[GeoNode-users] Unexpected error when uploading
Andres Juarez
albertoandres.juarez at gmail.com
Mon Feb 25 03:46:46 PST 2019
hi francesco
Exactly, that's how it worked.
Thank you
El sáb., 23 feb. 2019 a las 22:01, Francesco Bartoli (<xbartolone at gmail.com>)
escribió:
> Can you try with this?
> docker-compose down -v
> docker-compose up -d —build
> Il 24 feb 2019, 01:17 +0100, Andres Juarez <albertoandres.juarez at gmail.com>,
> ha scritto:
> Hello everyone
> I have the same problem but I can not apply the change, and the loading of
> layers continues without working.
> I rebuilt Geonode with
> docker-compose stop
> docker-compose up -d --build
> Is this the right way? or in what way should I rebuild it?
> Thanks in advance
> El mar., 12 feb. 2019 a las 9:38, Paolo Pasquali (<
> paolo.pasquali at gmail.com>) escribió:
>> I can confirm the issue is not occurring anymore.
>> Thank you all for your help.
>> Ciao
>> P.
>> On Mon, Feb 11, 2019 at 10:00 PM Paolo Pasquali <paolo.pasquali at gmail.com>
>> wrote:
>>> Thank you so much.
>>> Tomorrow I’ll try it.
>>> Ciao
>>> P.
>>> On 11 Feb 2019, 20:21 +0100, Francesco Bartoli <xbartolone at gmail.com>,
>>> wrote:
>>> Paolo,
>>> with the last revert on geonode repo the issue looks like solved for the
>>> upload, I’m still seeing the 404 errors on layer and style from geoserver
>>> log though.
>>> @Alessio do you think it is worth to keep these errors traced?
>>> Il 11 feb 2019, 14:25 +0100, G. Allegri <
>>> giovanni.allegri at geo-solutions.it>, ha scritto:
>>> I would like to dig into this more because haystack supports related
>>> data, even if "preparing" the data (or denormalizing them) is suggested.
>>> The issue aslo highlights that some tests for haystack should be added.
>>> Giovanni
>>> Il giorno lun 11 feb 2019 alle ore 14:00 Francesco Bartoli <
>>> xbartolone at gmail.com> ha scritto:
>>>> What can we do? I’d go with reverting it and asking the developer to
>>>> come up with a solution. This is gone to block geonode-project at all
>>>> Il 11 feb 2019, 13:48 +0100, Alessio Fabiani <
>>>> alessio.fabiani at geo-solutions.it>, ha scritto:
>>>> Given the stacktrace below, it seems to me a regression caused by this
>>>> PR
>>>> https://github.com/GeoNode/geonode/pull/4209
>>>> File "/usr/local/lib/python2.7/site-packages/haystack/signals.py",
>>>> line 52, in handle_save
>>>> index.update_object(instance, using=using)
>>>> File "/usr/local/lib/python2.7/site-packages/haystack/indexes.py",
>>>> line 284, in update_object
>>>> backend.update(self, [instance])
>>>> File
>>>> "/usr/local/lib/python2.7/site-packages/haystack/backends/elasticsearch_backend.py",
>>>> line 168, in update
>>>> prepped_data = index.full_prepare(obj)
>>>> line 208, in full_prepare
>>>> self.prepared_data = self.prepare(obj)
>>>> line 199, in prepare
>>>> self.prepared_data[field.index_fieldname] = field.prepare(obj)
>>>> File "/usr/local/lib/python2.7/site-packages/haystack/fields.py",
>>>> line 206, in prepare
>>>> return self.convert(super(CharField, self).prepare(obj))
>>>> line 88, in prepare
>>>> values = self.resolve_attributes_lookup(current_objects, attrs)
>>>> line 115, in resolve_attributes_lookup
>>>> values.extend(self.resolve_attributes_lookup(current_objects_in_attr,
>>>> attributes[1:]))
>>>> line 107, in resolve_attributes_lookup
>>>> for current_object in current_objects:
>>>> File
>>>> "/usr/local/lib/python2.7/site-packages/django/utils/functional.py", line
>>>> 239, in inner
>>>> return func(self._wrapped, *args)
>>>> TypeError: 'Profile' object is not iterable
>>>> Il giorno lun 11 feb 2019 alle ore 13:40 Alessio Fabiani <
>>>> alessio.fabiani at geo-solutions.it> ha scritto:
>>>>> Does not seem to be a GeoServer <--> GeoNode issue, but just a GeoNode
>>>>> one
>>>>> {"errors": ["Unexpected exception 'Profile' object is not iterable"],
>>>>> "success": false}
>>>>> Il giorno lun 11 feb 2019 alle ore 11:51 Alessio Fabiani <
>>>>>> At a first glance, GeoFence rules seem to be good to me.
>>>>>> In that case it could be some REST specific security rule, which is
>>>>>> strange in any case.
