[GeoNode-users] GeoNode Credentials Login
Julierme Pinheiro
juliermeopensourcedeveloper at gmail.com
Tue Mar 26 14:56:35 PDT 2019
And no Caps Lock on.
On Tue, Mar 26, 2019 at 6:55 PM Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com> wrote:
> And geoserver response while liging in:
> Invalid username/password combination.
> On Tue, Mar 26, 2019 at 6:53 PM Julierme Pinheiro <
>> Hi Francesco,
>> Thank you very much for your reply. Look at this response. I did not do
>> any change at all:
>> Forbidden (403)
>> CSRF verification failed. Request aborted.
>> You are seeing this message because this site requires a CSRF cookie when
>> submitting forms. This cookie is required for security reasons, to ensure
>> that your browser is not being hijacked by third parties.
>> If you have configured your browser to disable cookies, please re-enable
>> them, at least for this site, or for 'same-origin' requests.
>> Help
>> Reason given for failure:
>> CSRF cookie not set.
>> In general, this can occur when there is a genuine Cross Site Request
>> Forgery, or when Django's CSRF mechanism
>> <https://docs.djangoproject.com/en/1.11/ref/csrf/> has not been used
>> correctly. For POST forms, you need to ensure:
>> - Your browser is accepting cookies.
>> - The view function passes a request to the template's render
>> <https://docs.djangoproject.com/en/dev/topics/templates/#django.template.backends.base.Template.render>
>> method.
>> - In the template, there is a {% csrf_token %} template tag inside
>> each POST form that targets an internal URL.
>> - If you are not using CsrfViewMiddleware, then you must use
>> csrf_protect on any views that use the csrf_token template tag, as
>> well as those that accept the POST data.
>> - The form has a valid CSRF token. After logging in in another
>> browser tab or hitting the back button after a login, you may need to
>> reload the page with the form, because the token is rotated after a login.
>> You're seeing the help section of this page because you have DEBUG = True
>> in your Django settings file. Change that to False, and only the initial
>> error message will be displayed.
>> You can customize this page using the CSRF_FAILURE_VIEW setting.
>> I appreciated your reply.
>> Julierme
>> On Tue, Mar 26, 2019 at 6:37 PM Francesco Bartoli <xbartolone at gmail.com>
>> wrote:
>>> Hi Julierme,
>>> I’m right now on a geonode-project based code and the login is working
>>> well for me.
>>> Francesco
>>> Il 26 mar 2019, 22:30 +0100, Julierme Pinheiro <
>>> juliermeopensourcedeveloper at gmail.com>, ha scritto:
>>> Dear users and developers,
>>> I just installed via Docker a brand new master geonode-project on a
>>> Ubuntu18.04lTS server and after installation I could not do a login either
>>> through geonode and geoserver default credentials:
>>> admin admin
>>> admin geoserver.
>>> Has anyone faced the same issue? Did the default credentials change?
>>> I appreciated your time.
>>> Kind regards
>>> Julierme
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190326/4d8a6d12/attachment.html>
More information about the geonode-users
