[GeoNode-users] Installation error 2.10 on CentOS
    Alessio Fabiani
    alessio.fabiani at geo-solutions.it
    Mon Feb 11 03:21:12 PST 2019
Federico,
from the logs it looks like the pypi package is not working correctly on
Centos ?!? (just guessing)
Could you mabe try to install it manually from the source code?
https://github.com/GeoNode/geonode-oauth-toolkit
Il giorno lun 11 feb 2019 alle ore 12:01 Federico Gianoli <
alpacagis at gmail.com> ha scritto:
> Ciao, this is a fresh setup on a new machine running centos
> Il giorno lunedì 11 febbraio 2019, Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> ha scritto:
>> Uhm, never seen this until now.
>>  you have a previous version of the library installed on your
>> environment? Or is this a fresh setup?
>> Il giorno lun 11 feb 2019 alle ore 11:52 Federico Gianoli <
>> Hi Alessio,
>> Now we have the following error
>> pip install geonode-oauth-toolkit --upgrade
>> DEPRECATION: Python 2.7 will reach the end of its life on January 1st,
>> 2020. Please upgrade your Python as Python 2.7 won't be maintained after
>> that date. A future version of pip will drop support for Python 2.7.
>> Collecting geonode-oauth-toolkit
>> Installing collected packages: geonode-oauth-toolkit
>> Exception:
>> Traceback (most recent call last):
>>   File
>> "/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/cli/base_command.py",
>> line 179, in main
>>     status = self.run(options, args)
>>   File
>> "/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/commands/install.py",
>> line 393, in run
>>     use_user_site=options.use_user_site,
>>   File
>> "/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/req/__init__.py",
>> line 57, in install_given_reqs
>>     **kwargs
>>   File
>> "/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/req/req_install.py",
>> line 913, in install
>>     use_user_site=use_user_site, pycompile=pycompile,
>>   File
>> line 445, in move_wheel_files
>>     warn_script_location=warn_script_location,
>>   File
>> "/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/wheel.py",
>> line 421, in move_wheel_files
>>     assert info_dir, "%s .dist-info directory not found" % req
>> AssertionError: geonode-oauth-toolkit .dist-info directory not found
>> (geonode) $
>> Hello Federico,
>> could you try the following command
>> Il giorno lun 11 feb 2019 alle ore 11:02 Federico Gianoli <
>> Thanks Alessio,
>> Now, during the installation of geonode-oauth-toolkit>=1.1.2rc0,  I have
>> this error:
>> Exception:
>>   File
>> line 179, in main
>>   File
>> line 393, in run
>>   File
>>     **kwargs
>>   File
>>   File
>>   File
>> AssertionError: geonode-oauth-toolkit>=1.1.2rc0 .dist-info directory not
>> found
>> Il giorno ven 8 feb 2019 alle ore 15:10 Alessio Fabiani <
>> Hello Federico,
>> it looks like you have an old version of geonode-oauth-toolkit
>> Coult you try a
>> pip freeze | grep oauth
>> You should get the following results:
>> geonode-oauth-toolkit==1.1.2rc0
>> oauthlib==2.1.0
>> requests-oauthlib==1.0.0
>> Il giorno ven 8 feb 2019 alle ore 11:35 Federico Gianoli <
>> Dear all, I am trying to install GeoNode 2.10 on Centos.
>> I am following this guide (
>> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit
>> <https://www.google.com/url?q=https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit&sa=D&source=hangouts&ust=1549686966108000&usg=AFQjCNFJm4OMOTuTsHR3fuPFWeZZT4cdfQ> ),
>> everything works fine until the command paver syn that returns this error.
>> Someone else experieced the same issue or have any suggestion to solve it?
