[GeoNode-users] Installation error 2.10 on CentOS
Federico Gianoli
alpacagis at gmail.com
Mon Feb 11 04:57:39 PST 2019
I have already tried to install it manually and the log is this:
python /tmp/geonode-oauth-toolkit/setup.py install
running install
running bdist_egg
running egg_info
writing UNKNOWN.egg-info/PKG-INFO
writing top-level names to UNKNOWN.egg-info/top_level.txt
writing dependency_links to UNKNOWN.egg-info/dependency_links.txt
reading manifest file 'UNKNOWN.egg-info/SOURCES.txt'
writing manifest file 'UNKNOWN.egg-info/SOURCES.txt'
installing library code to build/bdist.linux-x86_64/egg
running install_lib
warning: install_lib: 'build/lib' does not exist -- no Python modules to
install
creating build/bdist.linux-x86_64/egg
creating build/bdist.linux-x86_64/egg/EGG-INFO
copying UNKNOWN.egg-info/PKG-INFO -> build/bdist.linux-x86_64/egg/EGG-INFO
copying UNKNOWN.egg-info/SOURCES.txt ->
copying UNKNOWN.egg-info/dependency_links.txt ->
copying UNKNOWN.egg-info/top_level.txt ->
zip_safe flag not set; analyzing archive contents...
creating 'dist/UNKNOWN-0.0.0-py2.7.egg' and adding
'build/bdist.linux-x86_64/egg' to it
removing 'build/bdist.linux-x86_64/egg' (and everything under it)
Processing UNKNOWN-0.0.0-py2.7.egg
Removing
/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/UNKNOWN-0.0.0-py2.7.egg
Copying UNKNOWN-0.0.0-py2.7.egg to
UNKNOWN 0.0.0 is already the active version in easy-install.pth
Installed
Processing dependencies for UNKNOWN==0.0.0
Finished processing dependencies for UNKNOWN==0.0.0
Il giorno lun 11 feb 2019 alle ore 12:21 Alessio Fabiani <
alessio.fabiani at geo-solutions.it> ha scritto:
> Federico,
> from the logs it looks like the pypi package is not working correctly on
> Centos ?!? (just guessing)
> Could you mabe try to install it manually from the source code?
> https://github.com/GeoNode/geonode-oauth-toolkit
> Il giorno lun 11 feb 2019 alle ore 12:01 Federico Gianoli <
> alpacagis at gmail.com> ha scritto:
>> Ciao, this is a fresh setup on a new machine running centos
>> Il giorno lunedì 11 febbraio 2019, Alessio Fabiani <
>>> Uhm, never seen this until now.
>>> you have a previous version of the library installed on your
>>> environment? Or is this a fresh setup?
>>> Il giorno lun 11 feb 2019 alle ore 11:52 Federico Gianoli <
>>> Hi Alessio,
>>> Now we have the following error
>>> pip install geonode-oauth-toolkit --upgrade
>>> DEPRECATION: Python 2.7 will reach the end of its life on January 1st,
>>> 2020. Please upgrade your Python as Python 2.7 won't be maintained after
>>> that date. A future version of pip will drop support for Python 2.7.
