[GeoNode-users] Installation error 2.10 on CentOS
Federico Gianoli
alpacagis at gmail.com
Mon Feb 11 05:15:21 PST 2019
This is the result :-/
pip install -e .
Obtaining file:///tmp/geonode-oauth-toolkit
Installing collected packages: UNKNOWN
Found existing installation: UNKNOWN 0.0.0
Uninstalling UNKNOWN-0.0.0:
Successfully uninstalled UNKNOWN-0.0.0
Running setup.py develop for UNKNOWN
Successfully installed UNKNOWN
File "/bin/pip", line 9, in <module>
load_entry_point('pip==19.0.2', 'console_scripts', 'pip')()
File "/usr/lib/python2.7/site-packages/pip/_internal/__init__.py", line
78, in main
return command.main(cmd_args)
File
"/usr/lib/python2.7/site-packages/pip/_internal/cli/base_command.py", line
228, in main
timeout=min(5, options.timeout)
File
93, in _build_session
insecure_hosts=options.trusted_hosts,
File "/usr/lib/python2.7/site-packages/pip/_internal/download.py", line
344, in __init__
self.headers["User-Agent"] = user_agent()
134, in user_agent
setuptools_version = get_installed_version("setuptools")
File "/usr/lib/python2.7/site-packages/pip/_internal/utils/misc.py", line
902, in get_installed_version
working_set = pkg_resources.WorkingSet()
File
"/usr/lib/python2.7/site-packages/pip/_vendor/pkg_resources/__init__.py",
line 565, in __init__
self.add_entry(entry)
File
line 621, in add_entry
for dist in find_distributions(entry, True):
File
line 1886, in find_eggs_in_zip
if metadata.has_metadata('PKG-INFO'):
File
line 1405, in has_metadata
return self.egg_info and self._has(self._fn(self.egg_info, name))
File
line 1760, in _has
return zip_path in self.zipinfo or zip_path in self._index()
File
line 1637, in zipinfo
return self._zip_manifests.load(self.loader.archive)
File
line 1594, in load
mtime = os.stat(path).st_mtime
OSError: [Errno 2] No such file or directory:
'/usr/lib/python2.7/site-packages/UNKNOWN-0.0.0-py2.7.egg'
*From:* Federico Gianoli <gianoli.federico at gmail.com>
*Sent:* 11 February 2019 14:07
[Messaggio troncato] Visualizza intero messaggio
<https://mail.google.com/mail/u/0?ui=2&ik=b344d072b8&view=lg&permmsgid=msg-f%3A1625178261382153937&ser=1>
Il giorno lun 11 feb 2019 alle ore 14:01 Alessio Fabiani <
alessio.fabiani at geo-solutions.it> ha scritto:
> what about
> cd /tmp/geonode-oauth-toolkit/
> pip install -e .
> I also would try to cleanup completely the python/lib paths of geonode-oauth-toolkit
> under the Env
> Il giorno lun 11 feb 2019 alle ore 13:57 Federico Gianoli <
> alpacagis at gmail.com> ha scritto:
>> I have already tried to install it manually and the log is this:
>> python /tmp/geonode-oauth-toolkit/setup.py install
>> running install
>> running bdist_egg
>> running egg_info
>> writing UNKNOWN.egg-info/PKG-INFO
>> writing top-level names to UNKNOWN.egg-info/top_level.txt
>> writing dependency_links to UNKNOWN.egg-info/dependency_links.txt
>> reading manifest file 'UNKNOWN.egg-info/SOURCES.txt'
>> writing manifest file 'UNKNOWN.egg-info/SOURCES.txt'
>> installing library code to build/bdist.linux-x86_64/egg
>> running install_lib
>> warning: install_lib: 'build/lib' does not exist -- no Python modules to
>> install
>> creating build/bdist.linux-x86_64/egg
>> creating build/bdist.linux-x86_64/egg/EGG-INFO
>> copying UNKNOWN.egg-info/PKG-INFO -> build/bdist.linux-x86_64/egg/EGG-INFO
>> copying UNKNOWN.egg-info/SOURCES.txt ->
>> copying UNKNOWN.egg-info/dependency_links.txt ->
>> copying UNKNOWN.egg-info/top_level.txt ->
>> zip_safe flag not set; analyzing archive contents...
