[GeoNode-users] Changing theme of geonode
Paolo Pasquali
paolo.pasquali at gmail.com
Fri Mar 8 06:25:19 PST 2019
Hi Pierlugi,
If you want to customize your GeoNode installation this is not a
recommended way to proceed.
I would suggest instead to start with a GeoNode project [1] and make all
your changes there.
A GeoNode project is like a Django project so if you want to learn more and
get the most out of the templates (and avoid to screw up your installation)
you can follow the Django documentation.
Best,
Paolo
[1] https://github.com/GeoNode/geonode-project
On Fri, Mar 8, 2019 at 3:18 PM Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com> wrote:
> Hi Pierlugi,
> I am running GeoNODE DevMode installed via docker. If you installed
> DevMode by using this tutorial (
> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/create_geonode_db.html),
> your templates sub-directory should be in the same directory as static, If
> I am not mistaken should be .../geonode/static and .../geonode/templates/ .
> After making changes in the files site_base.html, site_index.html and
> site_base.css, you must run <python manage.py collectstatic>
> I hope it helps
> I encourage you to take a look over geonode-project. It is very
> straightforward.
> Kind regards
> Julierme
> On Fri, Mar 8, 2019 at 10:29 AM Jose Cáceres <jose.atyus at gmail.com> wrote:
>> Hi Pierluigi,
>> If you installed Geonode usgin the apt-get command, then the file that
>> you need to nodify for you index is:
>> /usr/local/lib/python2.7/dist-packages/geonode/templates/index.html
>> Remember always restart Apache afterwards.
>> Kind Regards,
>> José
>> El El vie, 8 de mar. de 2019 a las 07:23, pierluigi de rosa <
>> pierluigi.derosa at gmail.com> escribió:
>>> Dear Julierme,
>>> I'm modifing this file here:
>>> /usr/local/lib/python2.7/dist-packages/geonode/contrib/geosites/site_template/templates/site_index.html
>>> But not changes are detected.
>>> In my system is the only file I have called site_index.html
>>> I'm writing this line:
>>> <h1>"Multi.park S.D.I."{% trans "Welcome" %}</h1>
>>> But only Welcome appear.
>>> Instead I'm able to change the css that in
>>> /var/www/geonode/static/geonode/css
>>> Thanks
>>> Pierluigi
>>> Il giorno ven 8 mar 2019 alle ore 13:53 Julierme Pinheiro <
>>> juliermeopensourcedeveloper at gmail.com> ha scritto:
>>>> Dear Pierluigi,
>>>> I think you need to look over GeoNODE Project as in [1]. And make
>>>> changes to site_base.html and site_index.html [2] and site_base.css[3].
>>>> [1] https://github.com/GeoNode/geonode-project/tree/master
>>>> [2]
>>>> https://github.com/GeoNode/geonode-project/tree/master/project_name/templates
>>>> [3]
>>>> https://github.com/GeoNode/geonode-project/tree/master/project_name/static/css
>>>> I hope it helps.
>>>> Kind regards
>>>> Julierme
>>>> On Fri, Mar 8, 2019 at 9:32 AM pierluigi de rosa <
>>>> pierluigi.derosa at gmail.com> wrote:
>>>>> Dear User,
>>>>> I'm trying to change the theme of geonode installation. The
>>>>> installation have been done using the quick installation as here [0].
>>>>> I need to change some text in the index and following the page [1]
>>>>> modifying site_index.html
>>>>> Anyway the changes are not detected. I think I'm changing the wrong
>>>>> file.
>>>>> What is the html file I need to change?
>>>>> Thanks
>>>>> Pierluigi
>>>>> [0]
>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/quick_install.html
>>>>> [1]
>>>>> http://docs.geonode.org/en/master/tutorials/admin/customize_lookfeel/customize/theme_admin.html#theme-admin
>>>>> Ing. Pierluigi De Rosa (PhD in Earth Science)
>>>>> Contract Professor of Geographic Information System at University of
>>>>> Perugia
>>>>> cel: 3497558268 / fax: 075 7823038
>>>>> skype: pierluigi.derosa
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> Perugia
>> José David Cáceres
>> Ingeniero Ambiental
>> Máster en Tecnologías de la Información Geográfica
>> e-mail: jose.atyus at gmail.com
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190308/30a2c94b/attachment.html>
More information about the geonode-users