>> Thanks a lot
>> paver sync
>> ---> pavement.sync
>>  python -W ignore manage.py makemigrations --noinput
>> No changes detected
>>  python -W ignore manage.py migrate --noinput
>> Operations to perform:
>>   Apply all migrations: account, actstream, admin, agon_ratings,
>> announcements, auth, avatar, base, contenttypes, dialogos, documents,
>> geonode_client, geonode_themes, groups, guardian, invitations, layers,
>> maps, oauth2_provider, people, pinax_notifications, services, sessions,
>> sites, socialaccount, taggit, tastypie, upload, user_messages
>> Running migrations:
>>   Applying contenttypes.0001_initial... OK
>>   Applying taggit.0001_initial... OK
>>   Applying taggit.0002_auto_20150616_2121... OK
>>   Applying contenttypes.0002_remove_content_type_name... OK
>>   Applying auth.0001_initial... OK
>>   Applying auth.0002_alter_permission_name_max_length... OK
>>   Applying auth.0003_alter_user_email_max_length... OK
>>   Applying auth.0004_alter_user_username_opts... OK
>>   Applying auth.0005_alter_user_last_login_null... OK
>>   Applying auth.0006_require_contenttypes_0002... OK
>>   Applying people.24_initial... OK
>>   Applying account.0001_initial... OK
>>   Applying account.0002_email_max_length... OK
>>   Applying actstream.0001_initial... OK
>>   Applying actstream.0002_remove_action_data... OK
>>   Applying admin.0001_initial... OK
>>   Applying admin.0002_logentry_remove_auto_add... OK
>>   Applying agon_ratings.0001_initial... OK
>>   Applying announcements.0001_initial... OK
>>   Applying announcements.0002_auto_20190207_1459... OK
>>   Applying auth.0007_alter_validators_add_error_messages... OK
>>   Applying auth.0008_alter_user_username_max_length... OK
>>   Applying avatar.0001_initial... OK
>>   Applying base.24_initial... OK
>>   Applying base.24_to_26... OK
>>   Applying base.26_to_27... OK
>>   Applying base.0027_auto_20170801_1228... OK
>>   Applying base.0028_resourcebase_is_approved... OK
>>   Applying base.0029_auto_20171114_0341... OK
>>   Applying base.0030_auto_20180309_0833... OK
>>   Applying base.0031_auto_20180309_0837... OK
>>   Applying base.0032_auto_20180329_1844... OK
>>   Applying base.0033_auto_20180330_0951... OK
>>   Applying base.0034_auto_20180606_1543... OK
>>   Applying base.0035_resourcebase_dirty_state... OK
>>   Applying base.0036_auto_20190207_1459... OK
>>   Applying dialogos.0001_initial... OK
>>   Applying documents.24_initial... OK
>>   Applying documents.25_add_documentresourcelink_table... OK
>>   Applying documents.26_move_data_to_documentresourcelink_table... OK
>>   Applying documents.27_drop_resource_columns_from_document_table... OK
>>   Applying documents.0028_auto_20170801_1228... OK
>>   Applying documents.0029_auto_20180301_1947... OK
>>   Applying documents.0030_auto_20180302_0430... OK
>>   Applying documents.0031_auto_20180409_1238... OK
>>   Applying documents.0032_auto_20180412_0822... OK
>>   Applying documents.0033_auto_20180414_2120... OK
>>   Applying geonode_client.0001_initial... OK
>>   Applying geonode_client.0002_auto_20180412_1039... OK
>>   Applying
>> geonode_client.0003_geonodethemecustomization_jumbotron_welcome_hide... OK
>>   Applying geonode_client.0004_auto_20180416_1319... OK
>>   Applying geonode_client.0005_auto_20181015_1201... OK
>>   Applying geonode_themes.0001_initial... OK
>>   Applying geonode_themes.0002_auto_20181015_1208... OK
>>   Applying
>> geonode_themes.0003_remove_geonodethemecustomization_identifier... OK
>>   Applying groups.24_initial... OK
>>   Applying groups.26_to_27... OK
>>   Applying groups.0027_auto_20180105_1631... OK
>>   Applying groups.0028_auto_20180606_1543... OK
>>   Applying guardian.0001_initial... OK
>>   Applying invitations.0001_initial... OK
>>   Applying invitations.0002_auto_20151126_0426... OK
>>   Applying invitations.0003_auto_20151126_1523... OK
>>   Applying layers.24_initial... OK
>>   Applying services.24_initial... OK
>>   Applying services.0025_harvestjob... OK
>>   Applying services.0026_auto_20171130_0600... OK
>>   Applying services.0027_harvestjob_details... OK
>>   Applying services.0028_auto_20171201_0640... OK
>>   Applying services.0029_auto_20171203_1624... OK
>>   Applying services.0030_auto_20171212_0518... OK
>>   Applying layers.24_to_26... OK
>>   Applying layers.26_to_27... OK
>>   Applying layers.0027_auto_20170801_1228... OK
>>   Applying layers.0028_auto_20171218_0249... OK
>>   Applying layers.0029_layer_service... OK
>>   Applying layers.0030_auto_20180228_0812... OK
>>   Applying layers.0031_uploadsession_resource... OK
>>   Applying layers.0032_auto_20180424_1638... OK
>>   Applying layers.0033_auto_20180606_1543... OK
>>   Applying maps.24_initial... OK
