[GeoNode-users] GWC doesn't work normaly for GeoExt client on docker Geonode 2.10 master
    Alessio Fabiani
    alessio.fabiani at geo-solutions.it
    Wed Jan 30 00:46:41 PST 2019
Hello Dejan,
can you please convert this into an issue on github?
Il giorno lun 28 gen 2019 alle ore 16:37 Dejan Samardzic <
dejan.samardzic at cedis.me> ha scritto:
> Dear Geonode community,
> We have made docker Gonode 2.10 master branch installation on Ubuntu 18.04
> by Alessio's guide:
> https://docs.google.com/document/d/1S0ac9IR9IW9tUjMu7JETPLUjnfQ6P87m1PKNko8IPWY/edit
> after that we have configure GeoWebCache:
> 1) We have configure Caching to external postgresql database:
> Tile caching - Disk quota....Enable disk Quota ....Maximum tile cache size
> 50GiB
> Disk quota check frequency:600s
> Disk quota store type....External database
> Target database type....PostgreSQL
> JDBC data source...GeoServer managed connection pool
> JDBC Driver class name.....org.postgresql.Driver
> JDBC connection URL.....jdbc:postgresql://db:5432/geonode
> User name.....geonode
> Password.....****
> Validation query.....select 1
> 2) Define path for cache
> From geoserver container:
> mkdir /var/cache/geoserver
> chmod -R 777 geoserver
> vi /usr/local/tomcat/webapps/geoserver/WEB-INF/web.xml
> insert :
> <context-param>
>        <param-name>GEOWEBCACHE_CACHE_DIR</param-name>
>        <param-value>/var/cache/geoserver/</param-value>
> </context-param>
> Now, GeoWebCache doesn't work (geowebcache-cache-result is always MISS and
> system is not generating png files in GEOWEBCACHE_CACHE_DIR).
> We have to remove/add that specitic layer in Geoserver->Tile Caching->Tile
> Layers. After that, GWC start working normally (geowebcache-cache-result is
> HIT and system start generating png files in GEOWEBCACHE_CACHE_DIR).
> Let me underline that before and after this remove/add actions, url on
> browser's Developer Tool has the same structure like:
> http://testgis.cedis.me/geoserver/ows?access_token=pNPeKSZxG60GgtYcUJ97RCMKKGuIXm&LAYERS=geonode%3Anovi_r5_Grbalj_3_10kV_izmjenjen&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A3857&BBOX=2088259.6124603,5217897.2981329,2088565.3605734,5218203.046246&WIDTH=256&HEIGHT=256
> Please watch for yourself:
> https://www.youtube.com/watch?v=4Y0KIBOowDM
> Regards,
> Dejan.
> * Dejan Samardžić* Rukovodilac Sektora za ICT / IT Manager
> CEDIS d.o.o.
> Ivana Milutinovića 12, 81000 Podgorica
> gsm: +382 67 220 971
> tel: +382 20 408 453
> email: dejan.samardzic at cedis.me
> web: www.cedis.me
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190130/d3f045df/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190130/d3f045df/attachment.jpg>
More information about the geonode-users
