[GeoNode-users] GeoNode Credentials Login
Julierme Pinheiro
juliermeopensourcedeveloper at gmail.com
Tue Mar 26 14:53:32 PDT 2019
Hi Francesco,
Thank you very much for your reply. Look at this response. I did not do any
change at all:
Forbidden (403)
CSRF verification failed. Request aborted.
You are seeing this message because this site requires a CSRF cookie when
submitting forms. This cookie is required for security reasons, to ensure
that your browser is not being hijacked by third parties.
If you have configured your browser to disable cookies, please re-enable
them, at least for this site, or for 'same-origin' requests.
Help
Reason given for failure:
CSRF cookie not set.
In general, this can occur when there is a genuine Cross Site Request
Forgery, or when Django's CSRF mechanism
<https://docs.djangoproject.com/en/1.11/ref/csrf/> has not been used
correctly. For POST forms, you need to ensure:
- Your browser is accepting cookies.
- The view function passes a request to the template's render
<https://docs.djangoproject.com/en/dev/topics/templates/#django.template.backends.base.Template.render>
method.
- In the template, there is a {% csrf_token %} template tag inside each
POST form that targets an internal URL.
- If you are not using CsrfViewMiddleware, then you must use csrf_protect
on any views that use the csrf_token template tag, as well as those that
accept the POST data.
- The form has a valid CSRF token. After logging in in another browser
tab or hitting the back button after a login, you may need to reload the
page with the form, because the token is rotated after a login.
You're seeing the help section of this page because you have DEBUG = True
in your Django settings file. Change that to False, and only the initial
error message will be displayed.
You can customize this page using the CSRF_FAILURE_VIEW setting.
I appreciated your reply.
Julierme
On Tue, Mar 26, 2019 at 6:37 PM Francesco Bartoli <xbartolone at gmail.com>
wrote:
> Hi Julierme,
> I’m right now on a geonode-project based code and the login is working
> well for me.
> Francesco
> Il 26 mar 2019, 22:30 +0100, Julierme Pinheiro <
> juliermeopensourcedeveloper at gmail.com>, ha scritto:
> Dear users and developers,
> I just installed via Docker a brand new master geonode-project on a
> Ubuntu18.04lTS server and after installation I could not do a login either
> through geonode and geoserver default credentials:
> admin admin
> admin geoserver.
> Has anyone faced the same issue? Did the default credentials change?
> I appreciated your time.
> Kind regards
> Julierme
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190326/9e1c0f71/attachment.html>
More information about the geonode-users
