[GeoNode-users] Installation error 2.10 on CentOS
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Mon Feb 11 02:55:33 PST 2019
Uhm, never seen this until now.
Did you have a previous version of the library installed on your
environment? Or is this a fresh setup?
Il giorno lun 11 feb 2019 alle ore 11:52 Federico Gianoli <
alpacagis at gmail.com> ha scritto:
> Hi Alessio,
> Now we have the following error
> pip install geonode-oauth-toolkit --upgrade
> DEPRECATION: Python 2.7 will reach the end of its life on January 1st,
> 2020. Please upgrade your Python as Python 2.7 won't be maintained after
> that date. A future version of pip will drop support for Python 2.7.
> Collecting geonode-oauth-toolkit
> Installing collected packages: geonode-oauth-toolkit
> Exception:
> Traceback (most recent call last):
> File
> "/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/cli/base_command.py",
> line 179, in main
> status = self.run(options, args)
> File
> "/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/commands/install.py",
> line 393, in run
> use_user_site=options.use_user_site,
> File
> "/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/req/__init__.py",
> line 57, in install_given_reqs
> **kwargs
> File
> "/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/req/req_install.py",
> line 913, in install
> use_user_site=use_user_site, pycompile=pycompile,
> File
> line 445, in move_wheel_files
> warn_script_location=warn_script_location,
> File
> "/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/wheel.py",
> line 421, in move_wheel_files
> assert info_dir, "%s .dist-info directory not found" % req
> AssertionError: geonode-oauth-toolkit .dist-info directory not found
> (geonode) $
> Il giorno lunedì 11 febbraio 2019, Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> ha scritto:
>> Hello Federico,
>> could you try the following command
>> Il giorno lun 11 feb 2019 alle ore 11:02 Federico Gianoli <
>>> Thanks Alessio,
>>> Now, during the installation of geonode-oauth-toolkit>=1.1.2rc0, I have
>>> this error:
>>> Exception:
>>> File
>>> line 179, in main
>>> File
>>> line 393, in run
>>> File
>>> **kwargs
>>> File
>>> File
>>> File
>>> AssertionError: geonode-oauth-toolkit>=1.1.2rc0 .dist-info directory not
>>> found
>>> Il giorno ven 8 feb 2019 alle ore 15:10 Alessio Fabiani <
>>>> Hello Federico,
>>>> it looks like you have an old version of geonode-oauth-toolkit
>>>> Coult you try a
>>>> pip freeze | grep oauth
>>>> You should get the following results:
>>>> geonode-oauth-toolkit==1.1.2rc0
>>>> oauthlib==2.1.0
>>>> requests-oauthlib==1.0.0
>>>> Il giorno ven 8 feb 2019 alle ore 11:35 Federico Gianoli <
>>>>> Dear all, I am trying to install GeoNode 2.10 on Centos.
>>>>> I am following this guide (
>>>>> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit
>>>>> <https://www.google.com/url?q=https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit&sa=D&source=hangouts&ust=1549686966108000&usg=AFQjCNFJm4OMOTuTsHR3fuPFWeZZT4cdfQ> ),
>>>>> everything works fine until the command paver syn that returns this error.
>>>>> Someone else experieced the same issue or have any suggestion to solve it?
>>>>> Thanks a lot
>>>>> paver sync
>>>>> ---> pavement.sync
>>>>> python -W ignore manage.py makemigrations --noinput
>>>>> No changes detected
>>>>> python -W ignore manage.py migrate --noinput
>>>>> Operations to perform:
>>>>> Apply all migrations: account, actstream, admin, agon_ratings,
>>>>> announcements, auth, avatar, base, contenttypes, dialogos, documents,
>>>>> geonode_client, geonode_themes, groups, guardian, invitations, layers,
>>>>> maps, oauth2_provider, people, pinax_notifications, services, sessions,
>>>>> sites, socialaccount, taggit, tastypie, upload, user_messages
>>>>> Running migrations:
>>>>> Applying contenttypes.0001_initial... OK
>>>>> Applying taggit.0001_initial... OK
>>>>> Applying taggit.0002_auto_20150616_2121... OK
>>>>> Applying contenttypes.0002_remove_content_type_name... OK
>>>>> Applying auth.0001_initial... OK
>>>>> Applying auth.0002_alter_permission_name_max_length... OK
>>>>> Applying auth.0003_alter_user_email_max_length... OK
>>>>> Applying auth.0004_alter_user_username_opts... OK
>>>>> Applying auth.0005_alter_user_last_login_null... OK
>>>>> Applying auth.0006_require_contenttypes_0002... OK
>>>>> Applying people.24_initial... OK
>>>>> Applying account.0001_initial... OK
>>>>> Applying account.0002_email_max_length... OK
>>>>> Applying actstream.0001_initial... OK
>>>>> Applying actstream.0002_remove_action_data... OK
