[GeoNode-users] Load CVS file.
Ariel Nunez
ingenieroariel at gmail.com
Fri Mar 29 08:21:10 PDT 2019
Fra,
I think Assefay is referring to having the csv become a Layer. Kind of like:
http://docs.geonode.org/en/master/tutorials/devel/geonode_apis/importer/rest_examples.html#uploading-a-csv-file-to-postgis-while-transforming-it
-a
On Fri, Mar 29, 2019 at 9:52 AM Francesco Bartoli <xbartolone at gmail.com> wrote:
> Hi,
> You can upload it under documents.
> Hope this helps
> Francesco
> Il 29 mar 2019, 15:36 +0100, Yewondwossen Assefa <assefay at gmail.com>, ha scritto:
> Hi Stefan,
> I am talking of non-geographical CSV (just attributes). For geographical elements, I always use shape files.
> You mention that It should work with the non-geographical CVS? I get the following message: Only Shapefiles, GeoTiffs, and ASCIIs are supported. You uploaded a .csv file
> Thanks
> On Fri, Mar 29, 2019 at 5:32 PM Stefan Steiniger <ssteiniger at uc.cl> wrote:
>> Hi,
>> it depends what type of CSV. That is, you mean a file with point coordinates to display it as in a map, or just a spread sheet, as an xls so people can download?The latter is no problem, but a "geographical CSV" is.
>> stefan
>> On Fri, Mar 29, 2019 at 11:11 AM Yewondwossen Assefa <assefay at gmail.com> wrote:
>>> Hi all,
>>> What would be the way to go to be able to upload CSV file?
>>> The installation was done using the quick installation.
>>> I have I tried to set 'BACKEND': 'geonode.importer', in settings.py but that did not help.
>>> Are there other setting I should look for?
>>> Thanks
>>> Y. Assefa
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
More information about the geonode-users
