[GeoNode-users] Unexpected error when uploading
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Mon Feb 11 04:48:19 PST 2019
Given the stacktrace below, it seems to me a regression caused by this PR
https://github.com/GeoNode/geonode/pull/4209
File "/usr/local/lib/python2.7/site-packages/haystack/signals.py", line
52, in handle_save
index.update_object(instance, using=using)
File "/usr/local/lib/python2.7/site-packages/haystack/indexes.py", line
284, in update_object
backend.update(self, [instance])
File
"/usr/local/lib/python2.7/site-packages/haystack/backends/elasticsearch_backend.py",
line 168, in update
prepped_data = index.full_prepare(obj)
208, in full_prepare
self.prepared_data = self.prepare(obj)
199, in prepare
self.prepared_data[field.index_fieldname] = field.prepare(obj)
File "/usr/local/lib/python2.7/site-packages/haystack/fields.py", line
206, in prepare
return self.convert(super(CharField, self).prepare(obj))
88, in prepare
values = self.resolve_attributes_lookup(current_objects, attrs)
115, in resolve_attributes_lookup
values.extend(self.resolve_attributes_lookup(current_objects_in_attr,
attributes[1:]))
107, in resolve_attributes_lookup
for current_object in current_objects:
File "/usr/local/lib/python2.7/site-packages/django/utils/functional.py",
line 239, in inner
return func(self._wrapped, *args)
TypeError: 'Profile' object is not iterable
Il giorno lun 11 feb 2019 alle ore 13:40 Alessio Fabiani <
alessio.fabiani at geo-solutions.it> ha scritto:
> Does not seem to be a GeoServer <--> GeoNode issue, but just a GeoNode one
> {"errors": ["Unexpected exception 'Profile' object is not iterable"],
> "success": false}
> Il giorno lun 11 feb 2019 alle ore 11:51 Alessio Fabiani <
>> At a first glance, GeoFence rules seem to be good to me.
>> In that case it could be some REST specific security rule, which is
>> strange in any case.
>> Il giorno lun 11 feb 2019 alle ore 11:47 Paolo Pasquali <
>> paolo.pasquali at gmail.com> ha scritto:
>>> Hi all,
>>> These are the GeoFence rules after uploading 3 layers:
>>> [image: Screenshot 2019-02-11 at 11.45.58.png]
>>> On Mon, Feb 11, 2019 at 10:51 AM Alessio Fabiani <
>>> alessio.fabiani at geo-solutions.it> wrote:
>>>> Dear all,
>>>> I'm going to make a test also myself.
>>>> From the logged report my guess is that, somehow, the GeoFence rules
>>>> are not correctly set after the upload.
>>>> Il giorno lun 11 feb 2019 alle ore 10:39 Dimitris Karakostis <
>>>> karakostis.dimitris at gmail.com> ha scritto:
>>>>> Hello Paolo,
>>>>> I am not sure if this helps but, I had the same error sometime ago and
>>>>> it was related to folder permissions and ownership. I fixed by assigning
>>>>> the right permissions to the following folders:
>>>>> $ sudo chown -Rf geonode /home/geonode/my_geonode/
>>>>> $ sudo chown -Rf geonode:www-data /home/geonode/my_geonode/my_geonode/static/
>>>>> $ sudo chown -Rf geonode:www-data /home/geonode/my_geonode/my_geonode/uploaded/
>>>>> $ chmod -Rf 777 /home/geonode/my_geonode/my_geonode/uploaded/thumbs
>>>>> $ chmod -Rf 777 /home/geonode/my_geonode/my_geonode/uploaded/layers
>>>>> $ sudo chown www-data:www-data /home/geonode/my_geonode/my_geonode/static_root/
>>>>> From here:
>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/setup_configure_httpd.html
>>>>> On Fri, Feb 8, 2019 at 4:49 PM Paolo Pasquali <
>>>>> paolo.pasquali at gmail.com> wrote:
>>>>>> Dear all,
>>>>>> I have installed a GeoNode 2.10.x (master) with Docker and using the
>>>>>> geonode-project and following this documentation: [1]
>>>>>> The issue I have is an Unespected error! when I try to upload a
>>>>>> layer. So in GeoNode the layer is not present.
>>>>>> But when I double check I find the layer in GeoServer with no
>>>>>> apparent issue and if I run updatelayers the layer appear in the django db
>>>>>> and of course in GeoNode.
>>>>>> I have found these errors in the log:
>>>>>> 08 Feb 15:38:06 ERROR [geoserver.rest] - No such layer:
>>>>>> ne_10m_geography_regions_polys
>>>>>> geoserver4fabspace | org.geoserver.rest.ResourceNotFoundException 404
>>>>>> NOT_FOUND: No such layer: ne_10m_geography_regions_polys
>>>>>> 08 Feb 15:38:15 ERROR [geoserver.rest] - No such style
>>>>>> ne_10m_geography_regions_polys in workspace geonode
>>>>>> org.geoserver.rest.ResourceNotFoundException 404 NOT_FOUND: No such
>>>>>> style ne_10m_geography_regions_polys in workspace geonode
>>>>>> Your help would be much appreciated.
>>>>>> Thanks!
>>>>>> Paolo
>>>>>> [1] https://github.com/GeoNode/geonode-project#start-your-server
>>>>>> _______________________________________________
>>>>>> geonode-users mailing list
>>>>>> geonode-users at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>> GeoServer Professional Services from the experts! Visit
>>>> http://goo.gl/it488V for more information.
>>>> Ing. Alessio Fabiani
>>>> @alfa7691
>>>> Founder/Technical Lead
>>>> GeoSolutions S.A.S.
>>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>>> phone: +39 0584 962313
>>>> fax: +39 0584 1660272
>>>> mob: +39 331 6233686
>>>> http://www.geo-solutions.it
>>>> http://twitter.com/geosolutions_it
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>>> precisa che ogni circostanza inerente alla presente email (il suo
>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>> This email is intended only for the person or entity to which it is
>>>> addressed and may contain information that is privileged, confidential or
>>>> otherwise protected from disclosure. We remind that - as provided by
>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>> e-mail or the information herein by anyone other than the intended
>>>> recipient is prohibited. If you have received this email by mistake, please
>>>> notify us immediately by telephone or e-mail.
>> @alfa7691
>> GeoSolutions S.A.S.
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190211/e478a21c/attachment-0001.html>
Name: Screenshot 2019-02-11 at 11.45.58.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190211/e478a21c/attachment-0001.png>
More information about the geonode-users
