[GeoNode-users] Is it possible to have a library of reusable styles
Peter Thiem peterthiem at gmail.com
Thu Feb 21 17:59:39 PST 2019
Looks great Alessio, thanks!
I've been using version "Powered by GeoNode version 2.10rc4", checked out
from github/master on 15/2/2019, and built using the docker instructions.
Should be a recent version, most likely I just am not doing (and don't
understand) the right thing to set up a reusable style.
>  I'd suggest waiting a bit until we release a new GIS client for GeoNode.
Any guess when this would be? In any case, i hope to have only a light or
zero customisation instance of geonode, so that it will be easier to
upgrade, so I may be able to proceed with the current version, then upgrade
upon the release of a new version.
Cheers.
On Thu, 21 Feb 2019 at 19:53, Alessio Fabiani <alessio.fabiani at gmail.com>
wrote:
> Dear Peter,
> which version of GeoNode you are currently using? The issue you describe
> seems to be related to a quite old version of it.
> About your questions, I'd suggest waiting a bit until we release a new GIS
> client for GeoNode [1] which should fulfill your requirements.
> Here below few screenshots on how it looks and the zoom levels (it can
> zoom up to 1:2)
> [image: image.png]
> [image: image.png]
> [image: image.png]
> [image: image.png]
> [1] -
> https://github.com/geosolutions-it/geonode-mapstore-client#geonode-client---
> *WARNING: Only working on GeoNode 2.10+*
> Il giorno gio 21 feb 2019 alle ore 01:13 Peter Thiem <peterthiem at gmail.com>
> ha scritto:
>> Hi Geonode users,
>> I'm considering using geonode to store and share and visualise large
>> number of farm plot maps for a research farm.
>> Each layer for a research study would have a number of attributes for
>> each farm plot collected during the experiment (i.e. fertiziler amount,
>> moisture, seek yield, plant height, etc).
>> I'm thinking to use a different style for each type of attribute, that
>> could be associated with the layer depending the attributes that layer has,
>> and the user can choose between the associated styles.
>> In my attempts to get them to work, i create styles in the geonode admin
>> interface, but then they seem to get deleted automatically if they are not
>> associated with a layer.
>> And to really get the layer setup and working, i seem to need to create
>> it in geoserver and in geonode.
>> I'm not sure i understand how Geonode manages styles and intends for
>> users to operate them.
>> Questions.
>> Is it possible and sensible to have a library of styles that can be
>> shared between maps? Why or why not?
>> Or are styles really meant to be associated with a single layer (rather
>> than as a library)?
>> If so, how would I set them up, properly?
>> Is there a better approach to making it easier for the users to visualise
>> different attributes in each layer?
>> Cheers, Peter.
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190222/b7a7b98b/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190222/b7a7b98b/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190222/b7a7b98b/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190222/b7a7b98b/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190222/b7a7b98b/attachment-0007.png>
More information about the geonode-users mailing list