>>>>> Applying admin.0001_initial... OK
>>>>> Applying admin.0002_logentry_remove_auto_add... OK
>>>>> Applying agon_ratings.0001_initial... OK
>>>>> Applying announcements.0001_initial... OK
>>>>> Applying announcements.0002_auto_20190207_1459... OK
>>>>> Applying auth.0007_alter_validators_add_error_messages... OK
>>>>> Applying auth.0008_alter_user_username_max_length... OK
>>>>> Applying avatar.0001_initial... OK
>>>>> Applying base.24_initial... OK
>>>>> Applying base.24_to_26... OK
>>>>> Applying base.26_to_27... OK
>>>>> Applying base.0027_auto_20170801_1228... OK
>>>>> Applying base.0028_resourcebase_is_approved... OK
>>>>> Applying base.0029_auto_20171114_0341... OK
>>>>> Applying base.0030_auto_20180309_0833... OK
>>>>> Applying base.0031_auto_20180309_0837... OK
>>>>> Applying base.0032_auto_20180329_1844... OK
>>>>> Applying base.0033_auto_20180330_0951... OK
>>>>> Applying base.0034_auto_20180606_1543... OK
>>>>> Applying base.0035_resourcebase_dirty_state... OK
>>>>> Applying base.0036_auto_20190207_1459... OK
>>>>> Applying dialogos.0001_initial... OK
>>>>> Applying documents.24_initial... OK
>>>>> Applying documents.25_add_documentresourcelink_table... OK
>>>>> Applying documents.26_move_data_to_documentresourcelink_table... OK
>>>>> Applying documents.27_drop_resource_columns_from_document_table... OK
>>>>> Applying documents.0028_auto_20170801_1228... OK
>>>>> Applying documents.0029_auto_20180301_1947... OK
>>>>> Applying documents.0030_auto_20180302_0430... OK
>>>>> Applying documents.0031_auto_20180409_1238... OK
>>>>> Applying documents.0032_auto_20180412_0822... OK
>>>>> Applying documents.0033_auto_20180414_2120... OK
>>>>> Applying geonode_client.0001_initial... OK
>>>>> Applying geonode_client.0002_auto_20180412_1039... OK
>>>>> Applying
>>>>> geonode_client.0003_geonodethemecustomization_jumbotron_welcome_hide... OK
>>>>> Applying geonode_client.0004_auto_20180416_1319... OK
>>>>> Applying geonode_client.0005_auto_20181015_1201... OK
>>>>> Applying geonode_themes.0001_initial... OK
>>>>> Applying geonode_themes.0002_auto_20181015_1208... OK
>>>>> Applying
>>>>> geonode_themes.0003_remove_geonodethemecustomization_identifier... OK
>>>>> Applying groups.24_initial... OK
>>>>> Applying groups.26_to_27... OK
>>>>> Applying groups.0027_auto_20180105_1631... OK
>>>>> Applying groups.0028_auto_20180606_1543... OK
>>>>> Applying guardian.0001_initial... OK
>>>>> Applying invitations.0001_initial... OK
>>>>> Applying invitations.0002_auto_20151126_0426... OK
>>>>> Applying invitations.0003_auto_20151126_1523... OK
>>>>> Applying layers.24_initial... OK
>>>>> Applying services.24_initial... OK
>>>>> Applying services.0025_harvestjob... OK
>>>>> Applying services.0026_auto_20171130_0600... OK
>>>>> Applying services.0027_harvestjob_details... OK
>>>>> Applying services.0028_auto_20171201_0640... OK
>>>>> Applying services.0029_auto_20171203_1624... OK
>>>>> Applying services.0030_auto_20171212_0518... OK
>>>>> Applying layers.24_to_26... OK
>>>>> Applying layers.26_to_27... OK
>>>>> Applying layers.0027_auto_20170801_1228... OK
>>>>> Applying layers.0028_auto_20171218_0249... OK
>>>>> Applying layers.0029_layer_service... OK
>>>>> Applying layers.0030_auto_20180228_0812... OK
>>>>> Applying layers.0031_uploadsession_resource... OK
>>>>> Applying layers.0032_auto_20180424_1638... OK
>>>>> Applying layers.0033_auto_20180606_1543... OK
>>>>> Applying maps.24_initial... OK
>>>>> Applying maps.0025_auto_20170801_1228... OK
>>>>> Applying maps.0026_auto_20180301_1947... OK
>>>>> Applying maps.0027_auto_20180302_0430... OK
>>>>> Applying maps.0028_auto_20180409_1238... OK
>>>>> Applying maps.0029_auto_20180412_0822... OK
>>>>> Applying maps.0030_auto_20180414_2120... OK
>>>>> Applying oauth2_provider.0001_initial... OK
>>>>> Applying oauth2_provider.0002_08_updates... OK
>>>>> Applying oauth2_provider.0003_auto_20160316_1503... OK
>>>>> Applying oauth2_provider.0004_auto_20160525_1623... OK
>>>>> Applying people.0025_auto_20170924_0932... OK
>>>>> Applying people.0026_auto_20171120_0730... OK
>>>>> Applying people.0027_auto_20180414_2120... OK
>>>>> Applying people.0028_auto_20180606_1543... OK
>>>>> Applying pinax_notifications.0001_initial... OK
>>>>> Applying pinax_notifications.0002_auto_20171003_2006... OK
>>>>> Applying services.0031_auto_20180301_1947... OK
>>>>> Applying services.0032_auto_20180302_0430... OK
>>>>> Applying services.0031_service_proxy_base... OK
>>>>> Applying services.0033_merge... OK
>>>>> Applying services.0034_auto_20180309_0917... OK
