0100, Andres Juarez <
>>> albertoandres.juarez at gmail.com>, ha scritto:
>>> Hello everyone
>>> I continue with Geonode 2.10 in docker, and I find a problem when
>>> executing the updatelayers command.
>>> I have several layers in a postgres database on another server, and I
>>> load it through a geoserver store.
>>> The updatelayers command runs flawlessly and warns me that the layers
>>> were updated, but they do not appear in the geonode layers section.
>>> However, I can create an empty map and load these same layers using the add
>>> layer button, selecting 'Geoserver - Public layers'.
>>> The same happens when executing createsuperuser, the process ends
>>> successfully in the command line, but I can not log in with that user.
>>> Thank you in advance for any help you can provide.
>>> Andrés Juarez
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> Andrés Juarez
Andrés Juarez
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190204/f5950db2/attachment.html>
More information about the geonode-users
