[GeoNode-users] Installation error 2.10 on CentOS
Federico Gianoli alpacagis at gmail.com
Mon Feb 11 02:02:04 PST 2019
Thanks Alessio,
Now, during the installation of geonode-oauth-toolkit>=1.1.2rc0,  I have
this error:
Installing collected packages: geonode-oauth-toolkit
Exception:
  File
"/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/cli/base_command.py",
line 179, in main
    status = self.run(options, args)
  File
"/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/commands/install.py",
line 393, in run
    use_user_site=options.use_user_site,
  File
"/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/req/__init__.py",
line 57, in install_given_reqs
    **kwargs
  File
"/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/req/req_install.py",
line 913, in install
    use_user_site=use_user_site, pycompile=pycompile,
  File
line 445, in move_wheel_files
    warn_script_location=warn_script_location,
  File
"/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/wheel.py",
line 421, in move_wheel_files
    assert info_dir, "%s .dist-info directory not found" % req
AssertionError: geonode-oauth-toolkit>=1.1.2rc0 .dist-info directory not
found
Il giorno ven 8 feb 2019 alle ore 15:10 Alessio Fabiani <
alessio.fabiani at geo-solutions.it> ha scritto:
> Hello Federico,
> it looks like you have an old version of geonode-oauth-toolkit
> Coult you try a
> pip freeze | grep oauth
> You should get the following results:
> geonode-oauth-toolkit==1.1.2rc0
> oauthlib==2.1.0
> requests-oauthlib==1.0.0
> Il giorno ven 8 feb 2019 alle ore 11:35 Federico Gianoli <
> alpacagis at gmail.com> ha scritto:
>> Dear all, I am trying to install GeoNode 2.10 on Centos.
>> I am following this guide (
>> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit
>> <https://www.google.com/url?q=https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit&sa=D&source=hangouts&ust=1549686966108000&usg=AFQjCNFJm4OMOTuTsHR3fuPFWeZZT4cdfQ> ),
>> everything works fine until the command paver syn that returns this error.
>> Someone else experieced the same issue or have any suggestion to solve it?
>> Thanks a lot
>> paver sync
>> ---> pavement.sync
>>  python -W ignore manage.py makemigrations --noinput
>> No changes detected
>>  python -W ignore manage.py migrate --noinput
>> Operations to perform:
>>   Apply all migrations: account, actstream, admin, agon_ratings,
>> announcements, auth, avatar, base, contenttypes, dialogos, documents,
>> geonode_client, geonode_themes, groups, guardian, invitations, layers,
>> maps, oauth2_provider, people, pinax_notifications, services, sessions,
>> sites, socialaccount, taggit, tastypie, upload, user_messages
>> Running migrations:
>>   Applying contenttypes.0001_initial... OK
>>   Applying taggit.0001_initial... OK
>>   Applying taggit.0002_auto_20150616_2121... OK
>>   Applying contenttypes.0002_remove_content_type_name... OK
>>   Applying auth.0001_initial... OK
>>   Applying auth.0002_alter_permission_name_max_length... OK
>>   Applying auth.0003_alter_user_email_max_length... OK
>>   Applying auth.0004_alter_user_username_opts... OK
>>   Applying auth.0005_alter_user_last_login_null... OK
>>   Applying auth.0006_require_contenttypes_0002... OK
>>   Applying people.24_initial... OK
>>   Applying account.0001_initial... OK
>>   Applying account.0002_email_max_length... OK
>>   Applying actstream.0001_initial... OK
>>   Applying actstream.0002_remove_action_data... OK
>>   Applying admin.0001_initial... OK
>>   Applying admin.0002_logentry_remove_auto_add... OK
>>   Applying agon_ratings.0001_initial... OK
>>   Applying announcements.0001_initial... OK
>>   Applying announcements.0002_auto_20190207_1459... OK