>>   Applying maps.0025_auto_20170801_1228... OK
>>   Applying maps.0026_auto_20180301_1947... OK
>>   Applying maps.0027_auto_20180302_0430... OK
>>   Applying maps.0028_auto_20180409_1238... OK
>>   Applying maps.0029_auto_20180412_0822... OK
>>   Applying maps.0030_auto_20180414_2120... OK
>>   Applying oauth2_provider.0001_initial... OK
>>   Applying oauth2_provider.0002_08_updates... OK
>>   Applying oauth2_provider.0003_auto_20160316_1503... OK
>>   Applying oauth2_provider.0004_auto_20160525_1623... OK
>>   Applying people.0025_auto_20170924_0932... OK
>>   Applying people.0026_auto_20171120_0730... OK
>>   Applying people.0027_auto_20180414_2120... OK
>>   Applying people.0028_auto_20180606_1543... OK
>>   Applying pinax_notifications.0001_initial... OK
>>   Applying pinax_notifications.0002_auto_20171003_2006... OK
>>   Applying services.0031_auto_20180301_1947... OK
>>   Applying services.0032_auto_20180302_0430... OK
>>   Applying services.0031_service_proxy_base... OK
>>   Applying services.0033_merge... OK
>>   Applying services.0034_auto_20180309_0917... OK
>>   Applying services.0035_auto_20180327_0846... OK
>>   Applying services.0036_auto_20180331_1039... OK
>>   Applying services.0037_auto_20180409_1238... OK
>>   Applying services.0038_auto_20180412_0822... OK
>>   Applying services.0039_auto_20180414_2120... OK
>>   Applying sessions.0001_initial... OK
>>   Applying sites.0001_initial... OK
>>   Applying sites.0002_alter_domain_unique... OK
>>   Applying socialaccount.0001_initial... OK
>>   Applying socialaccount.0002_token_max_lengths... OK
>>   Applying socialaccount.0003_extra_data_default_dict... OK
>>   Applying tastypie.0001_initial... OK
>>   Applying upload.24_initial... OK
>>   Applying user_messages.0001_initial... OK
>>   Applying user_messages.0002_auto_20171107_1128... OK
>>   Applying user_messages.0003_auto_20171108_1037... OK
>>   Applying user_messages.0004_auto_20171108_1101... OK
>>  python -W ignore manage.py loaddata sample_admin.json
>> Installed 1 object(s) from 1 fixture(s)
>> geonode/base/fixtures/default_oauth_apps.json
>>   File "manage.py", line 29, in <module>
>>     execute_from_command_line(sys.argv)
>>   File
>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/management/__init__.py",
>> line 364, in execute_from_command_line
>>     utility.execute()
>>   File
>> line 356, in execute
>>     self.fetch_command(subcommand).run_from_argv(self.argv)
>>   File
>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/management/base.py",
>> line 283, in run_from_argv
>>     self.execute(*args, **cmd_options)
>>   File
>> line 330, in execute
>>     output = self.handle(*args, **options)
>>   File
>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/modeltranslation/management/commands/loaddata.py",
>> line 61, in handle
>>     return super(Command, self).handle(*fixture_labels, **options)
>>   File
>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/management/commands/loaddata.py",
>> line 69, in handle
>>     self.loaddata(fixture_labels)
>>   File
>> line 109, in loaddata
>>     self.load_label(fixture_label)
>>   File
>> line 166, in load_label
>>     for obj in objects:
>>   File
>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/serializers/json.py",
>> line 88, in Deserializer
>>     six.reraise(DeserializationError, DeserializationError(e),
>> sys.exc_info()[2])
>>   File
>> line 82, in Deserializer
>>     for obj in PythonDeserializer(objects, **options):
>>   File
>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/serializers/python.py",
>> line 129, in Deserializer
>>     field = Model._meta.get_field(field_name)
>>   File
>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/db/models/options.py",
>> line 619, in get_field
>>     raise FieldDoesNotExist("%s has no field named '%s'" %
>> (self.object_name, field_name))
>> django.core.serializers.base.DeserializationError: Problem installing
>> fixture '/srv/www/geonode/geonode/base/fixtures/default_oauth_apps.json':
>> Application has no field named 'updated'
>> Captured Task Output:
>> ---> pavement.sync
>> Build failed running pavement.sync: Subprocess return code: 1
>> Jan 25, 9:54
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3
>> <https://maps.google.com/?q=Via+di+Montramito+3&entry=gmail&source=g>/A
>> - 55054  Massarosa (LU) - Italy
>> phone: +39 0584 962313
>> fax:     +39 0584 1660272
>> mob:   +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
>> @alfa7691
>> GeoSolutions S.A.S.
>> Via di Montramito 3
>> @alfa7691
>> GeoSolutions S.A.S.
>> Via di Montramito 3
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190211/f5402786/attachment-0001.html>
More information about the geonode-users