>> creating 'dist/UNKNOWN-0.0.0-py2.7.egg' and adding
>> 'build/bdist.linux-x86_64/egg' to it
>> removing 'build/bdist.linux-x86_64/egg' (and everything under it)
>> Processing UNKNOWN-0.0.0-py2.7.egg
>> Removing
>> /srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/UNKNOWN-0.0.0-py2.7.egg
>> Copying UNKNOWN-0.0.0-py2.7.egg to
>> UNKNOWN 0.0.0 is already the active version in easy-install.pth
>> Installed
>> Processing dependencies for UNKNOWN==0.0.0
>> Finished processing dependencies for UNKNOWN==0.0.0
>> Il giorno lun 11 feb 2019 alle ore 12:21 Alessio Fabiani <
>>> Federico,
>>> from the logs it looks like the pypi package is not working correctly on
>>> Centos ?!? (just guessing)
>>> Could you mabe try to install it manually from the source code?
>>> https://github.com/GeoNode/geonode-oauth-toolkit
>>> Il giorno lun 11 feb 2019 alle ore 12:01 Federico Gianoli <
>>>> Ciao, this is a fresh setup on a new machine running centos
>>>> Il giorno lunedì 11 febbraio 2019, Alessio Fabiani <
>>>>> Uhm, never seen this until now.
>>>>> you have a previous version of the library installed on your
>>>>> environment? Or is this a fresh setup?
>>>>> Il giorno lun 11 feb 2019 alle ore 11:52 Federico Gianoli <
>>>>> Hi Alessio,
>>>>> Now we have the following error
>>>>> pip install geonode-oauth-toolkit --upgrade
>>>>> DEPRECATION: Python 2.7 will reach the end of its life on January 1st,
>>>>> 2020. Please upgrade your Python as Python 2.7 won't be maintained after
>>>>> that date. A future version of pip will drop support for Python 2.7.
>>>>> Collecting geonode-oauth-toolkit
>>>>> Installing collected packages: geonode-oauth-toolkit
>>>>> Exception:
>>>>> File
>>>>> "/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/cli/base_command.py",
>>>>> line 179, in main
>>>>> status = self.run(options, args)
>>>>> File
>>>>> "/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/commands/install.py",
>>>>> line 393, in run
>>>>> use_user_site=options.use_user_site,
>>>>> File
>>>>> "/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/req/__init__.py",
>>>>> line 57, in install_given_reqs
>>>>> **kwargs
>>>>> File
>>>>> "/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/req/req_install.py",
>>>>> line 913, in install
>>>>> use_user_site=use_user_site, pycompile=pycompile,
>>>>> File
>>>>> line 445, in move_wheel_files
>>>>> warn_script_location=warn_script_location,
>>>>> File
>>>>> "/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/wheel.py",
>>>>> line 421, in move_wheel_files
>>>>> assert info_dir, "%s .dist-info directory not found" % req
>>>>> AssertionError: geonode-oauth-toolkit .dist-info directory not found
>>>>> (geonode) $
>>>>> Hello Federico,
>>>>> could you try the following command
>>>>> Il giorno lun 11 feb 2019 alle ore 11:02 Federico Gianoli <
>>>>> Thanks Alessio,
>>>>> Now, during the installation of geonode-oauth-toolkit>=1.1.2rc0, I
>>>>> have this error:
>>>>> Exception:
>>>>> File
>>>>> line 179, in main
>>>>> File
>>>>> line 393, in run
>>>>> File
>>>>> **kwargs
>>>>> File
>>>>> File
>>>>> File
>>>>> AssertionError: geonode-oauth-toolkit>=1.1.2rc0 .dist-info directory
>>>>> not found
>>>>> Il giorno ven 8 feb 2019 alle ore 15:10 Alessio Fabiani <
>>>>> Hello Federico,
>>>>> it looks like you have an old version of geonode-oauth-toolkit
>>>>> Coult you try a
>>>>> pip freeze | grep oauth
>>>>> You should get the following results:
>>>>> geonode-oauth-toolkit==1.1.2rc0
>>>>> oauthlib==2.1.0
>>>>> requests-oauthlib==1.0.0
>>>>> Il giorno ven 8 feb 2019 alle ore 11:35 Federico Gianoli <
>>>>> Dear all, I am trying to install GeoNode 2.10 on Centos.
