[GeoNode-users] Installation error 2.10 on CentOS
Alessio Fabiani alessio.fabiani at geo-solutions.it
Mon Feb 11 05:20:40 PST 2019
I'll try to take some time to double check. It seems clear that there's
some error on the package definition.
Il giorno lun 11 feb 2019 alle ore 14:15 Federico Gianoli <
alpacagis at gmail.com> ha scritto:
> This is the result :-/
> pip install -e .
> Obtaining file:///tmp/geonode-oauth-toolkit
> Installing collected packages: UNKNOWN
>   Found existing installation: UNKNOWN 0.0.0
>     Uninstalling UNKNOWN-0.0.0:
>       Successfully uninstalled UNKNOWN-0.0.0
>   Running setup.py develop for UNKNOWN
> Successfully installed UNKNOWN
> Traceback (most recent call last):
>   File "/bin/pip", line 9, in <module>
>     load_entry_point('pip==19.0.2', 'console_scripts', 'pip')()
>   File "/usr/lib/python2.7/site-packages/pip/_internal/__init__.py", line
> 78, in main
>     return command.main(cmd_args)
>   File
> "/usr/lib/python2.7/site-packages/pip/_internal/cli/base_command.py", line
> 228, in main
>     timeout=min(5, options.timeout)
>   File
> 93, in _build_session
>     insecure_hosts=options.trusted_hosts,
>   File "/usr/lib/python2.7/site-packages/pip/_internal/download.py", line
> 344, in __init__
>     self.headers["User-Agent"] = user_agent()
> 134, in user_agent
>     setuptools_version = get_installed_version("setuptools")
>   File "/usr/lib/python2.7/site-packages/pip/_internal/utils/misc.py",
> line 902, in get_installed_version
>     working_set = pkg_resources.WorkingSet()
>   File
> "/usr/lib/python2.7/site-packages/pip/_vendor/pkg_resources/__init__.py",
> line 565, in __init__
>     self.add_entry(entry)
>   File
> line 621, in add_entry
>     for dist in find_distributions(entry, True):
>   File
> line 1886, in find_eggs_in_zip
>     if metadata.has_metadata('PKG-INFO'):
>   File
> line 1405, in has_metadata
>     return self.egg_info and self._has(self._fn(self.egg_info, name))
>   File
> line 1760, in _has
>     return zip_path in self.zipinfo or zip_path in self._index()
>   File
> line 1637, in zipinfo
>     return self._zip_manifests.load(self.loader.archive)
>   File
> line 1594, in load
>     mtime = os.stat(path).st_mtime
> OSError: [Errno 2] No such file or directory:
> '/usr/lib/python2.7/site-packages/UNKNOWN-0.0.0-py2.7.egg'
> *From:* Federico Gianoli <gianoli.federico at gmail.com>
> *Sent:* 11 February 2019 14:07
> [Messaggio troncato]  Visualizza intero messaggio
> <https://mail.google.com/mail/u/0?ui=2&ik=b344d072b8&view=lg&permmsgid=msg-f%3A1625178261382153937&ser=1>
> Il giorno lun 11 feb 2019 alle ore 14:01 Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> ha scritto:
>> what about
>> cd /tmp/geonode-oauth-toolkit/
>> pip install -e .
>> I also would try to cleanup completely the python/lib paths of geonode-oauth-toolkit
>> under the Env
>> Il giorno lun 11 feb 2019 alle ore 13:57 Federico Gianoli <
>>> I have already tried to install it manually and the log is this:
>>> python /tmp/geonode-oauth-toolkit/setup.py install
>>> running install
>>> running bdist_egg
>>> running egg_info
>>> writing UNKNOWN.egg-info/PKG-INFO
>>> writing top-level names to UNKNOWN.egg-info/top_level.txt
>>> writing dependency_links to UNKNOWN.egg-info/dependency_links.txt
>>> reading manifest file 'UNKNOWN.egg-info/SOURCES.txt'
>>> writing manifest file 'UNKNOWN.egg-info/SOURCES.txt'
>>> installing library code to build/bdist.linux-x86_64/egg
>>> running install_lib
>>> warning: install_lib: 'build/lib' does not exist -- no Python modules to
>>> install
>>> creating build/bdist.linux-x86_64/egg
>>> creating build/bdist.linux-x86_64/egg/EGG-INFO
>>> copying UNKNOWN.egg-info/PKG-INFO ->
>>> copying UNKNOWN.egg-info/SOURCES.txt ->
>>> copying UNKNOWN.egg-info/dependency_links.txt ->
>>> copying UNKNOWN.egg-info/top_level.txt ->
>>> zip_safe flag not set; analyzing archive contents...
