[GeoNode-users] Migrate Geonode to new server
G. Allegri giohappy at gmail.com
Tue Feb 5 13:57:29 PST 2019
You can apply the backup / response procedure
http://docs.geonode.org/en/master/tutorials/admin/backup_restore/.
Then you can run migrate_baseurl in case sourcs ip / domain is different
from target.
https://github.com/GeoNode/geonode/blob/master/geonode/base/management/commands/migrate_baseurl.py
Giovanni
Il giorno mar 5 feb 2019, 22:41 Francesco Bartoli <xbartolone at gmail.com> ha
scritto:
> Hi Jose,
> Is already the source instance a geonode-project template? In case it
> isn’t I strongly recommend to move under that.
> Would the move change the version? I see you are on 2.8 which is fine but
> 2.10 can be considered stable as well.
> Moving the data is the hardest part, I think Toni can suggest better than
> me with semi-automated procedure and ansible scrips but for sure you have
> to reconfigure the ip address within the new database for some GeoNode
> objects like layers and maps.
> That said once you land to a new brand geonode-project I would consider to
> use Docker deployment too which is now well tested.
> Regards,
> Francesco
> Il 5 feb 2019, 21:51 +0100, Jose Cáceres <jose.atyus at gmail.com>, ha
> scritto:
> Hi everyone,
> I have a Geonode deployment on this server http://206.189.229.38/
> I'm moving all my configuration to a new server, which has a different IP
> address, so I'm wondering was is the best way to migrate or clone all my
> server configuration to preserve the custom look as well as layers load,
> styles, documents and maps composed of my original Geonode site.
> If anyone can point me on the right path it will be much appreciated,
> Thanks,
> José
> José David Cáceres
> Ingeniero Ambiental
> Máster en Tecnologías de la Información Geográfica
> e-mail: jose.atyus at gmail.com
> [image: Mailtrack]
> <https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&> Remitente
> notificado con
> Mailtrack
> <https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&> 05/02/19
> 14:48:01
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190205/5c7d06ea/attachment-0001.html>
More information about the geonode-users mailing list