>>>>> I am following this guide (
>>>>> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit
>>>>> <https://www.google.com/url?q=https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit&sa=D&source=hangouts&ust=1549686966108000&usg=AFQjCNFJm4OMOTuTsHR3fuPFWeZZT4cdfQ> ),
>>>>> everything works fine until the command paver syn that returns this error.
>>>>> Someone else experieced the same issue or have any suggestion to solve it?
>>>>> Thanks a lot
>>>>> paver sync
>>>>> ---> pavement.sync
>>>>> python -W ignore manage.py makemigrations --noinput
>>>>> No changes detected
>>>>> python -W ignore manage.py migrate --noinput
>>>>> Operations to perform:
>>>>> Apply all migrations: account, actstream, admin, agon_ratings,
>>>>> announcements, auth, avatar, base, contenttypes, dialogos, documents,
>>>>> geonode_client, geonode_themes, groups, guardian, invitations, layers,
>>>>> maps, oauth2_provider, people, pinax_notifications, services, sessions,
>>>>> sites, socialaccount, taggit, tastypie, upload, user_messages
>>>>> Running migrations:
>>>>> Applying contenttypes.0001_initial... OK
>>>>> Applying taggit.0001_initial... OK
>>>>> Applying taggit.0002_auto_20150616_2121... OK
>>>>> Applying contenttypes.0002_remove_content_type_name... OK
>>>>> Applying auth.0001_initial... OK
>>>>> Applying auth.0002_alter_permission_name_max_length... OK
>>>>> Applying auth.0003_alter_user_email_max_length... OK
>>>>> Applying auth.0004_alter_user_username_opts... OK
>>>>> Applying auth.0005_alter_user_last_login_null... OK
>>>>> Applying auth.0006_require_contenttypes_0002... OK
>>>>> Applying people.24_initial... OK
>>>>> Applying account.0001_initial... OK
>>>>> Applying account.0002_email_max_length... OK
>>>>> Applying actstream.0001_initial... OK
>>>>> Applying actstream.0002_remove_action_data... OK
>>>>> Applying admin.0001_initial... OK
>>>>> Applying admin.0002_logentry_remove_auto_add... OK
>>>>> Applying agon_ratings.0001_initial... OK
>>>>> Applying announcements.0001_initial... OK
>>>>> Applying announcements.0002_auto_20190207_1459... OK
>>>>> Applying auth.0007_alter_validators_add_error_messages... OK
>>>>> Applying auth.0008_alter_user_username_max_length... OK
>>>>> Applying avatar.0001_initial... OK
>>>>> Applying base.24_initial... OK
>>>>> Applying base.24_to_26... OK
>>>>> Applying base.26_to_27... OK
>>>>> Applying base.0027_auto_20170801_1228... OK
>>>>> Applying base.0028_resourcebase_is_approved... OK
>>>>> Applying base.0029_auto_20171114_0341... OK
>>>>> Applying base.0030_auto_20180309_0833... OK
>>>>> Applying base.0031_auto_20180309_0837... OK
>>>>> Applying base.0032_auto_20180329_1844... OK
>>>>> Applying base.0033_auto_20180330_0951... OK
>>>>> Applying base.0034_auto_20180606_1543... OK
>>>>> Applying base.0035_resourcebase_dirty_state... OK
>>>>> Applying base.0036_auto_20190207_1459... OK
>>>>> Applying dialogos.0001_initial... OK
>>>>> Applying documents.24_initial... OK
>>>>> Applying documents.25_add_documentresourcelink_table... OK
>>>>> Applying documents.26_move_data_to_documentresourcelink_table... OK
>>>>> Applying documents.27_drop_resource_columns_from_document_table... OK
>>>>> Applying documents.0028_auto_20170801_1228... OK
>>>>> Applying documents.0029_auto_20180301_1947... OK
>>>>> Applying documents.0030_auto_20180302_0430... OK
>>>>> Applying documents.0031_auto_20180409_1238... OK
>>>>> Applying documents.0032_auto_20180412_0822... OK
>>>>> Applying documents.0033_auto_20180414_2120... OK
>>>>> Applying geonode_client.0001_initial... OK
>>>>> Applying geonode_client.0002_auto_20180412_1039... OK
>>>>> Applying
