[GeoNode-users] Unexpected error when uploading
Alessio Fabiani alessio.fabiani at geo-solutions.it
Mon Feb 11 04:40:51 PST 2019
Does not seem to be a GeoServer <--> GeoNode issue, but just a GeoNode one
{"errors": ["Unexpected exception 'Profile' object is not iterable"],
"success": false}
Il giorno lun 11 feb 2019 alle ore 11:51 Alessio Fabiani <
alessio.fabiani at geo-solutions.it> ha scritto:
> At a first glance, GeoFence rules seem to be good to me.
> In that case it could be some REST specific security rule, which is
> strange in any case.
> Il giorno lun 11 feb 2019 alle ore 11:47 Paolo Pasquali <
> paolo.pasquali at gmail.com> ha scritto:
>> Hi all,
>> These are the GeoFence rules after uploading 3 layers:
>> [image: Screenshot 2019-02-11 at 11.45.58.png]
>> On Mon, Feb 11, 2019 at 10:51 AM Alessio Fabiani <
>> alessio.fabiani at geo-solutions.it> wrote:
>>> Dear all,
>>> I'm going to make a test also myself.
>>> From the logged report my guess is that, somehow, the GeoFence rules are
>>> not correctly set after the upload.
>>> Il giorno lun 11 feb 2019 alle ore 10:39 Dimitris Karakostis <
>>> karakostis.dimitris at gmail.com> ha scritto:
>>>> Hello Paolo,
>>>> I am not sure if this helps but, I had the same error sometime ago and
>>>> it was related to folder permissions and ownership. I fixed by assigning
>>>> the right permissions to the following folders:
>>>> $ sudo chown -Rf geonode /home/geonode/my_geonode/
>>>> $ sudo chown -Rf geonode:www-data /home/geonode/my_geonode/my_geonode/static/
>>>> $ sudo chown -Rf geonode:www-data /home/geonode/my_geonode/my_geonode/uploaded/
>>>> $ chmod -Rf 777 /home/geonode/my_geonode/my_geonode/uploaded/thumbs
>>>> $ chmod -Rf 777 /home/geonode/my_geonode/my_geonode/uploaded/layers
>>>> $ sudo chown www-data:www-data /home/geonode/my_geonode/my_geonode/static_root/
>>>> From here:
>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/setup_configure_httpd.html
>>>> On Fri, Feb 8, 2019 at 4:49 PM Paolo Pasquali <paolo.pasquali at gmail.com>
>>>> wrote:
>>>>> Dear all,
>>>>> I have installed a GeoNode 2.10.x (master) with Docker and using the
>>>>> geonode-project and following this documentation: [1]
>>>>> The issue I have is an Unespected error! when I try to upload a
>>>>> layer. So in GeoNode the layer is not present.
>>>>> But when I double check I find the layer in GeoServer with no apparent
>>>>> issue and if I run updatelayers the layer appear in the django db and of
>>>>> course in GeoNode.
>>>>> I have found these errors in the log:
>>>>> 08 Feb 15:38:06 ERROR [geoserver.rest] - No such layer:
>>>>> ne_10m_geography_regions_polys
>>>>> geoserver4fabspace | org.geoserver.rest.ResourceNotFoundException 404
>>>>> NOT_FOUND: No such layer: ne_10m_geography_regions_polys
>>>>> 08 Feb 15:38:15 ERROR [geoserver.rest] - No such style
>>>>> ne_10m_geography_regions_polys in workspace geonode
>>>>> org.geoserver.rest.ResourceNotFoundException 404 NOT_FOUND: No such
>>>>> style ne_10m_geography_regions_polys in workspace geonode
>>>>> Your help would be much appreciated.
>>>>> Thanks!
>>>>> Paolo
>>>>> [1] https://github.com/GeoNode/geonode-project#start-your-server
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> GeoServer Professional Services from the experts! Visit
>>> http://goo.gl/it488V for more information.
>>> Ing. Alessio Fabiani
>>> @alfa7691
>>> Founder/Technical Lead
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>> phone: +39 0584 962313
>>> fax:     +39 0584 1660272
>>> mob:   +39 331 6233686
>>> http://www.geo-solutions.it
>>> http://twitter.com/geosolutions_it
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> precisa che ogni circostanza inerente alla presente email (il suo
>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>> This email is intended only for the person or entity to which it is
>>> addressed and may contain information that is privileged, confidential or
>>> otherwise protected from disclosure. We remind that - as provided by
>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>> e-mail or the information herein by anyone other than the intended
>>> recipient is prohibited. If you have received this email by mistake, please
>>> notify us immediately by telephone or e-mail.
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190211/0c5e2fcb/attachment-0001.html>
Name: Screenshot 2019-02-11 at 11.45.58.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190211/0c5e2fcb/attachment-0001.png>
More information about the geonode-users mailing list
