[GeoNode-users] Unexpected error when uploading
Paolo Pasquali paolo.pasquali at gmail.com
Mon Feb 11 02:47:39 PST 2019
Hi all,
These are the GeoFence rules after uploading 3 layers:
[image: Screenshot 2019-02-11 at 11.45.58.png]
On Mon, Feb 11, 2019 at 10:51 AM Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Dear all,
> I'm going to make a test also myself.
> From the logged report my guess is that, somehow, the GeoFence rules are
> not correctly set after the upload.
> Il giorno lun 11 feb 2019 alle ore 10:39 Dimitris Karakostis <
> karakostis.dimitris at gmail.com> ha scritto:
>> Hello Paolo,
>> I am not sure if this helps but, I had the same error sometime ago and it
>> was related to folder permissions and ownership. I fixed by assigning the
>> right permissions to the following folders:
>> $ sudo chown -Rf geonode /home/geonode/my_geonode/
>> $ sudo chown -Rf geonode:www-data /home/geonode/my_geonode/my_geonode/static/
>> $ sudo chown -Rf geonode:www-data /home/geonode/my_geonode/my_geonode/uploaded/
>> $ chmod -Rf 777 /home/geonode/my_geonode/my_geonode/uploaded/thumbs
>> $ chmod -Rf 777 /home/geonode/my_geonode/my_geonode/uploaded/layers
>> $ sudo chown www-data:www-data /home/geonode/my_geonode/my_geonode/static_root/
>> From here:
>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/setup_configure_httpd.html
>> On Fri, Feb 8, 2019 at 4:49 PM Paolo Pasquali <paolo.pasquali at gmail.com>
>> wrote:
>>> Dear all,
>>> I have installed a GeoNode 2.10.x (master) with Docker and using the
>>> geonode-project and following this documentation: [1]
>>> The issue I have is an Unespected error! when I try to upload a layer.
>>> So in GeoNode the layer is not present.
>>> But when I double check I find the layer in GeoServer with no apparent
>>> issue and if I run updatelayers the layer appear in the django db and of
>>> course in GeoNode.
>>> I have found these errors in the log:
>>> 08 Feb 15:38:06 ERROR [geoserver.rest] - No such layer:
>>> ne_10m_geography_regions_polys
>>> geoserver4fabspace | org.geoserver.rest.ResourceNotFoundException 404
>>> NOT_FOUND: No such layer: ne_10m_geography_regions_polys
>>> 08 Feb 15:38:15 ERROR [geoserver.rest] - No such style
>>> ne_10m_geography_regions_polys in workspace geonode
>>> org.geoserver.rest.ResourceNotFoundException 404 NOT_FOUND: No such
>>> style ne_10m_geography_regions_polys in workspace geonode
>>> Your help would be much appreciated.
>>> Thanks!
>>> Paolo
>>> [1] https://github.com/GeoNode/geonode-project#start-your-server
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190211/642e1f82/attachment-0001.html>
Name: Screenshot 2019-02-11 at 11.45.58.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190211/642e1f82/attachment-0001.png>
More information about the geonode-users mailing list