>>   Applying auth.0007_alter_validators_add_error_messages... OK
>>   Applying auth.0008_alter_user_username_max_length... OK
>>   Applying avatar.0001_initial... OK
>>   Applying base.24_initial... OK
>>   Applying base.24_to_26... OK
>>   Applying base.26_to_27... OK
>>   Applying base.0027_auto_20170801_1228... OK
>>   Applying base.0028_resourcebase_is_approved... OK
>>   Applying base.0029_auto_20171114_0341... OK
>>   Applying base.0030_auto_20180309_0833... OK
>>   Applying base.0031_auto_20180309_0837... OK
>>   Applying base.0032_auto_20180329_1844... OK
>>   Applying base.0033_auto_20180330_0951... OK
>>   Applying base.0034_auto_20180606_1543... OK
>>   Applying base.0035_resourcebase_dirty_state... OK
>>   Applying base.0036_auto_20190207_1459... OK
>>   Applying dialogos.0001_initial... OK
>>   Applying documents.24_initial... OK
>>   Applying documents.25_add_documentresourcelink_table... OK
>>   Applying documents.26_move_data_to_documentresourcelink_table... OK
>>   Applying documents.27_drop_resource_columns_from_document_table... OK
>>   Applying documents.0028_auto_20170801_1228... OK
>>   Applying documents.0029_auto_20180301_1947... OK
>>   Applying documents.0030_auto_20180302_0430... OK
>>   Applying documents.0031_auto_20180409_1238... OK
>>   Applying documents.0032_auto_20180412_0822... OK
>>   Applying documents.0033_auto_20180414_2120... OK
>>   Applying geonode_client.0001_initial... OK
>>   Applying geonode_client.0002_auto_20180412_1039... OK
>>   Applying
>> geonode_client.0003_geonodethemecustomization_jumbotron_welcome_hide... OK
>>   Applying geonode_client.0004_auto_20180416_1319... OK
>>   Applying geonode_client.0005_auto_20181015_1201... OK
>>   Applying geonode_themes.0001_initial... OK
>>   Applying geonode_themes.0002_auto_20181015_1208... OK
>>   Applying
>> geonode_themes.0003_remove_geonodethemecustomization_identifier... OK
>>   Applying groups.24_initial... OK
>>   Applying groups.26_to_27... OK
>>   Applying groups.0027_auto_20180105_1631... OK
>>   Applying groups.0028_auto_20180606_1543... OK
>>   Applying guardian.0001_initial... OK
>>   Applying invitations.0001_initial... OK
>>   Applying invitations.0002_auto_20151126_0426... OK
>>   Applying invitations.0003_auto_20151126_1523... OK
>>   Applying layers.24_initial... OK
>>   Applying services.24_initial... OK
>>   Applying services.0025_harvestjob... OK
>>   Applying services.0026_auto_20171130_0600... OK
>>   Applying services.0027_harvestjob_details... OK
>>   Applying services.0028_auto_20171201_0640... OK
>>   Applying services.0029_auto_20171203_1624... OK
>>   Applying services.0030_auto_20171212_0518... OK
>>   Applying layers.24_to_26... OK
>>   Applying layers.26_to_27... OK
>>   Applying layers.0027_auto_20170801_1228... OK
>>   Applying layers.0028_auto_20171218_0249... OK
>>   Applying layers.0029_layer_service... OK
>>   Applying layers.0030_auto_20180228_0812... OK
>>   Applying layers.0031_uploadsession_resource... OK
>>   Applying layers.0032_auto_20180424_1638... OK
>>   Applying layers.0033_auto_20180606_1543... OK
>>   Applying maps.24_initial... OK
>>   Applying maps.0025_auto_20170801_1228... OK
>>   Applying maps.0026_auto_20180301_1947... OK
>>   Applying maps.0027_auto_20180302_0430... OK
>>   Applying maps.0028_auto_20180409_1238... OK
>>   Applying maps.0029_auto_20180412_0822... OK
>>   Applying maps.0030_auto_20180414_2120... OK
>>   Applying oauth2_provider.0001_initial... OK
>>   Applying oauth2_provider.0002_08_updates... OK
>>   Applying oauth2_provider.0003_auto_20160316_1503... OK
>>   Applying oauth2_provider.0004_auto_20160525_1623... OK
>>   Applying people.0025_auto_20170924_0932... OK
>>   Applying people.0026_auto_20171120_0730... OK