>>>>> geonode_client.0003_geonodethemecustomization_jumbotron_welcome_hide... OK
>>>>> Applying geonode_client.0004_auto_20180416_1319... OK
>>>>> Applying geonode_client.0005_auto_20181015_1201... OK
>>>>> Applying geonode_themes.0001_initial... OK
>>>>> Applying geonode_themes.0002_auto_20181015_1208... OK
>>>>> Applying
>>>>> geonode_themes.0003_remove_geonodethemecustomization_identifier... OK
>>>>> Applying groups.24_initial... OK
>>>>> Applying groups.26_to_27... OK
>>>>> Applying groups.0027_auto_20180105_1631... OK
>>>>> Applying groups.0028_auto_20180606_1543... OK
>>>>> Applying guardian.0001_initial... OK
>>>>> Applying invitations.0001_initial... OK
>>>>> Applying invitations.0002_auto_20151126_0426... OK
>>>>> Applying invitations.0003_auto_20151126_1523... OK
>>>>> Applying layers.24_initial... OK
>>>>> Applying services.24_initial... OK
>>>>> Applying services.0025_harvestjob... OK
>>>>> Applying services.0026_auto_20171130_0600... OK
>>>>> Applying services.0027_harvestjob_details... OK
>>>>> Applying services.0028_auto_20171201_0640... OK
>>>>> Applying services.0029_auto_20171203_1624... OK
>>>>> Applying services.0030_auto_20171212_0518... OK
>>>>> Applying layers.24_to_26... OK
>>>>> Applying layers.26_to_27... OK
>>>>> Applying layers.0027_auto_20170801_1228... OK
>>>>> Applying layers.0028_auto_20171218_0249... OK
>>>>> Applying layers.0029_layer_service... OK
>>>>> Applying layers.0030_auto_20180228_0812... OK
>>>>> Applying layers.0031_uploadsession_resource... OK
>>>>> Applying layers.0032_auto_20180424_1638... OK
>>>>> Applying layers.0033_auto_20180606_1543... OK
>>>>> Applying maps.24_initial... OK
>>>>> Applying maps.0025_auto_20170801_1228... OK
>>>>> Applying maps.0026_auto_20180301_1947... OK
>>>>> Applying maps.0027_auto_20180302_0430... OK
>>>>> Applying maps.0028_auto_20180409_1238... OK
>>>>> Applying maps.0029_auto_20180412_0822... OK
>>>>> Applying maps.0030_auto_20180414_2120... OK
>>>>> Applying oauth2_provider.0001_initial... OK
>>>>> Applying oauth2_provider.0002_08_updates... OK
>>>>> Applying oauth2_provider.0003_auto_20160316_1503... OK
>>>>> Applying oauth2_provider.0004_auto_20160525_1623... OK
>>>>> Applying people.0025_auto_20170924_0932... OK
>>>>> Applying people.0026_auto_20171120_0730... OK
>>>>> Applying people.0027_auto_20180414_2120... OK
>>>>> Applying people.0028_auto_20180606_1543... OK
>>>>> Applying pinax_notifications.0001_initial... OK
>>>>> Applying pinax_notifications.0002_auto_20171003_2006... OK
>>>>> Applying services.0031_auto_20180301_1947... OK
>>>>> Applying services.0032_auto_20180302_0430... OK
>>>>> Applying services.0031_service_proxy_base... OK
>>>>> Applying services.0033_merge... OK
>>>>> Applying services.0034_auto_20180309_0917... OK
>>>>> Applying services.0035_auto_20180327_0846... OK
>>>>> Applying services.0036_auto_20180331_1039... OK
>>>>> Applying services.0037_auto_20180409_1238... OK
>>>>> Applying services.0038_auto_20180412_0822... OK
>>>>> Applying services.0039_auto_20180414_2120... OK
>>>>> Applying sessions.0001_initial... OK
>>>>> Applying sites.0001_initial... OK
>>>>> Applying sites.0002_alter_domain_unique... OK
>>>>> Applying socialaccount.0001_initial... OK
>>>>> Applying socialaccount.0002_token_max_lengths... OK
>>>>> Applying socialaccount.0003_extra_data_default_dict... OK
>>>>> Applying tastypie.0001_initial... OK
>>>>> Applying upload.24_initial... OK
>>>>> Applying user_messages.0001_initial... OK
>>>>> Applying user_messages.0002_auto_20171107_1128... OK
>>>>> Applying user_messages.0003_auto_20171108_1037... OK
>>>>> Applying user_messages.0004_auto_20171108_1101... OK