>>> creating 'dist/UNKNOWN-0.0.0-py2.7.egg' and adding
>>> 'build/bdist.linux-x86_64/egg' to it
>>> removing 'build/bdist.linux-x86_64/egg' (and everything under it)
>>> Processing UNKNOWN-0.0.0-py2.7.egg
>>> Removing
>>> /srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/UNKNOWN-0.0.0-py2.7.egg
>>> Copying UNKNOWN-0.0.0-py2.7.egg to
>>> UNKNOWN 0.0.0 is already the active version in easy-install.pth
>>> Installed
>>> Processing dependencies for UNKNOWN==0.0.0
>>> Finished processing dependencies for UNKNOWN==0.0.0
>>> Il giorno lun 11 feb 2019 alle ore 12:21 Alessio Fabiani <
>>>> Federico,
>>>> from the logs it looks like the pypi package is not working correctly
>>>> on Centos ?!? (just guessing)
>>>> Could you mabe try to install it manually from the source code?
>>>> https://github.com/GeoNode/geonode-oauth-toolkit
>>>> Il giorno lun 11 feb 2019 alle ore 12:01 Federico Gianoli <
>>>>> Ciao, this is a fresh setup on a new machine running centos
>>>>> Il giorno lunedì 11 febbraio 2019, Alessio Fabiani <
>>>>>> Uhm, never seen this until now.
>>>>>>  you have a previous version of the library installed on your
>>>>>> environment? Or is this a fresh setup?
>>>>>> Il giorno lun 11 feb 2019 alle ore 11:52 Federico Gianoli <
>>>>>> Hi Alessio,
>>>>>> Now we have the following error
>>>>>> pip install geonode-oauth-toolkit --upgrade
>>>>>> DEPRECATION: Python 2.7 will reach the end of its life on January
>>>>>> 1st, 2020. Please upgrade your Python as Python 2.7 won't be maintained
>>>>>> after that date. A future version of pip will drop support for Python 2.7.
>>>>>> Collecting geonode-oauth-toolkit
>>>>>> Installing collected packages: geonode-oauth-toolkit
>>>>>> Exception:
>>>>>>   File
>>>>>> "/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/cli/base_command.py",
>>>>>> line 179, in main
>>>>>>     status = self.run(options, args)
>>>>>>   File
>>>>>> "/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/commands/install.py",
>>>>>> line 393, in run
>>>>>>     use_user_site=options.use_user_site,
>>>>>>   File
>>>>>> "/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/req/__init__.py",
>>>>>> line 57, in install_given_reqs
>>>>>>     **kwargs
>>>>>>   File
>>>>>> "/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/req/req_install.py",
>>>>>> line 913, in install
>>>>>>     use_user_site=use_user_site, pycompile=pycompile,
>>>>>>   File
>>>>>> line 445, in move_wheel_files
>>>>>>     warn_script_location=warn_script_location,
>>>>>>   File
>>>>>> "/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/wheel.py",
>>>>>> line 421, in move_wheel_files
>>>>>>     assert info_dir, "%s .dist-info directory not found" % req
>>>>>> AssertionError: geonode-oauth-toolkit .dist-info directory not found
>>>>>> (geonode) $
>>>>>> Hello Federico,
>>>>>> could you try the following command
>>>>>> Il giorno lun 11 feb 2019 alle ore 11:02 Federico Gianoli <
>>>>>> Thanks Alessio,
>>>>>> Now, during the installation of geonode-oauth-toolkit>=1.1.2rc0,  I
>>>>>> have this error:
>>>>>> Exception:
>>>>>>   File
>>>>>> line 179, in main
>>>>>>   File
>>>>>> line 393, in run
>>>>>>   File
>>>>>>     **kwargs
>>>>>>   File
>>>>>>   File
>>>>>>   File
>>>>>> AssertionError: geonode-oauth-toolkit>=1.1.2rc0 .dist-info directory
>>>>>> not found
>>>>>> Il giorno ven 8 feb 2019 alle ore 15:10 Alessio Fabiani <
>>>>>> Hello Federico,
>>>>>> it looks like you have an old version of geonode-oauth-toolkit
>>>>>> Coult you try a
>>>>>> pip freeze | grep oauth
>>>>>> You should get the following results:
>>>>>> geonode-oauth-toolkit==1.1.2rc0
>>>>>> oauthlib==2.1.0
>>>>>> requests-oauthlib==1.0.0
>>>>>> Il giorno ven 8 feb 2019 alle ore 11:35 Federico Gianoli <
>>>>>> Dear all, I am trying to install GeoNode 2.10 on Centos.
