[GeoNode-users] Changing theme of geonode
Jose Cáceres jose.atyus at gmail.com
Fri Mar 8 05:29:45 PST 2019
Hi Pierluigi,
If you installed Geonode usgin the apt-get command, then the file that you
need to nodify for you index is:
/usr/local/lib/python2.7/dist-packages/geonode/templates/index.html
Remember always restart Apache afterwards.
Kind Regards,
José
El El vie, 8 de mar. de 2019 a las 07:23, pierluigi de rosa <
pierluigi.derosa at gmail.com> escribió:
> Dear Julierme,
> I'm modifing this file here:
> /usr/local/lib/python2.7/dist-packages/geonode/contrib/geosites/site_template/templates/site_index.html
> But not changes are detected.
> In my system is the only file I have called site_index.html
> I'm writing this line:
> <h1>"Multi.park S.D.I."{% trans "Welcome" %}</h1>
> But only Welcome appear.
> Instead I'm able to change the css that in
> /var/www/geonode/static/geonode/css
> Thanks
> Pierluigi
> Il giorno ven 8 mar 2019 alle ore 13:53 Julierme Pinheiro <
> juliermeopensourcedeveloper at gmail.com> ha scritto:
>> Dear Pierluigi,
>> I think you need to look over GeoNODE Project as in [1]. And make changes
>> to site_base.html and site_index.html [2] and site_base.css[3].
>> [1] https://github.com/GeoNode/geonode-project/tree/master
>> [2]
>> https://github.com/GeoNode/geonode-project/tree/master/project_name/templates
>> [3]
>> https://github.com/GeoNode/geonode-project/tree/master/project_name/static/css
>> I hope it helps.
>> Kind regards
>> Julierme
>> On Fri, Mar 8, 2019 at 9:32 AM pierluigi de rosa <
>> pierluigi.derosa at gmail.com> wrote:
>>> Dear User,
>>> I'm trying to change the theme of geonode installation. The installation
>>> have been done using the quick installation as here [0].
>>> I need to change some text in the index and following the page [1]
>>> modifying site_index.html
>>> Anyway the changes are not detected. I think I'm changing the wrong file.
>>> What is the html file I need to change?
>>> Thanks
>>> Pierluigi
>>> [0]
>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/quick_install.html
>>> [1]
>>> http://docs.geonode.org/en/master/tutorials/admin/customize_lookfeel/customize/theme_admin.html#theme-admin
>>> Ing. Pierluigi De Rosa (PhD in Earth Science)
>>> Contract Professor of Geographic Information System at University of
>>> Perugia
>>> cel: 3497558268 / fax: 075 7823038
>>> skype: pierluigi.derosa
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> Perugia
José David Cáceres
Ingeniero Ambiental
Máster en Tecnologías de la Información Geográfica
e-mail: jose.atyus at gmail.com
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190308/5955eddd/attachment-0001.html>
More information about the geonode-users mailing list
