[GeoNode-users] GeoNode-Project at 2.8 Python version
Toni Schönbuchner toni.schoenbuchner at csgis.de
Tue Jul 16 01:30:42 PDT 2019
Dear Julierme,
the problem is of numpy 1.17 you have to downgrade it in your dockerfile.
This is already fixed in geonode core. I will try to PR for the project today.
Cheers,
Toni
> Message: 1
> Date: Mon, 15 Jul 2019 22:41:39 -0300
> From: 1520 gis <juliermeopensourcedeveloper at gmail.com>
> To: geonode-users <geonode-users at lists.osgeo.org>,  geonode-devel
> 	<geonode-devel at lists.osgeo.org>
> Subject: [GeoNode-devel] GeoNode-Project at 2.8 Python version
> Message-ID:
> 	<CAKTKyJKrFNUVodwhSSvfCeyJtG5scguszM_G-K1_CK5fcoiCNw at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Dear users and developers,
> I have been trying to install GeoNode-Project at 2.8 via Docker on an
> Ubuntu at 18.04LTS server, but while building the images, the installation is
> facing the following error:
> Collecting pygdal==2.1.2.3
>  Downloading
> https://files.pythonhosted.org/packages/37/4f/64823b0000ce4364bbddd4c46a21f80326910bae3763f9e514ececbd37d6/pygdal-2.1.2.3.tar.gz
> (407kB)
>    ERROR: Complete output from command python setup.py egg_info:
>    ERROR: Traceback (most recent call last):
>      File "<string>", line 1, in <module>
>      File "/tmp/pip-install-L5AGEr/pygdal/setup.py", line 173, in <module>
>        cmdclass=dict(build_ext=gdal_ext),
>      File "/usr/local/lib/python2.7/site-packages/setuptools/__init__.py",
> line 128, in setup
>        _install_setup_requires(attrs)
> line 123, in _install_setup_requires
>        dist.fetch_build_eggs(dist.setup_requires)
>      File "/usr/local/lib/python2.7/site-packages/setuptools/dist.py",
> line 504, in fetch_build_eggs
>        replace_conflicting=True,
>      File
> "/usr/local/lib/python2.7/site-packages/pkg_resources/__init__.py", line
> 774, in resolve
>        replace_conflicting=replace_conflicting
>      File
> 1057, in best_match
>        return self.obtain(req, installer)
>      File
> 1069, in obtain
>        return installer(requirement)
> line 571, in fetch_build_egg
>        return cmd.easy_install(req)
>      File
> "/usr/local/lib/python2.7/site-packages/setuptools/command/easy_install.py",
> line 673, in easy_install
>        return self.install_item(spec, dist.location, tmpdir, deps)
>      File
> line 699, in install_item
>        dists = self.install_eggs(spec, download, tmpdir)
>      File
> line 884, in install_eggs
>        return self.build_and_install(setup_script, setup_base)
>      File
> line 1152, in build_and_install
>        self.run_setup(setup_script, setup_base, args)
>      File
> line 1138, in run_setup
>        run_setup(setup_script, args)
>      File "/usr/local/lib/python2.7/site-packages/setuptools/sandbox.py",
> line 253, in run_setup
>        raise
>      File "/usr/local/lib/python2.7/contextlib.py", line 35, in __exit__
>        self.gen.throw(type, value, traceback)
> line 195, in setup_context
>        yield
> line 166, in save_modules
>        saved_exc.resume()
> line 141, in resume
>        six.reraise(type, exc, self._tb)
> line 154, in save_modules
>        yield saved
>        yield
> line 250, in run_setup
>        _execfile(setup_script, ns)
> line 45, in _execfile
>        exec(code, globals, locals)
>      File "/tmp/easy_install-1_bgIy/numpy-1.17.0rc1/setup.py", line 31, in
> <module>
>    RuntimeError: Python version >= 3.5 required.
> ERROR: Command "python setup.py egg_info" failed with error code 1 in
> ERROR: Service 'celery' failed to build: The command '/bin/sh -c
> GDAL_VERSION=`gdal-config --version`     && PYGDAL_VERSION="$(pip install
> pygdal==$GDAL_VERSION 2>&1 | grep -oP '(?<=: )(.*)(?=\))' | grep -oh
> $GDAL_VERSION\.[0-9])"     && pip install pygdal==$PYGDAL_VERSION' returned
> a non-zero code: 1
> (my_geonode) geo at 1520GIS:/home/geonode/my_geonode$ python -V
> Python 2.7.15+
> Any help will be very appreciated.
> Kind regards
> Julierme
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190715/4e030870/attachment-0001.html>
More information about the geonode-users mailing list