>>>>>> I am following this guide (
>>>>>> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit
>>>>>> <https://www.google.com/url?q=https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit&sa=D&source=hangouts&ust=1549686966108000&usg=AFQjCNFJm4OMOTuTsHR3fuPFWeZZT4cdfQ> ),
>>>>>> everything works fine until the command paver syn that returns this error.
>>>>>> Someone else experieced the same issue or have any suggestion to solve it?
>>>>>> Thanks a lot
>>>>>> paver sync
>>>>>> ---> pavement.sync
>>>>>>  python -W ignore manage.py makemigrations --noinput
>>>>>> No changes detected
>>>>>>  python -W ignore manage.py migrate --noinput
>>>>>> Operations to perform:
>>>>>>   Apply all migrations: account, actstream, admin, agon_ratings,
>>>>>> announcements, auth, avatar, base, contenttypes, dialogos, documents,
>>>>>> geonode_client, geonode_themes, groups, guardian, invitations, layers,
>>>>>> maps, oauth2_provider, people, pinax_notifications, services, sessions,
>>>>>> sites, socialaccount, taggit, tastypie, upload, user_messages
>>>>>> Running migrations:
>>>>>>   Applying contenttypes.0001_initial... OK
>>>>>>   Applying taggit.0001_initial... OK
>>>>>>   Applying taggit.0002_auto_20150616_2121... OK
>>>>>>   Applying contenttypes.0002_remove_content_type_name... OK
>>>>>>   Applying auth.0001_initial... OK
>>>>>>   Applying auth.0002_alter_permission_name_max_length... OK
>>>>>>   Applying auth.0003_alter_user_email_max_length... OK
>>>>>>   Applying auth.0004_alter_user_username_opts... OK
>>>>>>   Applying auth.0005_alter_user_last_login_null... OK
>>>>>>   Applying auth.0006_require_contenttypes_0002... OK
>>>>>>   Applying people.24_initial... OK
>>>>>>   Applying account.0001_initial... OK
>>>>>>   Applying account.0002_email_max_length... OK
>>>>>>   Applying actstream.0001_initial... OK
>>>>>>   Applying actstream.0002_remove_action_data... OK
>>>>>>   Applying admin.0001_initial... OK
>>>>>>   Applying admin.0002_logentry_remove_auto_add... OK
>>>>>>   Applying agon_ratings.0001_initial... OK
>>>>>>   Applying announcements.0001_initial... OK
>>>>>>   Applying announcements.0002_auto_20190207_1459... OK
>>>>>>   Applying auth.0007_alter_validators_add_error_messages... OK
>>>>>>   Applying auth.0008_alter_user_username_max_length... OK
>>>>>>   Applying avatar.0001_initial... OK
>>>>>>   Applying base.24_initial... OK
>>>>>>   Applying base.24_to_26... OK
>>>>>>   Applying base.26_to_27... OK
>>>>>>   Applying base.0027_auto_20170801_1228... OK
>>>>>>   Applying base.0028_resourcebase_is_approved... OK
>>>>>>   Applying base.0029_auto_20171114_0341... OK
>>>>>>   Applying base.0030_auto_20180309_0833... OK
>>>>>>   Applying base.0031_auto_20180309_0837... OK
>>>>>>   Applying base.0032_auto_20180329_1844... OK
>>>>>>   Applying base.0033_auto_20180330_0951... OK
>>>>>>   Applying base.0034_auto_20180606_1543... OK
>>>>>>   Applying base.0035_resourcebase_dirty_state... OK
>>>>>>   Applying base.0036_auto_20190207_1459... OK
>>>>>>   Applying dialogos.0001_initial... OK
>>>>>>   Applying documents.24_initial... OK
>>>>>>   Applying documents.25_add_documentresourcelink_table... OK
>>>>>>   Applying documents.26_move_data_to_documentresourcelink_table... OK
>>>>>>   Applying documents.27_drop_resource_columns_from_document_table...
