[GeoNode-users] Customize the Categories on a Genode 2.8 installation
Yewondwossen Assefa assefay at gmail.com
Thu Mar 28 00:09:35 PDT 2019
Dear Toni,
Many thanks. I was not aware of that particular customization setting. I
will play with it and report.
I was also not aware that the quick installation was deprecated. I will use
a manual installation on the next install. The current server will be used
to showcase capabilities of Geonode.
regards,
Y. Assefa
On Thu, Mar 28, 2019 at 9:07 AM Toni Schönbuchner <
toni.schoenbuchner at csgis.de> wrote:
> Dear Yewondwossen,
> welcome on board. Yes your message was delivered:
> https://lists.osgeo.org/pipermail/geonode-users/2019-March/005449.html
> Have you seen that there is a setting regarding customizations which is by
> defaul false.
> http://docs.geonode.org/en/master/reference/developers/settings.html#modify-topiccategory
> A word of caution, the quick installation is outdated / currently
> unmaintained.
> If it´s not to late I would suggest doing a manual install or use the
> docker stack.
> Cheers,
> Toni
> Am 28.03.2019 um 06:56 schrieb Yewondwossen Assefa <assefay at gmail.com>:
> Dear all,
> I had re-registered to the geonode users mailing list and sent an email
> yesterday. Not sure if it has reached the community. I also did not see the
> email in the March archive. Has it reached you or is any approval process
> needed?
> Many thanks,
> Y. Assefa
> ---------- Forwarded message ---------
> From: Yewondwossen Assefa <assefay at gmail.com>
> Date: Wed, Mar 27, 2019 at 6:37 PM
> Subject: Customize the Categories on a Genode 2.8 installation
> To: <geonode-users at lists.osgeo.org>
> Dear all,
> Is there a way to customize the categories available in Geonode (list of
> "available data sets" seen on the first page)?
> I tried to use the admin interface to  "Add topic category" and also
> disable some categories (Is choice un-selected) but did not see any
> changes.
> As a quick workaround, should changes be made directly on some of the
> installed files (index.html)
> Installation was done using the quick install guide.
> Thanks
> regards,
> Y. Assefa
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190328/eb1036ba/attachment.html>
More information about the geonode-users mailing list
