[GeoNode-users] Migrate Geonode to new server
Francesco Bartoli xbartolone at gmail.com
Tue Feb 5 13:41:05 PST 2019
Hi Jose,
Is already the source instance a geonode-project template? In case it isn’t I strongly recommend to move under that.
Would the move change the version? I see you are on 2.8 which is fine but 2.10 can be considered stable as well.
Moving the data is the hardest part, I think Toni can suggest better than me with semi-automated procedure and ansible scrips but for sure you have to reconfigure the ip address within the new database for some GeoNode objects like layers and maps.
That said once you land to a new brand geonode-project I would consider to use Docker deployment too which is now well tested.
Regards,
Francesco
Il 5 feb 2019, 21:51 +0100, Jose Cáceres <jose.atyus at gmail.com>, ha scritto:
> Hi everyone,
> I have a Geonode deployment on this server http://206.189.229.38/
> I'm moving all my configuration to a new server, which has a different IP address, so I'm wondering was is the best way to migrate or clone all my server configuration to preserve the custom look as well as layers load, styles, documents and maps composed of my original Geonode site.
> If anyone can point me on the right path it will be much appreciated,
> Thanks,
> José
> José David Cáceres
> Ingeniero Ambiental
> Máster en Tecnologías de la Información Geográfica
> e-mail: jose.atyus at gmail.com
> Remitente notificado con
> Mailtrack 05/02/19 14:48:01
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190205/2200f584/attachment.html>
More information about the geonode-users mailing list
