[GeoNode-users] [GeoNode-devel] GeoNode-Project at 2.8 Python version
Francesco Bartoli
xbartolone at gmail.com
Tue Jul 16 00:52:51 PDT 2019
This problem is known with the installation of numpy >1.16. A possible workaround is to install numpy==1.16 before the actual installation from pygdal in the Dockerfile.
Hope this helps
Francesco
Il 16 lug 2019, 03:41 +0200, 1520 gis <juliermeopensourcedeveloper at gmail.com>, ha scritto:
> Dear users and developers,
> I have been trying to install GeoNode-Project at 2.8 via Docker on an Ubuntu at 18.04LTS server, but while building the images, the installation is facing the following error:
> Collecting pygdal==2.1.2.3
> Downloading https://files.pythonhosted.org/packages/37/4f/64823b0000ce4364bbddd4c46a21f80326910bae3763f9e514ececbd37d6/pygdal-2.1.2.3.tar.gz (407kB)
> ERROR: Complete output from command python setup.py egg_info:
> ERROR: Traceback (most recent call last):
> File "<string>", line 1, in <module>
> File "/tmp/pip-install-L5AGEr/pygdal/setup.py", line 173, in <module>
> cmdclass=dict(build_ext=gdal_ext),
> File "/usr/local/lib/python2.7/site-packages/setuptools/__init__.py", line 128, in setup
> _install_setup_requires(attrs)
> File "/usr/local/lib/python2.7/site-packages/setuptools/__init__.py", line 123, in _install_setup_requires
> dist.fetch_build_eggs(dist.setup_requires)
> File "/usr/local/lib/python2.7/site-packages/setuptools/dist.py", line 504, in fetch_build_eggs
> replace_conflicting=True,
> File "/usr/local/lib/python2.7/site-packages/pkg_resources/__init__.py", line 774, in resolve
> replace_conflicting=replace_conflicting
> File "/usr/local/lib/python2.7/site-packages/pkg_resources/__init__.py", line 1057, in best_match
> return self.obtain(req, installer)
> File "/usr/local/lib/python2.7/site-packages/pkg_resources/__init__.py", line 1069, in obtain
> return installer(requirement)
> File "/usr/local/lib/python2.7/site-packages/setuptools/dist.py", line 571, in fetch_build_egg
> return cmd.easy_install(req)
> File "/usr/local/lib/python2.7/site-packages/setuptools/command/easy_install.py", line 673, in easy_install
> return self.install_item(spec, dist.location, tmpdir, deps)
> File "/usr/local/lib/python2.7/site-packages/setuptools/command/easy_install.py", line 699, in install_item
> dists = self.install_eggs(spec, download, tmpdir)
> File "/usr/local/lib/python2.7/site-packages/setuptools/command/easy_install.py", line 884, in install_eggs
> return self.build_and_install(setup_script, setup_base)
> File "/usr/local/lib/python2.7/site-packages/setuptools/command/easy_install.py", line 1152, in build_and_install
> self.run_setup(setup_script, setup_base, args)
> File "/usr/local/lib/python2.7/site-packages/setuptools/command/easy_install.py", line 1138, in run_setup
> run_setup(setup_script, args)
> File "/usr/local/lib/python2.7/site-packages/setuptools/sandbox.py", line 253, in run_setup
> raise
> File "/usr/local/lib/python2.7/contextlib.py", line 35, in __exit__
> self.gen.throw(type, value, traceback)
> File "/usr/local/lib/python2.7/site-packages/setuptools/sandbox.py", line 195, in setup_context
> yield
> File "/usr/local/lib/python2.7/site-packages/setuptools/sandbox.py", line 166, in save_modules
> saved_exc.resume()
> File "/usr/local/lib/python2.7/site-packages/setuptools/sandbox.py", line 141, in resume
> six.reraise(type, exc, self._tb)
> File "/usr/local/lib/python2.7/site-packages/setuptools/sandbox.py", line 154, in save_modules
> yield saved
> yield
> File "/usr/local/lib/python2.7/site-packages/setuptools/sandbox.py", line 250, in run_setup
> _execfile(setup_script, ns)
> File "/usr/local/lib/python2.7/site-packages/setuptools/sandbox.py", line 45, in _execfile
> exec(code, globals, locals)
> File "/tmp/easy_install-1_bgIy/numpy-1.17.0rc1/setup.py", line 31, in <module>
> RuntimeError: Python version >= 3.5 required.
> ERROR: Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-L5AGEr/pygdal/
> ERROR: Service 'celery' failed to build: The command '/bin/sh -c GDAL_VERSION=`gdal-config --version` && PYGDAL_VERSION="$(pip install pygdal==$GDAL_VERSION 2>&1 | grep -oP '(?<=: )(.*)(?=\))' | grep -oh $GDAL_VERSION\.[0-9])" && pip install pygdal==$PYGDAL_VERSION' returned a non-zero code: 1
> (my_geonode) geo at 1520GIS:/home/geonode/my_geonode$ python -V
> Python 2.7.15+
> Any help will be very appreciated.
> Kind regards
> Julierme
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190716/9ca60c50/attachment-0001.html>
More information about the geonode-users
