[GeoNode-users] GeoNode Credentials Login
Julierme Pinheiro
juliermeopensourcedeveloper at gmail.com
Tue Mar 26 14:55:25 PDT 2019
And geoserver response while liging in:
Invalid username/password combination.
On Tue, Mar 26, 2019 at 6:53 PM Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com> wrote:
> Hi Francesco,
> Thank you very much for your reply. Look at this response. I did not do
> any change at all:
> Forbidden (403)
> CSRF verification failed. Request aborted.
> You are seeing this message because this site requires a CSRF cookie when
> submitting forms. This cookie is required for security reasons, to ensure
> that your browser is not being hijacked by third parties.
> If you have configured your browser to disable cookies, please re-enable
> them, at least for this site, or for 'same-origin' requests.
> Help
> Reason given for failure:
> CSRF cookie not set.
> In general, this can occur when there is a genuine Cross Site Request
> Forgery, or when Django's CSRF mechanism
> <https://docs.djangoproject.com/en/1.11/ref/csrf/> has not been used
> correctly. For POST forms, you need to ensure:
> - Your browser is accepting cookies.
> - The view function passes a request to the template's render
> <https://docs.djangoproject.com/en/dev/topics/templates/#django.template.backends.base.Template.render>
> method.
> - In the template, there is a {% csrf_token %} template tag inside
> each POST form that targets an internal URL.
> - If you are not using CsrfViewMiddleware, then you must use
> csrf_protect on any views that use the csrf_token template tag, as
> well as those that accept the POST data.
> - The form has a valid CSRF token. After logging in in another browser
> tab or hitting the back button after a login, you may need to reload the
> page with the form, because the token is rotated after a login.
> You're seeing the help section of this page because you have DEBUG = True
> in your Django settings file. Change that to False, and only the initial
> error message will be displayed.
> You can customize this page using the CSRF_FAILURE_VIEW setting.
> I appreciated your reply.
> Julierme
> On Tue, Mar 26, 2019 at 6:37 PM Francesco Bartoli <xbartolone at gmail.com>
> wrote:
>> Hi Julierme,
>> I’m right now on a geonode-project based code and the login is working
>> well for me.
>> Francesco
>> Il 26 mar 2019, 22:30 +0100, Julierme Pinheiro <
>> juliermeopensourcedeveloper at gmail.com>, ha scritto:
>> Dear users and developers,
>> I just installed via Docker a brand new master geonode-project on a
>> Ubuntu18.04lTS server and after installation I could not do a login either
>> through geonode and geoserver default credentials:
>> admin admin
>> admin geoserver.
>> Has anyone faced the same issue? Did the default credentials change?
>> I appreciated your time.
>> Kind regards
>> Julierme
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190326/6749d875/attachment-0001.html>
More information about the geonode-users
