[GeoNode-users] django.urls.exceptions.NoReverseMatch: Reverse for 'account_login' not found. 'account_login' is not a valid view function or pattern name
Alessio Fabiani alessio.fabiani at geo-solutions.it
Wed Jun 12 05:44:18 PDT 2019
this is an hidden message caused by the mapstore-client overrides. Most
probably the error is located on your code somewhere.
In order to get the real message just change temporarly the value of
the GEONODE_CLIENT_LAYER_PREVIEW_LIBRARY setting to geoext either on the
settings or through the environment variable with the same name.
Il giorno mer 12 giu 2019 alle ore 12:10 edgar mlowe <mloweedgar0 at gmail.com>
ha scritto:
> Hello,
> While adding my own django app to geonode following this guide here
> https://geonode-docs.readthedocs.io/en/latest/tutorials/devel/projects/apps.html,
> I get error *django.urls.exceptions.NoReverseMatch: Reverse for
> 'account_login' not found. 'account_login' is not a valid view function* *or
> pattern name* when I add url for  my custom app in my_geonode/url.py.
> Iam using docker-compose to run my geonode in development mode using guide
> from here https://github.com/GeoNode/geonode-project.
> Thanks in advance for  anyone who can help me.
> Regards,
> Edgar.
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190612/88fd8686/attachment.html>
More information about the geonode-users mailing list
