[GeoNode-users] Wrong encoding after uploading shapefile (shp)
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Fri Jul 12 01:54:25 PDT 2019
Thank you very much.
Il giorno ven 12 lug 2019 alle ore 10:53 Athanasios Fotis <tfotis at draxis.gr>
ha scritto:
> Hi,
> Issue created https://github.com/GeoNode/geonode/issues/4635
> If you need further information for solving this, please let me know.
> Thank you again for your support
> Thanasis
> On Fri, 12 Jul 2019 at 10:38, Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> P.S.: in the meantime, I would ask if you could create an issue on the
>> GeoNode GitHub issue tracker reporting the problem. That would be
>> very helpful to keep track of our discussions.
>> Il giorno ven 12 lug 2019 alle ore 09:36 Alessio Fabiani <
>> alessio.fabiani at geo-solutions.it> ha scritto:
>>> Hi Athanasios,
>>> we are already investigating on this issue.
>>> It seems like the GeoServer Importer already supports charset encoding,
>>> so, in case this is confirmed, we will have to update the GeoNode APIs in
>>> order to correctly set the charset when creating the session.
>>> Hopefully in a week or so we will be able to fix this.
>>> Il giorno ven 12 lug 2019 alle ore 09:20 Athanasios Fotis <
>>> tfotis at draxis.gr> ha scritto:
>>>> Hi Alessio,
>>>> Perfect. That worked. Thank you!
>>>> So, is this is a known issue with Geoserver's importer plugin? Should i
>>>> send them an email in their list or create an issue in their tracker?
>>>> Best,
>>>> Thanasis
>>>> On Thu, 11 Jul 2019 at 17:41, Alessio Fabiani <
>>>>> Hi Athanasios,
>>>>> try maybe to change the UPLOADER method back to REST, it seems like
>>>>> the GeoServer Importer has some issues with the character encoding
>>>>> http://osgeo-org.1560.x6.nabble.com/JIRA-GEOS-9073-Encoding-issues-with-the-importer-plugin-td5389529.html
>>>>> In order to set the uploader method to geoserver.rest you can either
>>>>> set the environment variable
>>>>> DEFAULT_BACKEND_UPLOADER=geonode.rest
>>>>> Or override the UPLOADER setting in your settings file
>>>>> UPLOADER = {
>>>>> 'BACKEND': 'geonode.rest',
>>>>> 'OPTIONS': {
>>>>> 'TIME_ENABLED': False,
>>>>> 'MOSAIC_ENABLED': False,
>>>>> 'SUPPORTED_CRS': [
>>>>> 'EPSG:4326',
>>>>> 'EPSG:3785',
>>>>> 'EPSG:3857',
>>>>> 'EPSG:32647',
>>>>> 'EPSG:32736'
>>>>> 'SUPPORTED_EXT': [
>>>>> '.shp',
>>>>> '.csv',
>>>>> '.kml',
>>>>> '.kmz',
>>>>> '.json',
>>>>> '.geojson',
>>>>> '.tif',
>>>>> '.tiff',
>>>>> '.geotiff',
>>>>> '.gml',
>>>>> '.xml'
>>>>> Il giorno gio 11 lug 2019 alle ore 11:03 Athanasios Fotis <
>>>>>> Hi,
>>>>>> Thank you very much for your input.
>>>>>> Unfortunately, it doesn't seem to work for my installation.
>>>>>> [image: popup.png]
>>>>>> I have tried setting JAVA_OPTS and CATALINA_OPTS like you suggested
>>>>>> but the encoding is still not working correctly. It seems that it is not
>>>>>> properly stored in the database.
>>>>>> I even tried different values for -Dfile.encoding (UTF8 and UTF-8).
>>>>>> The installation is pretty straightforward, a git clone of the repo
>>>>>> at https://github.com/GeoNode/geonode and then a `docker-compose up
>>>>>> -d`.
>>>>>> Any other ideas of what to look for or how to debug this?
>>>>>> Best regards,
>>>>>> Thanasis
>>>>>> On Tue, 9 Jul 2019 at 17:33, Alessio Fabiani <
>>>>>>> Hi,
>>>>>>> most probably it depends by wrong Java settings on GeoServer.
>>>>>>> I tested your file on my own local instance and it looks fine to me
>>>>>>> (using UTF-8)
>>>>>>> [image: image.png]
>>>>>>> I had to start the JVM with the following settings:
>>>>>>> JAVA_OPTS= .... -Djavax.servlet.request.encoding=UTF-8 -Dfile.encoding=UTF-8
>>>>>>> set CATALINA_OPTS=-Dfile.encoding="UTF-8"
>>>>>>> Il giorno mar 9 lug 2019 alle ore 15:39 Athanasios Fotis <
>>>>>>>> Hi all,
>>>>>>>> I am trying to upload a shapefile to Geonode but the encoding of
>>>>>>>> the features isn't correctly recognized. I don't get any error messages
>>>>>>>> whatsoever and i can see that the layer is created successfully. But when i
>>>>>>>> click on a feature to get the info, the data is shown in the wrong encoding.
>>>>>>>> The geonode version is 2.10rc5 and the same issue happens in both a
>>>>>>>> local dockerized installation as well as the master demo one at
>>>>>>>> http://master.demo.geonode.org/.
>>>>>>>> Attached is the shapefile in question (although the same happens
>>>>>>>> with many others that i have, non-english).
>>>>>>>> Best regards,
>>>>>>>> Thanasis
>>>>>>>> _______________________________________________
>>>>>>>> geonode-users mailing list
>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>> http://goo.gl/it488V for more information.
>>>>>>> Ing. Alessio Fabiani
>>>>>>> @alfa7691
>>>>>>> Founder/Technical Lead
>>>>>>> GeoSolutions S.A.S.
>>>>>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>>>>>> phone: +39 0584 962313
>>>>>>> fax: +39 0584 1660272
>>>>>>> mob: +39 331 6233686
>>>>>>> http://www.geo-solutions.it
>>>>>>> http://twitter.com/geosolutions_it
>>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>>>> This email is intended only for the person or entity to which it is
>>>>>>> addressed and may contain information that is privileged, confidential or
>>>>>>> otherwise protected from disclosure. We remind that - as provided by
>>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>>>> e-mail or the information herein by anyone other than the intended
>>>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>>>> notify us immediately by telephone or e-mail.
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> @alfa7691
>> GeoSolutions S.A.S.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190712/9d14057c/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190712/9d14057c/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190712/9d14057c/attachment-0003.png>
More information about the geonode-users
