[GeoNode-users] Unexpected error when uploading
Paolo Pasquali paolo.pasquali at gmail.com
Mon Feb 11 01:22:32 PST 2019
Thanks.
Is there some test I can do?
P.
On Sat, Feb 9, 2019 at 11:16 PM Francesco Bartoli <xbartolone at gmail.com>
wrote:
> There is a 404 error in geoserver when the rest api is called. I guess the
> problem is in geonode itself because it is still present after having
> updated the GEOSERVER_PUBLIC_LOCATION from /geoserver to /gs in
> geonode-project. Need to investigate further
> Il 9 feb 2019, 22:47 +0100, Paolo Pasquali <paolo.pasquali at gmail.com>, ha
> scritto:
> Thanks Francesco.
> On 9 Feb 2019, 22:13 +0100, Francesco Bartoli <xbartolone at gmail.com>,
> wrote:
> I can confirm this issue in a new brand geonode-project
> Il 8 feb 2019, 18:44 +0100, Francesco Bartoli <xbartolone at gmail.com>, ha
> scritto:
> Ciao Paolo,
> I don’t remember if this has been already reported or not. Can you kindly
> check it out and eventually open an issue on geonode-project?
> Thanks!
> Francesco
> Il 8 feb 2019, 16:49 +0100, Paolo Pasquali <paolo.pasquali at gmail.com>, ha
> scritto:
> Dear all,
> I have installed a GeoNode 2.10.x (master) with Docker and using the
> geonode-project and following this documentation: [1]
> The issue I have is an Unespected error! when I try to upload a layer. So
> in GeoNode the layer is not present.
> But when I double check I find the layer in GeoServer with no apparent
> issue and if I run updatelayers the layer appear in the django db and of
> course in GeoNode.
> I have found these errors in the log:
> 08 Feb 15:38:06 ERROR [geoserver.rest] - No such layer:
> ne_10m_geography_regions_polys
> geoserver4fabspace | org.geoserver.rest.ResourceNotFoundException 404
> NOT_FOUND: No such layer: ne_10m_geography_regions_polys
> 08 Feb 15:38:15 ERROR [geoserver.rest] - No such style
> ne_10m_geography_regions_polys in workspace geonode
> org.geoserver.rest.ResourceNotFoundException 404 NOT_FOUND: No such style
> Your help would be much appreciated.
> Thanks!
> Paolo
> [1] https://github.com/GeoNode/geonode-project#start-your-server
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190211/a9b8a0c7/attachment.html>
More information about the geonode-users mailing list
