[GeoNode-users] Adding a XYZ basemap to GeoExplorer
Paolo Pasquali paolo.pasquali at gmail.com
Tue Feb 19 00:16:46 PST 2019
Hi Stefan,
The service responds to
https://htonl.dev.openstreetmap.org/ngi-tiles/tiles/50k/${z}/${x}/${y}.png
But if I set it as a TMS instead of a XYZ GeoExplorer builds the following
URL
https://htonl.dev.openstreetmap.org/ngi-tiles/tiles/1.0.0/50k/${z}/${x}/${y}.png
I can have the correct "y" but cannot remove the service version in the URL.
Best,
Paolo
On Mon, Feb 18, 2019 at 9:39 PM Stefan Steiniger <ssteiniger at uc.cl> wrote:
> Hi Paolo,
> Why woyld you have negative tile ids? This does not make sense to me that
> a tile service would not account for it. Did you check the standard?
> Perhaps this link helps? https://wiki.openstreetmap.org/wiki/TMS
> Cheers,
> Stefan
> On Mon, Feb 18, 2019, 13:49 Alessio Fabiani <alessio.fabiani at gmail.com
> wrote:
>> Hi Paolo,
>> I'm afraid you will need to create a custom ptype, similar to OSM as an
>> instance, which is able to correctly parse and create urls for this
>> particular use case.
>> Il giorno lun 18 feb 2019 alle ore 17:28 Paolo Pasquali <
>> paolo.pasquali at gmail.com> ha scritto:
>>> Dear all,
>>> I understand this is more a GeoExplorer matter but maybe you can help...
>>> I would like to add a XYZ layer as a basemap so I've changed my settings
>>> accordingly.
>>> The problem is that I cannot solve the z/x/y url pattern, in particular
>>> I should have (my guess, since the tiles goes on the other side of the
>>> equator) a negative y. Here is my settings:
>>>     "source": {"ptype": "gxp_olsource"},
>>>     "type": "OpenLayers.Layer.XYZ",
>>>     "title": "CD:NGI Topo",
>>>     "args": ["CD:NGI Topo", "
>>> https://htonl.dev.openstreetmap.org/ngi-tiles/tiles/50k/${z}/${x}/${-y}.png
>>>     "name": "background",
>>>     "attribution": "State Copyright © 1996–2013 <a href=\"
>>> http://www.ngi.gov.za\">Chief Directorate: National Geo-spatial
>>> Information</a>",
>>>     "visibility": False,
>>>     "wrapDateLine": True,
>>>     "fixed": True,
>>>     "group":"background"
>>> Unfortunately, OpenLayers (or GeoExplorer) cannot solve the -y because I
>>> get this for a tile:
>>> https://htonl.dev.openstreetmap.org/ngi-tiles/tiles/50k/5/17/$%7B-y%7D.png
>>> Is there a way to handle this? I've also tried with
>>> OpenLayers.Layer.OSM but had the same result.
>>> Thanks in advance for your help.
>>> Best,
>>> Paolo
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190219/63a0635c/attachment.html>
More information about the geonode-users mailing list
