[GeoNode-users] Command updatelayers and createsuperuser in docker-compose
MDG DEE kula009 at gmail.com
Mon Feb 4 15:46:58 PST 2019
Hello,
I had a similar issue before. Here is the solution someone offered and it
worked for me:
Log into your django container docker exec -it ...and try:
mkdir -p /usr/src/app/; \
    source $HOME/.override_env; \
    echo DATABASE_URL=$DATABASE_URL; \
    echo GEODATABASE_URL=$GEODATABASE_URL; \
    echo SITEURL=$SITEURL; \
    echo ALLOWED_HOSTS=$ALLOWED_HOSTS; \
    echo GEOSERVER_PUBLIC_LOCATION=$GEOSERVER_PUBLIC_LOCATION; \
    django-admin createsuperuser
this will create your new superuser correctly.
Ran
On Mon, Feb 4, 2019 at 3:38 PM Andres Juarez <albertoandres.juarez at gmail.com>
wrote:
> Hello Francesco, thanks for the reply
> I access the container django4my_geonode with
> docker exec -i -t django4my_geonode bash
> then I execute
> python manage.py migrate
> (because without this it did not allow to create the superuser), then
> python manage.py createsuperuser
> and after loading the layers in geoserver run
> python manage.py updatelayers
> regards
> and thanks again ...
> El lun., 4 feb. 2019 a las 18:36, Francesco Bartoli (<xbartolone at gmail.com>)
> escribió:
>> Can you briefly show which commands have been executed and against which
>> container?
>> Regards,
>> Francesco
>> Il 4 feb 2019, 21:43 +0100, Andres Juarez <albertoandres.juarez at gmail.com>,
>> ha scritto:
>> Hello everyone
>> I continue with Geonode 2.10 in docker, and I find a problem when
>> executing the updatelayers command.
>> I have several layers in a postgres database on another server, and I
>> load it through a geoserver store.
>> The updatelayers command runs flawlessly and warns me that the layers
>> were updated, but they do not appear in the geonode layers section.
>> However, I can create an empty map and load these same layers using the add
>> layer button, selecting 'Geoserver - Public layers'.
>> The same happens when executing createsuperuser, the process ends
>> successfully in the command line, but I can not log in with that user.
>> Thank you in advance for any help you can provide.
>>    Andrés Juarez
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>    Andrés Juarez
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190204/0f4736fb/attachment-0001.html>
More information about the geonode-users mailing list
