[GeoNode-users] Load CVS file.
Francesco Bartoli xbartolone at gmail.com
Fri Mar 29 07:51:53 PDT 2019
You can upload it under documents.
Hope this helps
Francesco
Il 29 mar 2019, 15:36 +0100, Yewondwossen Assefa <assefay at gmail.com>, ha scritto:
> Hi Stefan,
> I am talking of non-geographical CSV (just attributes). For geographical elements, I always use shape files.
> You mention that It should work with the non-geographical CVS? I get the following message: Only Shapefiles, GeoTiffs, and ASCIIs are supported. You uploaded a .csv file
> Thanks
> > On Fri, Mar 29, 2019 at 5:32 PM Stefan Steiniger <ssteiniger at uc.cl> wrote:
> > > Hi,
> > > it depends what type of CSV. That is, you mean a file with point coordinates to display it as in a map, or just a spread sheet, as an xls so people can download?The latter is no problem, but a "geographical CSV" is.
> > > stefan
> > > > On Fri, Mar 29, 2019 at 11:11 AM Yewondwossen Assefa <assefay at gmail.com> wrote:
> > > > > Hi all,
> > > > > What would be the way to go to be able to upload CSV file?
> > > > > The installation was done using the quick installation.
> > > > > I have I tried to set 'BACKEND': 'geonode.importer', in settings.py but that did not help.
> > > > > Are there other setting I should look for?
> > > > > Thanks
> > > > > Y. Assefa
> > > > > _______________________________________________
> > > > > geonode-users mailing list
> > > > > geonode-users at lists.osgeo.org
> > > > > https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190329/63c42aae/attachment.html>
More information about the geonode-users mailing list
