[GeoNode-users] Installation error 2.10 on CentOS
Alessio Fabiani alessio.fabiani at geo-solutions.it
Mon Feb 11 02:05:11 PST 2019
Hello Federico,
could you try the following command
pip install geonode-oauth-toolkit --upgrade
Il giorno lun 11 feb 2019 alle ore 11:02 Federico Gianoli <
alpacagis at gmail.com> ha scritto:
> Thanks Alessio,
> Now, during the installation of geonode-oauth-toolkit>=1.1.2rc0,  I have
> this error:
> Installing collected packages: geonode-oauth-toolkit
> Exception:
> Traceback (most recent call last):
>   File
> "/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/cli/base_command.py",
> line 179, in main
>     status = self.run(options, args)
>   File
> "/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/commands/install.py",
> line 393, in run
>     use_user_site=options.use_user_site,
>   File
> "/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/req/__init__.py",
> line 57, in install_given_reqs
>     **kwargs
>   File
> "/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/req/req_install.py",
> line 913, in install
>     use_user_site=use_user_site, pycompile=pycompile,
>   File
> line 445, in move_wheel_files
>     warn_script_location=warn_script_location,
>   File
> "/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/wheel.py",
> line 421, in move_wheel_files
>     assert info_dir, "%s .dist-info directory not found" % req
> AssertionError: geonode-oauth-toolkit>=1.1.2rc0 .dist-info directory not
> found
> Il giorno ven 8 feb 2019 alle ore 15:10 Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> ha scritto:
>> Hello Federico,
>> it looks like you have an old version of geonode-oauth-toolkit
>> Coult you try a
>> pip freeze | grep oauth
>> You should get the following results:
>> geonode-oauth-toolkit==1.1.2rc0
>> oauthlib==2.1.0
>> requests-oauthlib==1.0.0
>> Il giorno ven 8 feb 2019 alle ore 11:35 Federico Gianoli <
>>> Dear all, I am trying to install GeoNode 2.10 on Centos.
>>> I am following this guide (
>>> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit
>>> <https://www.google.com/url?q=https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit&sa=D&source=hangouts&ust=1549686966108000&usg=AFQjCNFJm4OMOTuTsHR3fuPFWeZZT4cdfQ> ),
>>> everything works fine until the command paver syn that returns this error.
>>> Someone else experieced the same issue or have any suggestion to solve it?
>>> Thanks a lot
>>> paver sync
>>> ---> pavement.sync
>>>  python -W ignore manage.py makemigrations --noinput
>>> No changes detected
>>>  python -W ignore manage.py migrate --noinput
>>> Operations to perform:
>>>   Apply all migrations: account, actstream, admin, agon_ratings,
>>> announcements, auth, avatar, base, contenttypes, dialogos, documents,
>>> geonode_client, geonode_themes, groups, guardian, invitations, layers,
>>> maps, oauth2_provider, people, pinax_notifications, services, sessions,
>>> sites, socialaccount, taggit, tastypie, upload, user_messages
>>> Running migrations:
>>>   Applying contenttypes.0001_initial... OK
>>>   Applying taggit.0001_initial... OK
>>>   Applying taggit.0002_auto_20150616_2121... OK
>>>   Applying contenttypes.0002_remove_content_type_name... OK
>>>   Applying auth.0001_initial... OK
>>>   Applying auth.0002_alter_permission_name_max_length... OK
>>>   Applying auth.0003_alter_user_email_max_length... OK
>>>   Applying auth.0004_alter_user_username_opts... OK
>>>   Applying auth.0005_alter_user_last_login_null... OK
>>>   Applying auth.0006_require_contenttypes_0002... OK
>>>   Applying people.24_initial... OK
>>>   Applying account.0001_initial... OK
>>>   Applying account.0002_email_max_length... OK
>>>   Applying actstream.0001_initial... OK
>>>   Applying actstream.0002_remove_action_data... OK
>>>   Applying admin.0001_initial... OK
>>>   Applying admin.0002_logentry_remove_auto_add... OK
>>>   Applying agon_ratings.0001_initial... OK
