[GeoNode-users] Wrong encoding after uploading shapefile (shp)
Alessio Fabiani alessio.fabiani at geo-solutions.it
Thu Jul 11 07:40:52 PDT 2019
Hi Athanasios,
try maybe to change the UPLOADER method back to REST, it seems like the
GeoServer Importer has some issues with the character encoding
http://osgeo-org.1560.x6.nabble.com/JIRA-GEOS-9073-Encoding-issues-with-the-importer-plugin-td5389529.html
In order to set the uploader method to geoserver.rest you can either set
the environment variable
DEFAULT_BACKEND_UPLOADER=geonode.rest
Or override the UPLOADER setting in your settings file
UPLOADER = {
'BACKEND': 'geonode.rest',
'OPTIONS': {
'TIME_ENABLED': False,
'MOSAIC_ENABLED': False,
'SUPPORTED_CRS': [
'EPSG:4326',
'EPSG:3785',
'EPSG:3857',
'EPSG:32647',
'EPSG:32736'
'SUPPORTED_EXT': [
'.shp',
'.csv',
'.kml',
'.kmz',
'.json',
'.geojson',
'.tif',
'.tiff',
'.geotiff',
'.gml',
'.xml'
Il giorno gio 11 lug 2019 alle ore 11:03 Athanasios Fotis <tfotis at draxis.gr>
ha scritto:
> Hi,
> Thank you very much for your input.
> Unfortunately, it doesn't seem to work for my installation.
> [image: popup.png]
> I have tried setting JAVA_OPTS and CATALINA_OPTS like you suggested but
> the encoding is still not working correctly. It seems that it is not
> properly stored in the database.
> I even tried different values for -Dfile.encoding (UTF8 and UTF-8).
> The installation is pretty straightforward, a git clone of the repo at
> https://github.com/GeoNode/geonode and then a `docker-compose up -d`.
> Any other ideas of what to look for or how to debug this?
> Best regards,
> Thanasis
> On Tue, 9 Jul 2019 at 17:33, Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> Hi,
>> most probably it depends by wrong Java settings on GeoServer.
>> I tested your file on my own local instance and it looks fine to me
>> (using UTF-8)
>> [image: image.png]
>> I had to start the JVM with the following settings:
>> JAVA_OPTS= .... -Djavax.servlet.request.encoding=UTF-8 -Dfile.encoding=UTF-8
>> set CATALINA_OPTS=-Dfile.encoding="UTF-8"
>> Il giorno mar 9 lug 2019 alle ore 15:39 Athanasios Fotis <
>> tfotis at draxis.gr> ha scritto:
>>> Hi all,
>>> I am trying to upload a shapefile to Geonode but the encoding of the
>>> features isn't correctly recognized. I don't get any error messages
>>> whatsoever and i can see that the layer is created successfully. But when i
>>> click on a feature to get the info, the data is shown in the wrong encoding.
>>> The geonode version is 2.10rc5 and the same issue happens in both a
>>> local dockerized  installation as well as the master demo one at
>>> http://master.demo.geonode.org/.
>>> Attached is the shapefile in question (although the same happens with
>>> many others that i have, non-english).
>>> Best regards,
>>> Thanasis
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>> phone: +39 0584 962313
>> fax:     +39 0584 1660272
>> mob:   +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190711/dc441317/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190711/dc441317/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190711/dc441317/attachment-0003.png>
More information about the geonode-users mailing list
