[GeoNode-users] Wrong encoding after uploading shapefile (shp)
    Athanasios Fotis
    tfotis at draxis.gr
    Fri Jul 12 00:20:41 PDT 2019
Hi Alessio,
Perfect. That worked. Thank you!
So, is this is a known issue with Geoserver's importer plugin? Should i
send them an email in their list or create an issue in their tracker?
Best,
Thanasis
On Thu, 11 Jul 2019 at 17:41, Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Hi Athanasios,
> try maybe to change the UPLOADER method back to REST, it seems like the
> GeoServer Importer has some issues with the character encoding
> http://osgeo-org.1560.x6.nabble.com/JIRA-GEOS-9073-Encoding-issues-with-the-importer-plugin-td5389529.html
> In order to set the uploader method to geoserver.rest you can either set
> the environment variable
> DEFAULT_BACKEND_UPLOADER=geonode.rest
> Or override the UPLOADER setting in your settings file
> UPLOADER = {
> 'BACKEND': 'geonode.rest',
> 'OPTIONS': {
> 'TIME_ENABLED': False,
> 'MOSAIC_ENABLED': False,
> 'SUPPORTED_CRS': [
> 'EPSG:4326',
> 'EPSG:3785',
> 'EPSG:3857',
> 'EPSG:32647',
> 'EPSG:32736'
> 'SUPPORTED_EXT': [
> '.shp',
> '.csv',
> '.kml',
> '.kmz',
> '.json',
> '.geojson',
> '.tif',
> '.tiff',
> '.geotiff',
> '.gml',
> '.xml'
> Il giorno gio 11 lug 2019 alle ore 11:03 Athanasios Fotis <
> tfotis at draxis.gr> ha scritto:
>> Hi,
>> Thank you very much for your input.
>> Unfortunately, it doesn't seem to work for my installation.
>> [image: popup.png]
>> I have tried setting JAVA_OPTS and CATALINA_OPTS like you suggested but
>> the encoding is still not working correctly. It seems that it is not
>> properly stored in the database.
>> I even tried different values for -Dfile.encoding (UTF8 and UTF-8).
>> The installation is pretty straightforward, a git clone of the repo at
>> https://github.com/GeoNode/geonode and then a `docker-compose up -d`.
>> Any other ideas of what to look for or how to debug this?
>> Best regards,
>> Thanasis
>> On Tue, 9 Jul 2019 at 17:33, Alessio Fabiani <
>>> Hi,
>>> most probably it depends by wrong Java settings on GeoServer.
>>> I tested your file on my own local instance and it looks fine to me
>>> (using UTF-8)
>>> [image: image.png]
>>> I had to start the JVM with the following settings:
>>> JAVA_OPTS= .... -Djavax.servlet.request.encoding=UTF-8 -Dfile.encoding=UTF-8
>>> set CATALINA_OPTS=-Dfile.encoding="UTF-8"
>>> Il giorno mar 9 lug 2019 alle ore 15:39 Athanasios Fotis <
>>>> Hi all,
>>>> I am trying to upload a shapefile to Geonode but the encoding of the
>>>> features isn't correctly recognized. I don't get any error messages
>>>> whatsoever and i can see that the layer is created successfully. But when i
>>>> click on a feature to get the info, the data is shown in the wrong encoding.
>>>> The geonode version is 2.10rc5 and the same issue happens in both a
>>>> local dockerized  installation as well as the master demo one at
>>>> http://master.demo.geonode.org/.
>>>> Attached is the shapefile in question (although the same happens with
>>>> many others that i have, non-english).
>>>> Best regards,
>>>> Thanasis
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> GeoServer Professional Services from the experts! Visit
>>> http://goo.gl/it488V for more information.
>>> Ing. Alessio Fabiani
>>> @alfa7691
>>> Founder/Technical Lead
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>> phone: +39 0584 962313
>>> fax:     +39 0584 1660272
>>> mob:   +39 331 6233686
>>> http://www.geo-solutions.it
>>> http://twitter.com/geosolutions_it
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> precisa che ogni circostanza inerente alla presente email (il suo
>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>> This email is intended only for the person or entity to which it is
>>> addressed and may contain information that is privileged, confidential or
>>> otherwise protected from disclosure. We remind that - as provided by
>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>> e-mail or the information herein by anyone other than the intended
>>> recipient is prohibited. If you have received this email by mistake, please
>>> notify us immediately by telephone or e-mail.
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190712/6d677ee3/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190712/6d677ee3/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190712/6d677ee3/attachment-0003.png>
More information about the geonode-users