>>> Collecting geonode-oauth-toolkit
>>> Installing collected packages: geonode-oauth-toolkit
>>> Exception:
>>> Traceback (most recent call last):
>>> File
>>> "/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/cli/base_command.py",
>>> line 179, in main
>>> status = self.run(options, args)
>>> File
>>> "/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/commands/install.py",
>>> line 393, in run
>>> use_user_site=options.use_user_site,
>>> File
>>> "/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/req/__init__.py",
>>> line 57, in install_given_reqs
>>> **kwargs
>>> File
>>> "/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/req/req_install.py",
>>> line 913, in install
>>> use_user_site=use_user_site, pycompile=pycompile,
>>> File
>>> line 445, in move_wheel_files
>>> warn_script_location=warn_script_location,
>>> File
>>> "/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/wheel.py",
>>> line 421, in move_wheel_files
>>> assert info_dir, "%s .dist-info directory not found" % req
>>> AssertionError: geonode-oauth-toolkit .dist-info directory not found
>>> (geonode) $
>>> Hello Federico,
>>> could you try the following command
>>> Il giorno lun 11 feb 2019 alle ore 11:02 Federico Gianoli <
>>> Thanks Alessio,
>>> Now, during the installation of geonode-oauth-toolkit>=1.1.2rc0, I have
>>> this error:
>>> Exception:
>>> File
>>> line 179, in main
>>> File
>>> line 393, in run
>>> File
>>> **kwargs
>>> File
>>> File
>>> File
>>> AssertionError: geonode-oauth-toolkit>=1.1.2rc0 .dist-info directory not
>>> found
>>> Il giorno ven 8 feb 2019 alle ore 15:10 Alessio Fabiani <
>>> Hello Federico,
>>> it looks like you have an old version of geonode-oauth-toolkit
>>> Coult you try a
>>> pip freeze | grep oauth
>>> You should get the following results:
>>> geonode-oauth-toolkit==1.1.2rc0
>>> oauthlib==2.1.0
>>> requests-oauthlib==1.0.0
>>> Il giorno ven 8 feb 2019 alle ore 11:35 Federico Gianoli <
>>> Dear all, I am trying to install GeoNode 2.10 on Centos.
>>> I am following this guide (
>>> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit
>>> <https://www.google.com/url?q=https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit&sa=D&source=hangouts&ust=1549686966108000&usg=AFQjCNFJm4OMOTuTsHR3fuPFWeZZT4cdfQ> ),
>>> everything works fine until the command paver syn that returns this error.
>>> Someone else experieced the same issue or have any suggestion to solve it?
>>> Thanks a lot
>>> paver sync
>>> ---> pavement.sync
>>> python -W ignore manage.py makemigrations --noinput
>>> No changes detected
>>> python -W ignore manage.py migrate --noinput
>>> Operations to perform:
>>> Apply all migrations: account, actstream, admin, agon_ratings,
>>> announcements, auth, avatar, base, contenttypes, dialogos, documents,
>>> geonode_client, geonode_themes, groups, guardian, invitations, layers,
>>> maps, oauth2_provider, people, pinax_notifications, services, sessions,
>>> sites, socialaccount, taggit, tastypie, upload, user_messages
>>> Running migrations:
>>> Applying contenttypes.0001_initial... OK
>>> Applying taggit.0001_initial... OK
>>> Applying taggit.0002_auto_20150616_2121... OK
>>> Applying contenttypes.0002_remove_content_type_name... OK
>>> Applying auth.0001_initial... OK
>>> Applying auth.0002_alter_permission_name_max_length... OK
>>> Applying auth.0003_alter_user_email_max_length... OK
>>> Applying auth.0004_alter_user_username_opts... OK
>>> Applying auth.0005_alter_user_last_login_null... OK
>>> Applying auth.0006_require_contenttypes_0002... OK
>>> Applying people.24_initial... OK
>>> Applying account.0001_initial... OK
>>> Applying account.0002_email_max_length... OK
>>> Applying actstream.0001_initial... OK
>>> Applying actstream.0002_remove_action_data... OK
>>> Applying admin.0001_initial... OK
>>> Applying admin.0002_logentry_remove_auto_add... OK
>>> Applying agon_ratings.0001_initial... OK
>>> Applying announcements.0001_initial... OK
>>> Applying announcements.0002_auto_20190207_1459... OK
>>> Applying auth.0007_alter_validators_add_error_messages... OK
>>> Applying auth.0008_alter_user_username_max_length... OK
>>> Applying avatar.0001_initial... OK
>>> Applying base.24_initial... OK