>>   Applying people.0027_auto_20180414_2120... OK
>>   Applying people.0028_auto_20180606_1543... OK
>>   Applying pinax_notifications.0001_initial... OK
>>   Applying pinax_notifications.0002_auto_20171003_2006... OK
>>   Applying services.0031_auto_20180301_1947... OK
>>   Applying services.0032_auto_20180302_0430... OK
>>   Applying services.0031_service_proxy_base... OK
>>   Applying services.0033_merge... OK
>>   Applying services.0034_auto_20180309_0917... OK
>>   Applying services.0035_auto_20180327_0846... OK
>>   Applying services.0036_auto_20180331_1039... OK
>>   Applying services.0037_auto_20180409_1238... OK
>>   Applying services.0038_auto_20180412_0822... OK
>>   Applying services.0039_auto_20180414_2120... OK
>>   Applying sessions.0001_initial... OK
>>   Applying sites.0001_initial... OK
>>   Applying sites.0002_alter_domain_unique... OK
>>   Applying socialaccount.0001_initial... OK
>>   Applying socialaccount.0002_token_max_lengths... OK
>>   Applying socialaccount.0003_extra_data_default_dict... OK
>>   Applying tastypie.0001_initial... OK
>>   Applying upload.24_initial... OK
>>   Applying user_messages.0001_initial... OK
>>   Applying user_messages.0002_auto_20171107_1128... OK
>>   Applying user_messages.0003_auto_20171108_1037... OK
>>   Applying user_messages.0004_auto_20171108_1101... OK
>>  python -W ignore manage.py loaddata sample_admin.json
>> Installed 1 object(s) from 1 fixture(s)
>> geonode/base/fixtures/default_oauth_apps.json
>>   File "manage.py", line 29, in <module>
>>     execute_from_command_line(sys.argv)
>>   File
>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/management/__init__.py",
>> line 364, in execute_from_command_line
>>     utility.execute()
>>   File
>> line 356, in execute
>>     self.fetch_command(subcommand).run_from_argv(self.argv)
>>   File
>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/management/base.py",
>> line 283, in run_from_argv
>>     self.execute(*args, **cmd_options)
>>   File
>> line 330, in execute
>>     output = self.handle(*args, **options)
>>   File
>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/modeltranslation/management/commands/loaddata.py",
>> line 61, in handle
>>     return super(Command, self).handle(*fixture_labels, **options)
>>   File
>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/management/commands/loaddata.py",
>> line 69, in handle
>>     self.loaddata(fixture_labels)
>>   File
>> line 109, in loaddata
>>     self.load_label(fixture_label)
>>   File
>> line 166, in load_label
>>     for obj in objects:
>>   File
>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/serializers/json.py",
>> line 88, in Deserializer
>>     six.reraise(DeserializationError, DeserializationError(e),
>> sys.exc_info()[2])
>>   File
>> line 82, in Deserializer
>>     for obj in PythonDeserializer(objects, **options):
>>   File
>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/serializers/python.py",
>> line 129, in Deserializer
>>     field = Model._meta.get_field(field_name)
>>   File
>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/db/models/options.py",
>> line 619, in get_field
>>     raise FieldDoesNotExist("%s has no field named '%s'" %
>> (self.object_name, field_name))
>> django.core.serializers.base.DeserializationError: Problem installing
>> fixture '/srv/www/geonode/geonode/base/fixtures/default_oauth_apps.json':
>> Application has no field named 'updated'
>> Captured Task Output:
>> ---> pavement.sync
>> Build failed running pavement.sync: Subprocess return code: 1
>> Jan 25, 9:54
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190211/166d4ba2/attachment-0001.html>
More information about the geonode-users mailing list