>>>>>> OK
>>>>>>   Applying documents.0028_auto_20170801_1228... OK
>>>>>>   Applying documents.0029_auto_20180301_1947... OK
>>>>>>   Applying documents.0030_auto_20180302_0430... OK
>>>>>>   Applying documents.0031_auto_20180409_1238... OK
>>>>>>   Applying documents.0032_auto_20180412_0822... OK
>>>>>>   Applying documents.0033_auto_20180414_2120... OK
>>>>>>   Applying geonode_client.0001_initial... OK
>>>>>>   Applying geonode_client.0002_auto_20180412_1039... OK
>>>>>>   Applying
>>>>>> geonode_client.0003_geonodethemecustomization_jumbotron_welcome_hide... OK
>>>>>>   Applying geonode_client.0004_auto_20180416_1319... OK
>>>>>>   Applying geonode_client.0005_auto_20181015_1201... OK
>>>>>>   Applying geonode_themes.0001_initial... OK
>>>>>>   Applying geonode_themes.0002_auto_20181015_1208... OK
>>>>>>   Applying
>>>>>> geonode_themes.0003_remove_geonodethemecustomization_identifier... OK
>>>>>>   Applying groups.24_initial... OK
>>>>>>   Applying groups.26_to_27... OK
>>>>>>   Applying groups.0027_auto_20180105_1631... OK
>>>>>>   Applying groups.0028_auto_20180606_1543... OK
>>>>>>   Applying guardian.0001_initial... OK
>>>>>>   Applying invitations.0001_initial... OK
>>>>>>   Applying invitations.0002_auto_20151126_0426... OK
>>>>>>   Applying invitations.0003_auto_20151126_1523... OK
>>>>>>   Applying layers.24_initial... OK
>>>>>>   Applying services.24_initial... OK
>>>>>>   Applying services.0025_harvestjob... OK
>>>>>>   Applying services.0026_auto_20171130_0600... OK
>>>>>>   Applying services.0027_harvestjob_details... OK
>>>>>>   Applying services.0028_auto_20171201_0640... OK
>>>>>>   Applying services.0029_auto_20171203_1624... OK
>>>>>>   Applying services.0030_auto_20171212_0518... OK
>>>>>>   Applying layers.24_to_26... OK
>>>>>>   Applying layers.26_to_27... OK
>>>>>>   Applying layers.0027_auto_20170801_1228... OK
>>>>>>   Applying layers.0028_auto_20171218_0249... OK
>>>>>>   Applying layers.0029_layer_service... OK
>>>>>>   Applying layers.0030_auto_20180228_0812... OK
>>>>>>   Applying layers.0031_uploadsession_resource... OK
>>>>>>   Applying layers.0032_auto_20180424_1638... OK
>>>>>>   Applying layers.0033_auto_20180606_1543... OK
>>>>>>   Applying maps.24_initial... OK
>>>>>>   Applying maps.0025_auto_20170801_1228... OK
>>>>>>   Applying maps.0026_auto_20180301_1947... OK
>>>>>>   Applying maps.0027_auto_20180302_0430... OK
>>>>>>   Applying maps.0028_auto_20180409_1238... OK
>>>>>>   Applying maps.0029_auto_20180412_0822... OK
>>>>>>   Applying maps.0030_auto_20180414_2120... OK
>>>>>>   Applying oauth2_provider.0001_initial... OK
>>>>>>   Applying oauth2_provider.0002_08_updates... OK
>>>>>>   Applying oauth2_provider.0003_auto_20160316_1503... OK
>>>>>>   Applying oauth2_provider.0004_auto_20160525_1623... OK
>>>>>>   Applying people.0025_auto_20170924_0932... OK
>>>>>>   Applying people.0026_auto_20171120_0730... OK
>>>>>>   Applying people.0027_auto_20180414_2120... OK
>>>>>>   Applying people.0028_auto_20180606_1543... OK
>>>>>>   Applying pinax_notifications.0001_initial... OK
>>>>>>   Applying pinax_notifications.0002_auto_20171003_2006... OK
>>>>>>   Applying services.0031_auto_20180301_1947... OK
>>>>>>   Applying services.0032_auto_20180302_0430... OK
>>>>>>   Applying services.0031_service_proxy_base... OK
>>>>>>   Applying services.0033_merge... OK
>>>>>>   Applying services.0034_auto_20180309_0917... OK
>>>>>>   Applying services.0035_auto_20180327_0846... OK
>>>>>>   Applying services.0036_auto_20180331_1039... OK
>>>>>>   Applying services.0037_auto_20180409_1238... OK
>>>>>>   Applying services.0038_auto_20180412_0822... OK
>>>>>>   Applying services.0039_auto_20180414_2120... OK
>>>>>>   Applying sessions.0001_initial... OK
>>>>>>   Applying sites.0001_initial... OK
>>>>>>   Applying sites.0002_alter_domain_unique... OK
>>>>>>   Applying socialaccount.0001_initial... OK
>>>>>>   Applying socialaccount.0002_token_max_lengths... OK
>>>>>>   Applying socialaccount.0003_extra_data_default_dict... OK
>>>>>>   Applying tastypie.0001_initial... OK
>>>>>>   Applying upload.24_initial... OK
>>>>>>   Applying user_messages.0001_initial... OK