>>> Applying base.24_to_26... OK
>>> Applying base.26_to_27... OK
>>> Applying base.0027_auto_20170801_1228... OK
>>> Applying base.0028_resourcebase_is_approved... OK
>>> Applying base.0029_auto_20171114_0341... OK
>>> Applying base.0030_auto_20180309_0833... OK
>>> Applying base.0031_auto_20180309_0837... OK
>>> Applying base.0032_auto_20180329_1844... OK
>>> Applying base.0033_auto_20180330_0951... OK
>>> Applying base.0034_auto_20180606_1543... OK
>>> Applying base.0035_resourcebase_dirty_state... OK
>>> Applying base.0036_auto_20190207_1459... OK
>>> Applying dialogos.0001_initial... OK
>>> Applying documents.24_initial... OK
>>> Applying documents.25_add_documentresourcelink_table... OK
>>> Applying documents.26_move_data_to_documentresourcelink_table... OK
>>> Applying documents.27_drop_resource_columns_from_document_table... OK
>>> Applying documents.0028_auto_20170801_1228... OK
>>> Applying documents.0029_auto_20180301_1947... OK
>>> Applying documents.0030_auto_20180302_0430... OK
>>> Applying documents.0031_auto_20180409_1238... OK
>>> Applying documents.0032_auto_20180412_0822... OK
>>> Applying documents.0033_auto_20180414_2120... OK
>>> Applying geonode_client.0001_initial... OK
>>> Applying geonode_client.0002_auto_20180412_1039... OK
>>> Applying
>>> geonode_client.0003_geonodethemecustomization_jumbotron_welcome_hide... OK
>>> Applying geonode_client.0004_auto_20180416_1319... OK
>>> Applying geonode_client.0005_auto_20181015_1201... OK
>>> Applying geonode_themes.0001_initial... OK
>>> Applying geonode_themes.0002_auto_20181015_1208... OK
>>> Applying
>>> geonode_themes.0003_remove_geonodethemecustomization_identifier... OK
>>> Applying groups.24_initial... OK
>>> Applying groups.26_to_27... OK
>>> Applying groups.0027_auto_20180105_1631... OK
>>> Applying groups.0028_auto_20180606_1543... OK
>>> Applying guardian.0001_initial... OK
>>> Applying invitations.0001_initial... OK
>>> Applying invitations.0002_auto_20151126_0426... OK
>>> Applying invitations.0003_auto_20151126_1523... OK
>>> Applying layers.24_initial... OK
>>> Applying services.24_initial... OK
>>> Applying services.0025_harvestjob... OK
>>> Applying services.0026_auto_20171130_0600... OK
>>> Applying services.0027_harvestjob_details... OK
>>> Applying services.0028_auto_20171201_0640... OK
>>> Applying services.0029_auto_20171203_1624... OK
>>> Applying services.0030_auto_20171212_0518... OK
>>> Applying layers.24_to_26... OK
>>> Applying layers.26_to_27... OK
>>> Applying layers.0027_auto_20170801_1228... OK
>>> Applying layers.0028_auto_20171218_0249... OK
>>> Applying layers.0029_layer_service... OK
>>> Applying layers.0030_auto_20180228_0812... OK
>>> Applying layers.0031_uploadsession_resource... OK
>>> Applying layers.0032_auto_20180424_1638... OK
>>> Applying layers.0033_auto_20180606_1543... OK
>>> Applying maps.24_initial... OK
>>> Applying maps.0025_auto_20170801_1228... OK
>>> Applying maps.0026_auto_20180301_1947... OK
>>> Applying maps.0027_auto_20180302_0430... OK
>>> Applying maps.0028_auto_20180409_1238... OK
>>> Applying maps.0029_auto_20180412_0822... OK
>>> Applying maps.0030_auto_20180414_2120... OK
>>> Applying oauth2_provider.0001_initial... OK
>>> Applying oauth2_provider.0002_08_updates... OK
>>> Applying oauth2_provider.0003_auto_20160316_1503... OK
>>> Applying oauth2_provider.0004_auto_20160525_1623... OK
>>> Applying people.0025_auto_20170924_0932... OK
>>> Applying people.0026_auto_20171120_0730... OK
>>> Applying people.0027_auto_20180414_2120... OK
>>> Applying people.0028_auto_20180606_1543... OK
>>> Applying pinax_notifications.0001_initial... OK
>>> Applying pinax_notifications.0002_auto_20171003_2006... OK
>>> Applying services.0031_auto_20180301_1947... OK
>>> Applying services.0032_auto_20180302_0430... OK
>>> Applying services.0031_service_proxy_base... OK
>>> Applying services.0033_merge... OK
>>> Applying services.0034_auto_20180309_0917... OK
>>> Applying services.0035_auto_20180327_0846... OK
>>> Applying services.0036_auto_20180331_1039... OK
>>> Applying services.0037_auto_20180409_1238... OK
>>> Applying services.0038_auto_20180412_0822... OK
>>> Applying services.0039_auto_20180414_2120... OK
