[GeoNode-users] GeoNode-Project at 2.8 Python version
1520 gis juliermeopensourcedeveloper at gmail.com
Mon Jul 15 18:41:39 PDT 2019
Dear users and developers,
I have been trying to install GeoNode-Project at 2.8 via Docker on an
Ubuntu at 18.04LTS server, but while building the images, the installation is
facing the following error:
Collecting pygdal==2.1.2.3
  Downloading
https://files.pythonhosted.org/packages/37/4f/64823b0000ce4364bbddd4c46a21f80326910bae3763f9e514ececbd37d6/pygdal-2.1.2.3.tar.gz
(407kB)
    ERROR: Complete output from command python setup.py egg_info:
    ERROR: Traceback (most recent call last):
      File "<string>", line 1, in <module>
      File "/tmp/pip-install-L5AGEr/pygdal/setup.py", line 173, in <module>
        cmdclass=dict(build_ext=gdal_ext),
      File "/usr/local/lib/python2.7/site-packages/setuptools/__init__.py",
line 128, in setup
        _install_setup_requires(attrs)
line 123, in _install_setup_requires
        dist.fetch_build_eggs(dist.setup_requires)
      File "/usr/local/lib/python2.7/site-packages/setuptools/dist.py",
line 504, in fetch_build_eggs
        replace_conflicting=True,
      File
"/usr/local/lib/python2.7/site-packages/pkg_resources/__init__.py", line
774, in resolve
        replace_conflicting=replace_conflicting
      File
1057, in best_match
        return self.obtain(req, installer)
      File
1069, in obtain
        return installer(requirement)
line 571, in fetch_build_egg
        return cmd.easy_install(req)
      File
"/usr/local/lib/python2.7/site-packages/setuptools/command/easy_install.py",
line 673, in easy_install
        return self.install_item(spec, dist.location, tmpdir, deps)
      File
line 699, in install_item
        dists = self.install_eggs(spec, download, tmpdir)
      File
line 884, in install_eggs
        return self.build_and_install(setup_script, setup_base)
      File
line 1152, in build_and_install
        self.run_setup(setup_script, setup_base, args)
      File
line 1138, in run_setup
        run_setup(setup_script, args)
      File "/usr/local/lib/python2.7/site-packages/setuptools/sandbox.py",
line 253, in run_setup
        raise
      File "/usr/local/lib/python2.7/contextlib.py", line 35, in __exit__
        self.gen.throw(type, value, traceback)
line 195, in setup_context
        yield
line 166, in save_modules
        saved_exc.resume()
line 141, in resume
        six.reraise(type, exc, self._tb)
line 154, in save_modules
        yield saved
        yield
line 250, in run_setup
        _execfile(setup_script, ns)
line 45, in _execfile
        exec(code, globals, locals)
      File "/tmp/easy_install-1_bgIy/numpy-1.17.0rc1/setup.py", line 31, in
<module>
    RuntimeError: Python version >= 3.5 required.
ERROR: Command "python setup.py egg_info" failed with error code 1 in
ERROR: Service 'celery' failed to build: The command '/bin/sh -c
GDAL_VERSION=`gdal-config --version`     && PYGDAL_VERSION="$(pip install
pygdal==$GDAL_VERSION 2>&1 | grep -oP '(?<=: )(.*)(?=\))' | grep -oh
$GDAL_VERSION\.[0-9])"     && pip install pygdal==$PYGDAL_VERSION' returned
a non-zero code: 1
(my_geonode) geo at 1520GIS:/home/geonode/my_geonode$ python -V
Python 2.7.15+
Any help will be very appreciated.
Kind regards
Julierme
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190715/4e030870/attachment.html>
More information about the geonode-users mailing list
