[GeoNode-users] Geonode 2.10 - Geoserver 2.13-SNAPSHOT data migration from geonode 2.8 and geoserver 2.12.2
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Jul 12 00:43:54 PDT 2019
Hello Anthony,
we are planning to write documentation sections trying to describe the
steps to do the upgrades, but until now we hadn't enough resources to do
that.
It may take some time to be finished, sorry about that.
Alessio.
Il giorno gio 11 lug 2019 alle ore 14:01 Anthony Njogu <anjogu0 at gmail.com>
ha scritto:
> Hi All,
> I have been migrating geonode from version 2.4 to 2.8 and now to 2.10(rc4)
> version. I successfully installed geonode 2.10rc4 on Ubuntu 18.04.2 since
> geonoderc5 kept on crashing due to some packages. I also migrated the
> databases successfully. However my challenge has been with migrating the
> layers which I had on geonode 2.4 and 2.8 to 2.10.
> I tried uploading a vector layer, and later a raster layer on clean
> geonode2.10 installation with the basic connection to geoserver but when I
> upload a raster or a vector image using Geonode UI, i get the error below:
> Tried to make a GET request to
> http://localhost:8080/geoserver/rest/workspaces.xml but got a 401 status
> code:
> but when i try uploading the same using the GeoServer UI everything
> uploads fine and I can view my two images.
> Could anyone assist me on this issue?
> Anthony Njogu
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190712/9d68024e/attachment.html>
More information about the geonode-users mailing list