>>>   Applying announcements.0001_initial... OK
>>>   Applying announcements.0002_auto_20190207_1459... OK
>>>   Applying auth.0007_alter_validators_add_error_messages... OK
>>>   Applying auth.0008_alter_user_username_max_length... OK
>>>   Applying avatar.0001_initial... OK
>>>   Applying base.24_initial... OK
>>>   Applying base.24_to_26... OK
>>>   Applying base.26_to_27... OK
>>>   Applying base.0027_auto_20170801_1228... OK
>>>   Applying base.0028_resourcebase_is_approved... OK
>>>   Applying base.0029_auto_20171114_0341... OK
>>>   Applying base.0030_auto_20180309_0833... OK
>>>   Applying base.0031_auto_20180309_0837... OK
>>>   Applying base.0032_auto_20180329_1844... OK
>>>   Applying base.0033_auto_20180330_0951... OK
>>>   Applying base.0034_auto_20180606_1543... OK
>>>   Applying base.0035_resourcebase_dirty_state... OK
>>>   Applying base.0036_auto_20190207_1459... OK
>>>   Applying dialogos.0001_initial... OK
>>>   Applying documents.24_initial... OK
>>>   Applying documents.25_add_documentresourcelink_table... OK
>>>   Applying documents.26_move_data_to_documentresourcelink_table... OK
>>>   Applying documents.27_drop_resource_columns_from_document_table... OK
>>>   Applying documents.0028_auto_20170801_1228... OK
>>>   Applying documents.0029_auto_20180301_1947... OK
>>>   Applying documents.0030_auto_20180302_0430... OK
>>>   Applying documents.0031_auto_20180409_1238... OK
>>>   Applying documents.0032_auto_20180412_0822... OK
>>>   Applying documents.0033_auto_20180414_2120... OK
>>>   Applying geonode_client.0001_initial... OK
>>>   Applying geonode_client.0002_auto_20180412_1039... OK
>>>   Applying
>>> geonode_client.0003_geonodethemecustomization_jumbotron_welcome_hide... OK
>>>   Applying geonode_client.0004_auto_20180416_1319... OK
>>>   Applying geonode_client.0005_auto_20181015_1201... OK
>>>   Applying geonode_themes.0001_initial... OK
>>>   Applying geonode_themes.0002_auto_20181015_1208... OK
>>>   Applying
>>> geonode_themes.0003_remove_geonodethemecustomization_identifier... OK
>>>   Applying groups.24_initial... OK
>>>   Applying groups.26_to_27... OK
>>>   Applying groups.0027_auto_20180105_1631... OK
>>>   Applying groups.0028_auto_20180606_1543... OK
>>>   Applying guardian.0001_initial... OK
>>>   Applying invitations.0001_initial... OK
>>>   Applying invitations.0002_auto_20151126_0426... OK
>>>   Applying invitations.0003_auto_20151126_1523... OK
>>>   Applying layers.24_initial... OK
>>>   Applying services.24_initial... OK
>>>   Applying services.0025_harvestjob... OK
>>>   Applying services.0026_auto_20171130_0600... OK
>>>   Applying services.0027_harvestjob_details... OK
>>>   Applying services.0028_auto_20171201_0640... OK
>>>   Applying services.0029_auto_20171203_1624... OK
>>>   Applying services.0030_auto_20171212_0518... OK
>>>   Applying layers.24_to_26... OK
>>>   Applying layers.26_to_27... OK
>>>   Applying layers.0027_auto_20170801_1228... OK
>>>   Applying layers.0028_auto_20171218_0249... OK
>>>   Applying layers.0029_layer_service... OK
>>>   Applying layers.0030_auto_20180228_0812... OK
>>>   Applying layers.0031_uploadsession_resource... OK
>>>   Applying layers.0032_auto_20180424_1638... OK
>>>   Applying layers.0033_auto_20180606_1543... OK
>>>   Applying maps.24_initial... OK
>>>   Applying maps.0025_auto_20170801_1228... OK
>>>   Applying maps.0026_auto_20180301_1947... OK
>>>   Applying maps.0027_auto_20180302_0430... OK
>>>   Applying maps.0028_auto_20180409_1238... OK
>>>   Applying maps.0029_auto_20180412_0822... OK
>>>   Applying maps.0030_auto_20180414_2120... OK
>>>   Applying oauth2_provider.0001_initial... OK
>>>   Applying oauth2_provider.0002_08_updates... OK
>>>   Applying oauth2_provider.0003_auto_20160316_1503... OK
>>>   Applying oauth2_provider.0004_auto_20160525_1623... OK
>>>   Applying people.0025_auto_20170924_0932... OK
>>>   Applying people.0026_auto_20171120_0730... OK