>>>>>>   Applying user_messages.0002_auto_20171107_1128... OK
>>>>>>   Applying user_messages.0003_auto_20171108_1037... OK
>>>>>>   Applying user_messages.0004_auto_20171108_1101... OK
>>>>>>  python -W ignore manage.py loaddata sample_admin.json
>>>>>> Installed 1 object(s) from 1 fixture(s)
>>>>>> geonode/base/fixtures/default_oauth_apps.json
>>>>>>   File "manage.py", line 29, in <module>
>>>>>>     execute_from_command_line(sys.argv)
>>>>>>   File
>>>>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/management/__init__.py",
>>>>>> line 364, in execute_from_command_line
>>>>>>     utility.execute()
>>>>>>   File
>>>>>> line 356, in execute
>>>>>>     self.fetch_command(subcommand).run_from_argv(self.argv)
>>>>>>   File
>>>>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/management/base.py",
>>>>>> line 283, in run_from_argv
>>>>>>     self.execute(*args, **cmd_options)
>>>>>>   File
>>>>>> line 330, in execute
>>>>>>     output = self.handle(*args, **options)
>>>>>>   File
>>>>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/modeltranslation/management/commands/loaddata.py",
>>>>>> line 61, in handle
>>>>>>     return super(Command, self).handle(*fixture_labels, **options)
>>>>>>   File
>>>>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/management/commands/loaddata.py",
>>>>>> line 69, in handle
>>>>>>     self.loaddata(fixture_labels)
>>>>>>   File
>>>>>> line 109, in loaddata
>>>>>>     self.load_label(fixture_label)
>>>>>>   File
>>>>>> line 166, in load_label
>>>>>>     for obj in objects:
>>>>>>   File
>>>>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/serializers/json.py",
>>>>>> line 88, in Deserializer
>>>>>>     six.reraise(DeserializationError, DeserializationError(e),
>>>>>> sys.exc_info()[2])
>>>>>>   File
>>>>>> line 82, in Deserializer
>>>>>>     for obj in PythonDeserializer(objects, **options):
>>>>>>   File
>>>>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/serializers/python.py",
>>>>>> line 129, in Deserializer
>>>>>>     field = Model._meta.get_field(field_name)
>>>>>>   File
>>>>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/db/models/options.py",
>>>>>> line 619, in get_field
>>>>>>     raise FieldDoesNotExist("%s has no field named '%s'" %
>>>>>> (self.object_name, field_name))
>>>>>> django.core.serializers.base.DeserializationError: Problem installing
>>>>>> fixture '/srv/www/geonode/geonode/base/fixtures/default_oauth_apps.json':
>>>>>> Application has no field named 'updated'
>>>>>> Captured Task Output:
>>>>>> ---> pavement.sync
>>>>>> Build failed running pavement.sync: Subprocess return code: 1
>>>>>> Jan 25, 9:54
>>>>>> _______________________________________________
>>>>>> geonode-users mailing list
>>>>>> geonode-users at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>> http://goo.gl/it488V for more information.
>>>>>> Ing. Alessio Fabiani
>>>>>> @alfa7691
>>>>>> Founder/Technical Lead
>>>>>> GeoSolutions S.A.S.
>>>>>> Via di Montramito 3
>>>>>> <https://maps.google.com/?q=Via+di+Montramito+3&entry=gmail&source=g>/A
>>>>>> - 55054  Massarosa (LU) - Italy
>>>>>> phone: +39 0584 962313
>>>>>> fax:     +39 0584 1660272
>>>>>> mob:   +39 331 6233686
>>>>>> http://www.geo-solutions.it
>>>>>> http://twitter.com/geosolutions_it
>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>>> This email is intended only for the person or entity to which it is
>>>>>> addressed and may contain information that is privileged, confidential or
>>>>>> otherwise protected from disclosure. We remind that - as provided by
>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>>> e-mail or the information herein by anyone other than the intended
>>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>>> notify us immediately by telephone or e-mail.
>>>>>> @alfa7691
>>>>>> GeoSolutions S.A.S.
>>>>>> Via di Montramito 3
>>>>>> @alfa7691
>>>>>> GeoSolutions S.A.S.
>>>>>> Via di Montramito 3
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> @alfa7691
>> GeoSolutions S.A.S.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190211/c0301402/attachment-0001.html>
More information about the geonode-users mailing list
