[GeoNode-users] [GeoNode-devel] GeoNode-Project at 2.8 Python version
1520 gis juliermeopensourcedeveloper at gmail.com
Tue Jul 16 11:36:31 PDT 2019
Dear Francesco,
I got it done. I appreciated your reply.
Kind regards
Julierme
On Tue, Jul 16, 2019 at 4:52 AM Francesco Bartoli <xbartolone at gmail.com>
wrote:
> This problem is known with the installation of numpy >1.16. A possible
> workaround is to install numpy==1.16 before the actual installation from
> pygdal in the Dockerfile.
> Hope this helps
> Francesco
> Il 16 lug 2019, 03:41 +0200, 1520 gis <
> juliermeopensourcedeveloper at gmail.com>, ha scritto:
> Dear users and developers,
> I have been trying to install GeoNode-Project at 2.8 via Docker on an
> Ubuntu at 18.04LTS server, but while building the images, the installation
> is facing the following error:
> Collecting pygdal==2.1.2.3
>   Downloading
> https://files.pythonhosted.org/packages/37/4f/64823b0000ce4364bbddd4c46a21f80326910bae3763f9e514ececbd37d6/pygdal-2.1.2.3.tar.gz
> (407kB)
>     ERROR: Complete output from command python setup.py egg_info:
>     ERROR: Traceback (most recent call last):
>       File "<string>", line 1, in <module>
>       File "/tmp/pip-install-L5AGEr/pygdal/setup.py", line 173, in <module>
>         cmdclass=dict(build_ext=gdal_ext),
>       File
> "/usr/local/lib/python2.7/site-packages/setuptools/__init__.py", line 128,
> in setup
>         _install_setup_requires(attrs)
>       File
> "/usr/local/lib/python2.7/site-packages/setuptools/__init__.py", line 123,
> in _install_setup_requires
>         dist.fetch_build_eggs(dist.setup_requires)
>       File "/usr/local/lib/python2.7/site-packages/setuptools/dist.py",
> line 504, in fetch_build_eggs
>         replace_conflicting=True,
>       File
> "/usr/local/lib/python2.7/site-packages/pkg_resources/__init__.py", line
> 774, in resolve
>         replace_conflicting=replace_conflicting
>       File
> 1057, in best_match
>         return self.obtain(req, installer)
>       File
> 1069, in obtain
>         return installer(requirement)
> line 571, in fetch_build_egg
>         return cmd.easy_install(req)
>       File
> "/usr/local/lib/python2.7/site-packages/setuptools/command/easy_install.py",
> line 673, in easy_install
>         return self.install_item(spec, dist.location, tmpdir, deps)
>       File
> line 699, in install_item
>         dists = self.install_eggs(spec, download, tmpdir)
>       File
> line 884, in install_eggs
>         return self.build_and_install(setup_script, setup_base)
>       File
> line 1152, in build_and_install
>         self.run_setup(setup_script, setup_base, args)
>       File
> line 1138, in run_setup
>         run_setup(setup_script, args)
>       File "/usr/local/lib/python2.7/site-packages/setuptools/sandbox.py",
> line 253, in run_setup
>         raise
>       File "/usr/local/lib/python2.7/contextlib.py", line 35, in __exit__
>         self.gen.throw(type, value, traceback)
> line 195, in setup_context
>         yield
> line 166, in save_modules
>         saved_exc.resume()
> line 141, in resume
>         six.reraise(type, exc, self._tb)
> line 154, in save_modules
>         yield saved
>         yield
> line 250, in run_setup
>         _execfile(setup_script, ns)
> line 45, in _execfile
>         exec(code, globals, locals)
>       File "/tmp/easy_install-1_bgIy/numpy-1.17.0rc1/setup.py", line 31,
> in <module>
>     RuntimeError: Python version >= 3.5 required.
> ERROR: Command "python setup.py egg_info" failed with error code 1 in
> ERROR: Service 'celery' failed to build: The command '/bin/sh -c
> GDAL_VERSION=`gdal-config --version`     && PYGDAL_VERSION="$(pip install
> pygdal==$GDAL_VERSION 2>&1 | grep -oP '(?<=: )(.*)(?=\))' | grep -oh
> $GDAL_VERSION\.[0-9])"     && pip install pygdal==$PYGDAL_VERSION' returned
> a non-zero code: 1
> (my_geonode) geo at 1520GIS:/home/geonode/my_geonode$ python -V
> Python 2.7.15+
> Any help will be very appreciated.
> Kind regards
> Julierme
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190716/ee1c4bb9/attachment-0001.html>
More information about the geonode-users mailing list
