[GeoNode-users] Unexpected error when uploading
Francesco Bartoli xbartolone at gmail.com
Mon Feb 11 01:28:57 PST 2019
I have tried with docker-compose after having applied this PRrebuilt the image
Il 11 feb 2019, 10:22 +0100, Paolo Pasquali <paolo.pasquali at gmail.com>, ha scritto:
> Thanks.
> Is there some test I can do?
> P.
> > On Sat, Feb 9, 2019 at 11:16 PM Francesco Bartoli <xbartolone at gmail.com> wrote:
> > > There is a 404 error in geoserver when the rest api is called. I guess the problem is in geonode itself because it is still present after having updated the GEOSERVER_PUBLIC_LOCATION from /geoserver to /gs in geonode-project. Need to investigate further
> > > Il 9 feb 2019, 22:47 +0100, Paolo Pasquali <paolo.pasquali at gmail.com>, ha scritto:
> > > > Thanks Francesco.
> > > > On 9 Feb 2019, 22:13 +0100, Francesco Bartoli <xbartolone at gmail.com>, wrote:
> > > > > I can confirm this issue in a new brand geonode-project
> > > > > Il 8 feb 2019, 18:44 +0100, Francesco Bartoli <xbartolone at gmail.com>, ha scritto:
> > > > > > Ciao Paolo,
> > > > > > I don’t remember if this has been already reported or not. Can you kindly check it out and eventually open an issue on geonode-project?
> > > > > > Thanks!
> > > > > > Francesco
> > > > > > Il 8 feb 2019, 16:49 +0100, Paolo Pasquali <paolo.pasquali at gmail.com>, ha scritto:
> > > > > > > Dear all,
> > > > > > > I have installed a GeoNode 2.10.x (master) with Docker and using the geonode-project and following this documentation: [1]
> > > > > > > The issue I have is an Unespected error! when I try to upload a layer. So in GeoNode the layer is not present.
> > > > > > > But when I double check I find the layer in GeoServer with no apparent issue and if I run updatelayers the layer appear in the django db and of course in GeoNode.
> > > > > > > I have found these errors in the log:
> > > > > > > 08 Feb 15:38:06 ERROR [geoserver.rest] - No such layer: ne_10m_geography_regions_polys
> > > > > > > geoserver4fabspace | org.geoserver.rest.ResourceNotFoundException 404 NOT_FOUND: No such layer: ne_10m_geography_regions_polys
> > > > > > > 08 Feb 15:38:15 ERROR [geoserver.rest] - No such style ne_10m_geography_regions_polys in workspace geonode
> > > > > > > org.geoserver.rest.ResourceNotFoundException 404 NOT_FOUND: No such style ne_10m_geography_regions_polys in workspace geonode
> > > > > > > Your help would be much appreciated.
> > > > > > > Thanks!
> > > > > > > Paolo
> > > > > > > [1] https://github.com/GeoNode/geonode-project#start-your-server
> > > > > > > _______________________________________________
> > > > > > > geonode-users mailing list
> > > > > > > geonode-users at lists.osgeo.org
> > > > > > > https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190211/40cd3c1d/attachment.html>
More information about the geonode-users mailing list
