[GeoNode-users] Wrong encoding after uploading shapefile (shp)
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Jul 12 00:36:56 PDT 2019
Hi Athanasios,
we are already investigating on this issue.
It seems like the GeoServer Importer already supports charset encoding, so,
in case this is confirmed, we will have to update the GeoNode APIs in order
to correctly set the charset when creating the session.
Hopefully in a week or so we will be able to fix this.
Il giorno ven 12 lug 2019 alle ore 09:20 Athanasios Fotis <tfotis at draxis.gr>
ha scritto:
> Hi Alessio,
> Perfect. That worked. Thank you!
> So, is this is a known issue with Geoserver's importer plugin? Should i
> send them an email in their list or create an issue in their tracker?
> Best,
> Thanasis
> On Thu, 11 Jul 2019 at 17:41, Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> Hi Athanasios,
>> try maybe to change the UPLOADER method back to REST, it seems like the
>> GeoServer Importer has some issues with the character encoding
>> http://osgeo-org.1560.x6.nabble.com/JIRA-GEOS-9073-Encoding-issues-with-the-importer-plugin-td5389529.html
>> In order to set the uploader method to geoserver.rest you can either set
>> the environment variable
>> DEFAULT_BACKEND_UPLOADER=geonode.rest
>> Or override the UPLOADER setting in your settings file
>> UPLOADER = {
>> 'BACKEND': 'geonode.rest',
>> 'OPTIONS': {
>> 'TIME_ENABLED': False,
>> 'MOSAIC_ENABLED': False,
>> 'SUPPORTED_CRS': [
>> 'EPSG:4326',
>> 'EPSG:3785',
>> 'EPSG:3857',
>> 'EPSG:32647',
>> 'EPSG:32736'
>> 'SUPPORTED_EXT': [
>> '.shp',
>> '.csv',
>> '.kml',
>> '.kmz',
>> '.json',
>> '.geojson',
>> '.tif',
>> '.tiff',
>> '.geotiff',
>> '.gml',
>> '.xml'
>> Il giorno gio 11 lug 2019 alle ore 11:03 Athanasios Fotis <
>> tfotis at draxis.gr> ha scritto:
>>> Hi,
>>> Thank you very much for your input.
>>> Unfortunately, it doesn't seem to work for my installation.
>>> [image: popup.png]
>>> I have tried setting JAVA_OPTS and CATALINA_OPTS like you suggested but
>>> the encoding is still not working correctly. It seems that it is not
>>> properly stored in the database.
>>> I even tried different values for -Dfile.encoding (UTF8 and UTF-8).
>>> The installation is pretty straightforward, a git clone of the repo at
>>> https://github.com/GeoNode/geonode and then a `docker-compose up -d`.
>>> Any other ideas of what to look for or how to debug this?
>>> Best regards,
>>> Thanasis
>>> On Tue, 9 Jul 2019 at 17:33, Alessio Fabiani <
>>>> Hi,
>>>> most probably it depends by wrong Java settings on GeoServer.
>>>> I tested your file on my own local instance and it looks fine to me
>>>> (using UTF-8)
>>>> [image: image.png]
>>>> I had to start the JVM with the following settings:
>>>> JAVA_OPTS= .... -Djavax.servlet.request.encoding=UTF-8 -Dfile.encoding=UTF-8
>>>> set CATALINA_OPTS=-Dfile.encoding="UTF-8"
>>>> Il giorno mar 9 lug 2019 alle ore 15:39 Athanasios Fotis <
>>>>> Hi all,
>>>>> I am trying to upload a shapefile to Geonode but the encoding of the
>>>>> features isn't correctly recognized. I don't get any error messages
>>>>> whatsoever and i can see that the layer is created successfully. But when i
>>>>> click on a feature to get the info, the data is shown in the wrong encoding.
>>>>> The geonode version is 2.10rc5 and the same issue happens in both a
>>>>> local dockerized  installation as well as the master demo one at
>>>>> http://master.demo.geonode.org/.
>>>>> Attached is the shapefile in question (although the same happens with
>>>>> many others that i have, non-english).
>>>>> Best regards,
>>>>> Thanasis
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>> GeoServer Professional Services from the experts! Visit
>>>> http://goo.gl/it488V for more information.
>>>> Ing. Alessio Fabiani
>>>> @alfa7691
>>>> Founder/Technical Lead
>>>> GeoSolutions S.A.S.
>>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>>> phone: +39 0584 962313
>>>> fax:     +39 0584 1660272
>>>> mob:   +39 331 6233686
>>>> http://www.geo-solutions.it
>>>> http://twitter.com/geosolutions_it
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>>> precisa che ogni circostanza inerente alla presente email (il suo
>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>> This email is intended only for the person or entity to which it is
>>>> addressed and may contain information that is privileged, confidential or
>>>> otherwise protected from disclosure. We remind that - as provided by
>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>> e-mail or the information herein by anyone other than the intended
>>>> recipient is prohibited. If you have received this email by mistake, please
>>>> notify us immediately by telephone or e-mail.
>> @alfa7691
>> GeoSolutions S.A.S.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190712/1fd6b931/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190712/1fd6b931/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190712/1fd6b931/attachment-0003.png>
More information about the geonode-users mailing list