>>> Applying sessions.0001_initial... OK
>>> Applying sites.0001_initial... OK
>>> Applying sites.0002_alter_domain_unique... OK
>>> Applying socialaccount.0001_initial... OK
>>> Applying socialaccount.0002_token_max_lengths... OK
>>> Applying socialaccount.0003_extra_data_default_dict... OK
>>> Applying tastypie.0001_initial... OK
>>> Applying upload.24_initial... OK
>>> Applying user_messages.0001_initial... OK
>>> Applying user_messages.0002_auto_20171107_1128... OK
>>> Applying user_messages.0003_auto_20171108_1037... OK
>>> Applying user_messages.0004_auto_20171108_1101... OK
>>> python -W ignore manage.py loaddata sample_admin.json
>>> Installed 1 object(s) from 1 fixture(s)
>>> geonode/base/fixtures/default_oauth_apps.json
>>> File "manage.py", line 29, in <module>
>>> execute_from_command_line(sys.argv)
>>> File
>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/management/__init__.py",
>>> line 364, in execute_from_command_line
>>> utility.execute()
>>> File
>>> line 356, in execute
>>> self.fetch_command(subcommand).run_from_argv(self.argv)
>>> File
>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/management/base.py",
>>> line 283, in run_from_argv
>>> self.execute(*args, **cmd_options)
>>> File
>>> line 330, in execute
>>> output = self.handle(*args, **options)
>>> File
>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/modeltranslation/management/commands/loaddata.py",
>>> line 61, in handle
>>> return super(Command, self).handle(*fixture_labels, **options)
>>> File
>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/management/commands/loaddata.py",
>>> line 69, in handle
>>> self.loaddata(fixture_labels)
>>> File
>>> line 109, in loaddata
>>> self.load_label(fixture_label)
>>> File
>>> line 166, in load_label
>>> for obj in objects:
>>> File
>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/serializers/json.py",
>>> line 88, in Deserializer
>>> six.reraise(DeserializationError, DeserializationError(e),
>>> sys.exc_info()[2])
>>> File
>>> line 82, in Deserializer
>>> for obj in PythonDeserializer(objects, **options):
>>> File
>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/serializers/python.py",
>>> line 129, in Deserializer
>>> field = Model._meta.get_field(field_name)
>>> File
>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/db/models/options.py",
>>> line 619, in get_field
>>> raise FieldDoesNotExist("%s has no field named '%s'" %
>>> (self.object_name, field_name))
>>> django.core.serializers.base.DeserializationError: Problem installing
>>> fixture '/srv/www/geonode/geonode/base/fixtures/default_oauth_apps.json':
>>> Application has no field named 'updated'
>>> Captured Task Output:
>>> ---> pavement.sync
>>> Build failed running pavement.sync: Subprocess return code: 1
>>> Jan 25, 9:54
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> GeoServer Professional Services from the experts! Visit
>>> http://goo.gl/it488V for more information.
>>> Ing. Alessio Fabiani
>>> @alfa7691
>>> Founder/Technical Lead
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3
>>> <https://maps.google.com/?q=Via+di+Montramito+3&entry=gmail&source=g>/A
>>> - 55054 Massarosa (LU) - Italy
>>> phone: +39 0584 962313
>>> fax: +39 0584 1660272
>>> mob: +39 331 6233686
>>> http://www.geo-solutions.it
>>> http://twitter.com/geosolutions_it
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> precisa che ogni circostanza inerente alla presente email (il suo
>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>> This email is intended only for the person or entity to which it is
>>> addressed and may contain information that is privileged, confidential or
>>> otherwise protected from disclosure. We remind that - as provided by
>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>> e-mail or the information herein by anyone other than the intended
>>> recipient is prohibited. If you have received this email by mistake, please
>>> notify us immediately by telephone or e-mail.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3
> @alfa7691
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190211/695de726/attachment-0001.html>
More information about the geonode-users
