[GeoNode-users] The "gsconfig" module thing!
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Wed Jul 10 00:38:22 PDT 2019
Dear GeoNode devs, users,
as you might already know, GeoNode relies on a python library, started by
boundless several years ago, called "gsconfig", which basically handles
almost all the APIs communication with GeoServer.
Currently, the library seems to be abandoned and messed up.
There are tentatives to make it compliant with Python 3, but the code is
full of errors and they do not accept PRs anymore.
With the latest versions of GeoServer, we need to update some API calls.
Moreover, very soon, we will need to make this fundamental library
compliant with Python 3.
Probably the easiest way would be to fork this library and create a
"gsconfig3" or something hosted by the GeoNode github repo.
Any thoughts? Comments or feedbacks?
Alessio.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190710/85d9dfa3/attachment.html>
More information about the geonode-users
