[GeoNode-users] Load CVS file.
Yewondwossen Assefa assefay at gmail.com
Fri Mar 29 07:37:49 PDT 2019
Hi Stefan,
I am talking of non-geographical CSV (just attributes). For geographical
elements, I always use shape files.
You mention that It should work with the non-geographical CVS? I get the
following message: Only Shapefiles, GeoTiffs, and ASCIIs are supported. You
uploaded a .csv file
Thanks
On Fri, Mar 29, 2019 at 5:32 PM Stefan Steiniger <ssteiniger at uc.cl> wrote:
> Hi,
> it depends what type of CSV. That is, you mean a file with point
> coordinates to display it as in a map, or just a spread sheet, as an xls so
> people can download?The latter is no problem, but a "geographical CSV" is.
> stefan
> On Fri, Mar 29, 2019 at 11:11 AM Yewondwossen Assefa <assefay at gmail.com>
> wrote:
>> Hi all,
>> What would be the way to go to be able to upload CSV file?
>> The installation was done using the quick installation.
>> I have I tried to set 'BACKEND': 'geonode.importer', in settings.py but
>> that did not help.
>> Are there other setting I should look for?
>> Thanks
>> Y. Assefa
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190329/1ddd168f/attachment.html>
More information about the geonode-users mailing list