>>>>>> Il giorno lun 11 feb 2019 alle ore 11:47 Paolo Pasquali <
>>>>>> paolo.pasquali at gmail.com> ha scritto:
>>>>>>> Hi all,
>>>>>>> These are the GeoFence rules after uploading 3 layers:
>>>>>>> <Screenshot 2019-02-11 at 11.45.58.png>
>>>>>>> On Mon, Feb 11, 2019 at 10:51 AM Alessio Fabiani <
>>>>>>> alessio.fabiani at geo-solutions.it> wrote:
>>>>>>>> Dear all,
>>>>>>>> I'm going to make a test also myself.
>>>>>>>> From the logged report my guess is that, somehow, the GeoFence
>>>>>>>> rules are not correctly set after the upload.
>>>>>>>> Il giorno lun 11 feb 2019 alle ore 10:39 Dimitris Karakostis <
>>>>>>>> karakostis.dimitris at gmail.com> ha scritto:
>>>>>>>>> Hello Paolo,
>>>>>>>>> I am not sure if this helps but, I had the same error sometime ago
>>>>>>>>> and it was related to folder permissions and ownership. I fixed by
>>>>>>>>> assigning the right permissions to the following folders:
>>>>>>>>> $ sudo chown -Rf geonode /home/geonode/my_geonode/
>>>>>>>>> $ sudo chown -Rf geonode:www-data /home/geonode/my_geonode/my_geonode/static/
>>>>>>>>> $ sudo chown -Rf geonode:www-data /home/geonode/my_geonode/my_geonode/uploaded/
>>>>>>>>> $ chmod -Rf 777 /home/geonode/my_geonode/my_geonode/uploaded/thumbs
>>>>>>>>> $ chmod -Rf 777 /home/geonode/my_geonode/my_geonode/uploaded/layers
>>>>>>>>> $ sudo chown www-data:www-data /home/geonode/my_geonode/my_geonode/static_root/
>>>>>>>>> From here:
>>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/setup_configure_httpd.html
>>>>>>>>> On Fri, Feb 8, 2019 at 4:49 PM Paolo Pasquali <
>>>>>>>>> paolo.pasquali at gmail.com> wrote:
>>>>>>>>>> Dear all,
>>>>>>>>>> I have installed a GeoNode 2.10.x (master) with Docker and using
>>>>>>>>>> the geonode-project and following this documentation: [1]
>>>>>>>>>> The issue I have is an Unespected error! when I try to upload a
>>>>>>>>>> layer. So in GeoNode the layer is not present.
>>>>>>>>>> But when I double check I find the layer in GeoServer with no
>>>>>>>>>> apparent issue and if I run updatelayers the layer appear in the django db
>>>>>>>>>> and of course in GeoNode.
>>>>>>>>>> I have found these errors in the log:
>>>>>>>>>> 08 Feb 15:38:06 ERROR [geoserver.rest] - No such layer:
>>>>>>>>>> ne_10m_geography_regions_polys
>>>>>>>>>> geoserver4fabspace | org.geoserver.rest.ResourceNotFoundException
>>>>>>>>>> 404 NOT_FOUND: No such layer: ne_10m_geography_regions_polys
>>>>>>>>>> 08 Feb 15:38:15 ERROR [geoserver.rest] - No such style
>>>>>>>>>> ne_10m_geography_regions_polys in workspace geonode
>>>>>>>>>> org.geoserver.rest.ResourceNotFoundException 404 NOT_FOUND: No
>>>>>>>>>> such style ne_10m_geography_regions_polys in workspace geonode
>>>>>>>>>> Your help would be much appreciated.
>>>>>>>>>> Thanks!
>>>>>>>>>> Paolo
>>>>>>>>>> [1] https://github.com/GeoNode/geonode-project#start-your-server
>>>>>>>>>> _______________________________________________
>>>>>>>>>> geonode-users mailing list
>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>>> http://goo.gl/it488V for more information.
>>>>>>>> Ing. Alessio Fabiani
>>>>>>>> @alfa7691
>>>>>>>> Founder/Technical Lead
>>>>>>>> GeoSolutions S.A.S.
>>>>>>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>>>>>>> phone: +39 0584 962313
>>>>>>>> fax: +39 0584 1660272
>>>>>>>> mob: +39 331 6233686
>>>>>>>> http://www.geo-solutions.it
>>>>>>>> http://twitter.com/geosolutions_it
>>>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>>>>> This email is intended only for the person or entity to which it is
>>>>>>>> addressed and may contain information that is privileged, confidential or
>>>>>>>> otherwise protected from disclosure. We remind that - as provided by
>>>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>>>>> e-mail or the information herein by anyone other than the intended
>>>>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>>>>> notify us immediately by telephone or e-mail.
>>>>>> @alfa7691
>>>>>> GeoSolutions S.A.S.
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> Giovanni Allegri
>>> GeoSolutions S.A.S.
>>> <https://maps.google.com/?q=Via+di+Montramito+3/A%0D+55054+%C2%A0Massarosa&entry=gmail&source=g>
>>> 55054 Massarosa
>>> (LU)
>>> Italy
>>> phone: +39 0584 962313 <+39%200584%20962313>
>>> fax: +39 0584 1660272 <+39%200584%20166%200272>
> Andrés Juarez
Andrés Juarez
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190225/526c614a/attachment-0001.html>
More information about the geonode-users
