[GeoNode-users] Wrong encoding after uploading shapefile (shp)
Athanasios Fotis
tfotis at draxis.gr
Thu Jul 11 02:02:50 PDT 2019
Thank you very much for your input.
Unfortunately, it doesn't seem to work for my installation.
[image: popup.png]
I have tried setting JAVA_OPTS and CATALINA_OPTS like you suggested but the
encoding is still not working correctly. It seems that it is not properly
stored in the database.
I even tried different values for -Dfile.encoding (UTF8 and UTF-8).
The installation is pretty straightforward, a git clone of the repo at
https://github.com/GeoNode/geonode and then a `docker-compose up -d`.
Any other ideas of what to look for or how to debug this?
Best regards,
Thanasis
On Tue, 9 Jul 2019 at 17:33, Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Hi,
> most probably it depends by wrong Java settings on GeoServer.
> I tested your file on my own local instance and it looks fine to me (using
> UTF-8)
> [image: image.png]
> I had to start the JVM with the following settings:
> JAVA_OPTS= .... -Djavax.servlet.request.encoding=UTF-8 -Dfile.encoding=UTF-8
> set CATALINA_OPTS=-Dfile.encoding="UTF-8"
> Il giorno mar 9 lug 2019 alle ore 15:39 Athanasios Fotis <tfotis at draxis.gr>
> ha scritto:
>> Hi all,
>> I am trying to upload a shapefile to Geonode but the encoding of the
>> features isn't correctly recognized. I don't get any error messages
>> whatsoever and i can see that the layer is created successfully. But when i
>> click on a feature to get the info, the data is shown in the wrong encoding.
>> The geonode version is 2.10rc5 and the same issue happens in both a local
>> dockerized installation as well as the master demo one at
>> http://master.demo.geonode.org/.
>> Attached is the shapefile in question (although the same happens with
>> many others that i have, non-english).
>> Best regards,
>> Thanasis
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190711/17aa4dea/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190711/17aa4dea/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190711/17aa4dea/attachment-0003.png>
More information about the geonode-users