>>>>> Applying services.0035_auto_20180327_0846... OK
>>>>> Applying services.0036_auto_20180331_1039... OK
>>>>> Applying services.0037_auto_20180409_1238... OK
>>>>> Applying services.0038_auto_20180412_0822... OK
>>>>> Applying services.0039_auto_20180414_2120... OK
>>>>> Applying sessions.0001_initial... OK
>>>>> Applying sites.0001_initial... OK
>>>>> Applying sites.0002_alter_domain_unique... OK
>>>>> Applying socialaccount.0001_initial... OK
>>>>> Applying socialaccount.0002_token_max_lengths... OK
>>>>> Applying socialaccount.0003_extra_data_default_dict... OK
>>>>> Applying tastypie.0001_initial... OK
>>>>> Applying upload.24_initial... OK
>>>>> Applying user_messages.0001_initial... OK
>>>>> Applying user_messages.0002_auto_20171107_1128... OK
>>>>> Applying user_messages.0003_auto_20171108_1037... OK
>>>>> Applying user_messages.0004_auto_20171108_1101... OK
>>>>> python -W ignore manage.py loaddata sample_admin.json
>>>>> Installed 1 object(s) from 1 fixture(s)
>>>>> geonode/base/fixtures/default_oauth_apps.json
>>>>> File "manage.py", line 29, in <module>
>>>>> execute_from_command_line(sys.argv)
>>>>> File
>>>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/management/__init__.py",
>>>>> line 364, in execute_from_command_line
>>>>> utility.execute()
>>>>> File
>>>>> line 356, in execute
>>>>> self.fetch_command(subcommand).run_from_argv(self.argv)
>>>>> File
>>>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/management/base.py",
>>>>> line 283, in run_from_argv
>>>>> self.execute(*args, **cmd_options)
>>>>> File
>>>>> line 330, in execute
>>>>> output = self.handle(*args, **options)
>>>>> File
>>>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/modeltranslation/management/commands/loaddata.py",
>>>>> line 61, in handle
>>>>> return super(Command, self).handle(*fixture_labels, **options)
>>>>> File
>>>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/management/commands/loaddata.py",
>>>>> line 69, in handle
>>>>> self.loaddata(fixture_labels)
>>>>> File
>>>>> line 109, in loaddata
>>>>> self.load_label(fixture_label)
>>>>> File
>>>>> line 166, in load_label
>>>>> for obj in objects:
>>>>> File
>>>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/serializers/json.py",
>>>>> line 88, in Deserializer
>>>>> six.reraise(DeserializationError, DeserializationError(e),
>>>>> sys.exc_info()[2])
>>>>> File
>>>>> line 82, in Deserializer
>>>>> for obj in PythonDeserializer(objects, **options):
>>>>> File
>>>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/serializers/python.py",
>>>>> line 129, in Deserializer
>>>>> field = Model._meta.get_field(field_name)
>>>>> File
>>>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/db/models/options.py",
>>>>> line 619, in get_field
>>>>> raise FieldDoesNotExist("%s has no field named '%s'" %
>>>>> (self.object_name, field_name))
>>>>> django.core.serializers.base.DeserializationError: Problem installing
>>>>> fixture '/srv/www/geonode/geonode/base/fixtures/default_oauth_apps.json':
>>>>> Application has no field named 'updated'
>>>>> Captured Task Output:
>>>>> ---> pavement.sync
>>>>> Build failed running pavement.sync: Subprocess return code: 1
>>>>> Jan 25, 9:54
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>> GeoServer Professional Services from the experts! Visit
>>>> http://goo.gl/it488V for more information.
>>>> Ing. Alessio Fabiani
>>>> @alfa7691
>>>> Founder/Technical Lead
>>>> GeoSolutions S.A.S.
>>>> Via di Montramito 3
>>>> <https://maps.google.com/?q=Via+di+Montramito+3&entry=gmail&source=g>/A
>>>> - 55054 Massarosa (LU) - Italy
>>>> phone: +39 0584 962313
>>>> fax: +39 0584 1660272
>>>> mob: +39 331 6233686
>>>> http://www.geo-solutions.it
>>>> http://twitter.com/geosolutions_it
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>>> precisa che ogni circostanza inerente alla presente email (il suo
>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>> This email is intended only for the person or entity to which it is
>>>> addressed and may contain information that is privileged, confidential or
>>>> otherwise protected from disclosure. We remind that - as provided by
>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>> e-mail or the information herein by anyone other than the intended
>>>> recipient is prohibited. If you have received this email by mistake, please
>>>> notify us immediately by telephone or e-mail.
>> @alfa7691
>> GeoSolutions S.A.S.
>> Via di Montramito 3
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190211/a329d67d/attachment-0001.html>
More information about the geonode-users
