[GeoNode-users] Unexpected error when uploading
    Alessio Fabiani
    alessio.fabiani at geo-solutions.it
    Mon Feb 11 01:50:48 PST 2019
Dear all,
I'm going to make a test also myself.
>From the logged report my guess is that, somehow, the GeoFence rules are
not correctly set after the upload.
Il giorno lun 11 feb 2019 alle ore 10:39 Dimitris Karakostis <
karakostis.dimitris at gmail.com> ha scritto:
> Hello Paolo,
> I am not sure if this helps but, I had the same error sometime ago and it
> was related to folder permissions and ownership. I fixed by assigning the
> right permissions to the following folders:
> $ sudo chown -Rf geonode /home/geonode/my_geonode/
> $ sudo chown -Rf geonode:www-data /home/geonode/my_geonode/my_geonode/static/
> $ sudo chown -Rf geonode:www-data /home/geonode/my_geonode/my_geonode/uploaded/
> $ chmod -Rf 777 /home/geonode/my_geonode/my_geonode/uploaded/thumbs
> $ chmod -Rf 777 /home/geonode/my_geonode/my_geonode/uploaded/layers
> $ sudo chown www-data:www-data /home/geonode/my_geonode/my_geonode/static_root/
> From here:
> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/setup_configure_httpd.html
> On Fri, Feb 8, 2019 at 4:49 PM Paolo Pasquali <paolo.pasquali at gmail.com>
> wrote:
>> Dear all,
>> I have installed a GeoNode 2.10.x (master) with Docker and using the
>> geonode-project and following this documentation: [1]
>> The issue I have is an Unespected error! when I try to upload a layer.
>> So in GeoNode the layer is not present.
>> But when I double check I find the layer in GeoServer with no apparent
>> issue and if I run updatelayers the layer appear in the django db and of
>> course in GeoNode.
>> I have found these errors in the log:
>> 08 Feb 15:38:06 ERROR [geoserver.rest] - No such layer:
>> ne_10m_geography_regions_polys
>> geoserver4fabspace | org.geoserver.rest.ResourceNotFoundException 404
>> NOT_FOUND: No such layer: ne_10m_geography_regions_polys
>> 08 Feb 15:38:15 ERROR [geoserver.rest] - No such style
>> ne_10m_geography_regions_polys in workspace geonode
>> org.geoserver.rest.ResourceNotFoundException 404 NOT_FOUND: No such style
>> Your help would be much appreciated.
>> Thanks!
>> Paolo
>> [1] https://github.com/GeoNode/geonode-project#start-your-server
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190211/bd1ae5d2/attachment-0001.html>
More information about the geonode-users