>>>>> python -W ignore manage.py loaddata sample_admin.json
>>>>> Installed 1 object(s) from 1 fixture(s)
>>>>> geonode/base/fixtures/default_oauth_apps.json
>>>>> File "manage.py", line 29, in <module>
>>>>> execute_from_command_line(sys.argv)
>>>>> File
>>>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/management/__init__.py",
>>>>> line 364, in execute_from_command_line
>>>>> utility.execute()
>>>>> File
>>>>> line 356, in execute
>>>>> self.fetch_command(subcommand).run_from_argv(self.argv)
>>>>> File
>>>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/management/base.py",
>>>>> line 283, in run_from_argv
>>>>> self.execute(*args, **cmd_options)
>>>>> File
>>>>> line 330, in execute
>>>>> output = self.handle(*args, **options)
>>>>> File
>>>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/modeltranslation/management/commands/loaddata.py",
>>>>> line 61, in handle
>>>>> return super(Command, self).handle(*fixture_labels, **options)
>>>>> File
>>>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/management/commands/loaddata.py",
>>>>> line 69, in handle
>>>>> self.loaddata(fixture_labels)
>>>>> File
>>>>> line 109, in loaddata
>>>>> self.load_label(fixture_label)
>>>>> File
>>>>> line 166, in load_label
>>>>> for obj in objects:
>>>>> File
>>>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/serializers/json.py",
>>>>> line 88, in Deserializer
>>>>> six.reraise(DeserializationError, DeserializationError(e),
>>>>> sys.exc_info()[2])
>>>>> File
>>>>> line 82, in Deserializer
>>>>> for obj in PythonDeserializer(objects, **options):
>>>>> File
>>>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/serializers/python.py",
>>>>> line 129, in Deserializer
>>>>> field = Model._meta.get_field(field_name)
>>>>> File
>>>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/db/models/options.py",
>>>>> line 619, in get_field
>>>>> raise FieldDoesNotExist("%s has no field named '%s'" %
>>>>> (self.object_name, field_name))
>>>>> django.core.serializers.base.DeserializationError: Problem installing
>>>>> fixture '/srv/www/geonode/geonode/base/fixtures/default_oauth_apps.json':
>>>>> Application has no field named 'updated'
>>>>> Captured Task Output:
>>>>> ---> pavement.sync
>>>>> Build failed running pavement.sync: Subprocess return code: 1
>>>>> Jan 25, 9:54
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>> GeoServer Professional Services from the experts! Visit
>>>>> http://goo.gl/it488V for more information.
>>>>> Ing. Alessio Fabiani
>>>>> @alfa7691
>>>>> Founder/Technical Lead
>>>>> GeoSolutions S.A.S.
>>>>> Via di Montramito 3
>>>>> <https://maps.google.com/?q=Via+di+Montramito+3&entry=gmail&source=g>/A
>>>>> - 55054 Massarosa (LU) - Italy
>>>>> phone: +39 0584 962313
>>>>> fax: +39 0584 1660272
>>>>> mob: +39 331 6233686
>>>>> http://www.geo-solutions.it
>>>>> http://twitter.com/geosolutions_it
>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>> This email is intended only for the person or entity to which it is
>>>>> addressed and may contain information that is privileged, confidential or
>>>>> otherwise protected from disclosure. We remind that - as provided by
>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>> e-mail or the information herein by anyone other than the intended
>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>> notify us immediately by telephone or e-mail.
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>>>> Via di Montramito 3
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>>>> Via di Montramito 3
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190211/7057a59b/attachment-0001.html>
More information about the geonode-users
