[GeoNode-users] GeoNode-Project local_settings
Julierme Pinheiro
juliermeopensourcedeveloper at gmail.com
Thu Jan 10 06:34:21 PST 2019
Hi Toni,
Thank you very much for your reply and wishes.
Everything works fine, if I set wsgi.py to settings and do not make a copy
of local_settings.py.sample as local_settings.py. That is how I got here:
http://192.241.135.159/
However, if I set wsgi.py to settings (default configuration) and make a
copy of local_settings.py.sample as local_settings.py. The celery and
django container error remains:
celery4my_geonode | SITEURL = os.getenv('SITEURL', "http://%s:%s/" %
(SITE_HOST_NAME, SITE_HOST_PORT))
celery4my_geonode | NameError: name 'SITE_HOST_NAME' is not defined
django4my_geonode | SITEURL = os.getenv('SITEURL', "http://%s:%s/" %
django4my_geonode | NameError: name 'SITE_HOST_NAME' is not defined
The reason I am changing the wsgi.py to local_settings when using
local_settings.py is because there is a note on the guide
<https://github.com/GeoNode/geonode-project/tree/2.8> that it says:
*Remember to update "wsgi.py" in case you are using "local_settings" vim
my_geonode/wsgi.py --> os.environ.setdefault("DJANGO_SETTINGS_MODULE",
"my_geonode.local_settings")*
Anyway, using local_settings.py and configuring wsgi.py to either
"my_geonode.settings" or "my_geonode.local_settings", celery and django
container will not go up and the log file will return:
If you consider that an issue, I will post it on github.
Kind regards and thank you mery much for your patience
Julierme
On Thu, Jan 10, 2019 at 10:46 AM Toni Schönbuchner <
toni.schoenbuchner at csgis.de> wrote:
> Hey Julierme,
> first of all the same to you. All the best for 2019.
> Docker sets some env vars where I do not have a complete
> overview. Other might guide you better here.
> But look at settings.py:
> https://github.com/GeoNode/geonode-project/blob/master/project_name/settings.py#L27
> it includes local_settings ...
> So, what happens if you leave wsgi.py untouched (pointing to settings.py),
> rename
> local_settings.py.sample to local_settings.py (already happend) and make
> your changes
> there (local_settings). F.e. setup your smtp account or base layers etc.
> Does this help?
> Cheers,
> Toni
> CSGIS
> Kolonnadenstraße 1
> 04109 Leipzig
> Mobil +49/ (0) 176 6680 3198
> Tel +49/ (0) 341 24 04 738
> Fax +49/ (0) 341 24 04 73
> Web http://csgis.de
> Hinweis gemäß § 33 BDSG
> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
> ausschließlich für den
> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
> diese E-Mail versehentlich
> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
> löschen Sie diese Nachricht
> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
> Vervielfältigung, Veränderung,
> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
> Am 10.01.2019 um 13:33 schrieb Julierme Pinheiro <
> juliermeopensourcedeveloper at gmail.com>:
> Hi Toni,
> Thank you very much for your reply.
> Find bellow the site working with wsgi.py configured to settings
> Now, going back to the issue related to wsgi.py configured to
> local_settings:
> Yes, checking the logs, I found out that there is an issue with SITEURL.
> Please see bellow:
> SITE_HOST_NAME is defined after SITEURL. *I changed from*:
> SITEURL = os.getenv('SITEURL', "http://%s:%s/" % (SITE_HOST_NAME,
> SITE_HOST_PORT))
> # we need hostname for deployed
> _surl = urlparse(SITEURL)
> HOSTNAME = _surl.hostname
> # per-deployment settings should go here
> SITE_HOST_NAME = os.getenv('SITE_HOST_NAME', HOSTNAME)
> SITE_HOST_PORT = os.getenv('SITE_HOST_PORT', "80")
> *To: *
> #SITEURL = os.getenv('SITEURL', "http://%s:%s/" % (SITE_HOST_NAME,
> SITE_HOST_PORT))
> #_surl = urlparse(SITEURL)
> #HOSTNAME = _surl.hostname
> SITE_HOST_NAME = os.getenv('SITE_HOST_NAME', "172.21.5.187")
> SITE_HOST_PORT))
> But the django4my_geonode and celery4my_geonode container error remains
> the same:
> I appreciated your time and by the way, Happy 2019 for you all. I wish you
> all health and success in all life projects.
> Kind regards
> Julierme
> On Wed, Jan 9, 2019 at 6:18 PM Toni Schönbuchner <
>> Hey Julierme,
>> have you checked the output of logs?
>> $ docker-compose logs -f
>> or
>> $ docker-compose logs -f django
>> or
>> $ docker-compose logs -f celery
>> Cheers,
>> Toni
>> > Message: 1
>> > Date: Wed, 9 Jan 2019 11:27:59 -0200
>> > From: Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com>
>> > To: geonode-users <geonode-users at lists.osgeo.org>
>> > Subject: [GeoNode-users] GeoNode-Project local_settings
>> > Message-ID:
>> > <CAKTKyJJ_6KV9d=
>> zikW9SAj6bybDCD+p8-XT7OuDZL7QxGxVVzw at mail.gmail.com>
>> > Content-Type: text/plain; charset="utf-8"
>> > Dear all,
>> > I am running an Ubuntu 18.04 LTS VM. I am trying to install
>> > GeoNode-Project at 2.8 via Docker following the instructions in here.
>> > By changing wsgi.py to local_settings, celery4my_geonode and
>> > django4my_geonode won't start and I am always getting the *502 Bad
>> Gateway*
>> > response in the browser.
>> > Has anyone faced the same issue and could guide me on how to solve it?
>> > Thank you for your time in advance
>> > Regards
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190110/cd5e5700/attachment.html>
More information about the geonode-users
