[GeoNode-users] geonode devmode python virtualenv installation (Paulo Frias)
Toni Schönbuchner toni.schoenbuchner at csgis.de
Sat Mar 16 14:40:43 PDT 2019
in addition to my previous mail see: https://github.com/GeoNode/geonode/pull/4208#issuecomment-460942782 <https://github.com/GeoNode/geonode/pull/4208#issuecomment-460942782>
Cheers,
Toni
> Am 16.03.2019 um 21:37 schrieb Francesco Bartoli <xbartolone at gmail.com>:
> Hi Toni,
> there is something which I don’t understand:
> Here https://github.com/GeoNode/geonode/blob/master/geonode/templates/base.html#L252 <https://github.com/GeoNode/geonode/blob/master/geonode/templates/base.html#L252> the link for getting the web admin page of GeoServer
> Its default value https://github.com/GeoNode/geonode/blob/master/geonode/templates/base.html#L252 <https://github.com/GeoNode/geonode/blob/master/geonode/templates/base.html#L252> comes from here https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L752 <https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L752>
> The possible values have always a /gs location which isn’t a route allowed by neither any django urls nor Jetty
> I guess there is a regression here at least for the default value which should affect development mode.
> I’d like if @afabiani could confirm the issue and maybe give the rationale and how to get rid of it.
> Il 16 mar 2019, 20:16 +0100, Toni Schönbuchner <toni.schoenbuchner at csgis.de>, ha scritto:
>> Hello you two,
>> let me sugest to use the master branch has it has some important bugfixes which are missing in 2.8 branch.
>> 1) have a look where this link comes from:
>> in master: {{ OGC_SERVER.default.WEB_UI_LOCATION }}
>> in 2.8: {{ OGC_SERVER.default.LOCATION }}
>> https://github.com/GeoNode/geonode/blob/929265975816af0c08199e47e05f8be3c93f5477/geonode/templates/base.html#L252 <https://github.com/GeoNode/geonode/blob/929265975816af0c08199e47e05f8be3c93f5477/geonode/templates/base.html#L252>
>> https://github.com/GeoNode/geonode/blob/2.8.x/geonode/templates/base.html#L216 <https://github.com/GeoNode/geonode/blob/2.8.x/geonode/templates/base.html#L216>
>> Make sure to set those vars correctly in your local_settings..py
>> 2) please use verbose geoserver logging (in gs Gui I think it´s under general)
>> Watch log output while uploading layer with:
>> $ sudo tail -f /var/log/tomcat8/catalina.out
>> and maybe in some second terminal
>> $ sudo tail -f /var/log/apache2/error.log
>> As far as I remember this error can be solved when correctly setup your geoserver settings in local_settings
>> and further to correctly setup oauth2 settings on both sides Geonode/geoserver.
>> Hope this helps,
>> cheers,
>> Toni
>>> Am 16.03.2019 um 20:00 schrieb geonode-users-request at lists.osgeo.org <mailto:geonode-users-request at lists.osgeo.org>:
>>> Send geonode-users mailing list submissions to
>>> geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>
>>> To subscribe or unsubscribe via the World Wide Web, visit
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> or, via email, send a message with subject or body 'help' to
>>> You can reach the person managing the list at
>>> geonode-users-owner at lists.osgeo.org
>>> When replying, please edit your Subject line so it is more specific
>>> than "Re: Contents of geonode-users digest..."
>>> Today's Topics:
>>>   1. geonode devmode python virtualenv installation (Julierme Pinheiro)
>>>   2. Re: geonode devmode python virtualenv installation (Paulo Frias)
>>> Message: 1
>>> Date: Fri, 15 Mar 2019 16:50:50 -0300
>>> From: Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com>
>>> To: geonode-users <geonode-users at lists.osgeo.org>,  geonode-devel
>>> <geonode-devel at lists.osgeo.org>
>>> Subject: [GeoNode-users] geonode devmode python virtualenv
>>> installation
>>> Message-ID:
>>> <CAKTKyJKbAbggkwsSQ_d_1Afs9-ABQm1e_mNCb2eVwBjRLzC5wg at mail.gmail.com>
>>> Content-Type: text/plain; charset="utf-8"
>>> Dear all,
>>> I have tried to install geonode devmode vs 2.8 via python virtualenv in a
>>> 16.04LTS Ubuntu server. I am following the guide in here [1].
>>> I am using custom local_settings.py. Everything works fine, except:
>>> 1 - geoserver url. The link for Geoserver on GeoNode site points to
>>> localhost:8000/proxy/?url=http:localhost:8080/geoserver/, however when
>>> clicking on it, the site opens localhost:8000/geoserver/index.html.
>>> 2 - Upload layers - while uploading a layer, we hit " Unespected error"
>>> Geoserver port number should be 8080.  Thinking about that, I went to [2]
>>> which says to comment the lines:
>>> ...# SITEURL = 'http://localhost'...#GEOSERVER_LOCATION = os.getenv(#
>>>  'GEOSERVER_LOCATION', '{}/geoserver/'.format(SITEURL)#)
>>> #GEOSERVER_PUBLIC_LOCATION = os.getenv(#
>>> 'GEOSERVER_PUBLIC_LOCATION', '{}/gs/'.format(SITEURL)#)...
>>> Besides of that, I set GEOSERVER_PUBLIC_PORT = '8080', but the issues remains.
>>> GEOSERVER_PUBLIC_PORT = os.getenv(
>>>    'GEOSERVER_PUBLIC_PORT', '8080'
>>> If anyone else has faced these problems and could share any hint, it will
>>> be very appreciated.
>>> Kind regards
>>> Julierme
>>> [1]
>>> https://github.com/GeoNode/geonode-project/tree/06602d424a3779a636bcc78bc1d50c83ba980bad
>>> [2]
>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/create_geonode_db.html
>>> -------------- next part --------------
>>> An HTML attachment was scrubbed...
>>> URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190315/4f1769b2/attachment-0001.html>
>>> Message: 2
>>> Date: Sat, 16 Mar 2019 08:33:41 +0000
>>> From: Paulo Frias <pfrias82 at gmail.com>
>>> To: Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com>
>>> Cc: geonode-users <geonode-users at lists.osgeo.org>,  geonode-devel
>>> Subject: Re: [GeoNode-users] geonode devmode python virtualenv
>>> installation
>>> Message-ID:
>>> <CA+PD0U2bGP8NGbWPEVYR1ar-NA2KeU=SnyoLZdJ0M_7TKgLOyA at mail.gmail.com>
>>> Hi Julierme,
>>> I have the exact same problem running Geonode, same installation procedure,
>>> on my Mac. But I didn't found any solution yet. :(
>>> Regards,
>>> Paulo
>>> On Fri, 15 Mar 2019 at 19:51, Julierme Pinheiro <
>>> juliermeopensourcedeveloper at gmail.com> wrote:
>>>> Dear all,
>>>> ...# SITEURL = 'http://localhost'...#GEOSERVER_LOCATION = os.getenv(#    'GEOSERVER_LOCATION', '{}/geoserver/'.format(SITEURL)#)
>>>> #GEOSERVER_PUBLIC_LOCATION = os.getenv(#    'GEOSERVER_PUBLIC_LOCATION', '{}/gs/'.format(SITEURL)#)...
>>>> Kind regards
>>>> Julierme
>>>> [1]
>>>> [2]
>>>> _______________________________________________
>>> URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190316/4a801d6a/attachment-0001.html>
>>> Subject: Digest Footer
>>> End of geonode-users Digest, Vol 50, Issue 12
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190316/cd26f584/attachment-0001.html>
More information about the geonode-users mailing list