>>>   Applying people.0027_auto_20180414_2120... OK
>>>   Applying people.0028_auto_20180606_1543... OK
>>>   Applying pinax_notifications.0001_initial... OK
>>>   Applying pinax_notifications.0002_auto_20171003_2006... OK
>>>   Applying services.0031_auto_20180301_1947... OK
>>>   Applying services.0032_auto_20180302_0430... OK
>>>   Applying services.0031_service_proxy_base... OK
>>>   Applying services.0033_merge... OK
>>>   Applying services.0034_auto_20180309_0917... OK
>>>   Applying services.0035_auto_20180327_0846... OK
>>>   Applying services.0036_auto_20180331_1039... OK
>>>   Applying services.0037_auto_20180409_1238... OK
>>>   Applying services.0038_auto_20180412_0822... OK
>>>   Applying services.0039_auto_20180414_2120... OK
>>>   Applying sessions.0001_initial... OK
>>>   Applying sites.0001_initial... OK
>>>   Applying sites.0002_alter_domain_unique... OK
>>>   Applying socialaccount.0001_initial... OK
>>>   Applying socialaccount.0002_token_max_lengths... OK
>>>   Applying socialaccount.0003_extra_data_default_dict... OK
>>>   Applying tastypie.0001_initial... OK
>>>   Applying upload.24_initial... OK
>>>   Applying user_messages.0001_initial... OK
>>>   Applying user_messages.0002_auto_20171107_1128... OK
>>>   Applying user_messages.0003_auto_20171108_1037... OK
>>>   Applying user_messages.0004_auto_20171108_1101... OK
>>>  python -W ignore manage.py loaddata sample_admin.json
>>> Installed 1 object(s) from 1 fixture(s)
>>> geonode/base/fixtures/default_oauth_apps.json
>>>   File "manage.py", line 29, in <module>
>>>     execute_from_command_line(sys.argv)
>>>   File
>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/management/__init__.py",
>>> line 364, in execute_from_command_line
>>>     utility.execute()
>>>   File
>>> line 356, in execute
>>>     self.fetch_command(subcommand).run_from_argv(self.argv)
>>>   File
>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/management/base.py",
>>> line 283, in run_from_argv
>>>     self.execute(*args, **cmd_options)
>>>   File
>>> line 330, in execute
>>>     output = self.handle(*args, **options)
>>>   File
>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/modeltranslation/management/commands/loaddata.py",
>>> line 61, in handle
>>>     return super(Command, self).handle(*fixture_labels, **options)
>>>   File
>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/management/commands/loaddata.py",
>>> line 69, in handle
>>>     self.loaddata(fixture_labels)
>>>   File
>>> line 109, in loaddata
>>>     self.load_label(fixture_label)
>>>   File
>>> line 166, in load_label
>>>     for obj in objects:
>>>   File
>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/serializers/json.py",
>>> line 88, in Deserializer
>>>     six.reraise(DeserializationError, DeserializationError(e),
>>> sys.exc_info()[2])
>>>   File
>>> line 82, in Deserializer
>>>     for obj in PythonDeserializer(objects, **options):
>>>   File
>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/serializers/python.py",
>>> line 129, in Deserializer
>>>     field = Model._meta.get_field(field_name)
>>>   File
>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/db/models/options.py",
>>> line 619, in get_field
>>>     raise FieldDoesNotExist("%s has no field named '%s'" %
>>> (self.object_name, field_name))
>>> django.core.serializers.base.DeserializationError: Problem installing
>>> fixture '/srv/www/geonode/geonode/base/fixtures/default_oauth_apps.json':
>>> Application has no field named 'updated'
>>> Captured Task Output:
>>> ---> pavement.sync
>>> Build failed running pavement.sync: Subprocess return code: 1
>>> Jan 25, 9:54
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>> phone: +39 0584 962313
>> fax:     +39 0584 1660272
>> mob:   +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190211/756682ad/attachment-0001.html>
More information about the geonode-users mailing list
