[GeoNode-users] Load CVS file.
Francesco Bartoli xbartolone at gmail.com
Fri Mar 29 09:18:12 PDT 2019
Ciao Ariel,
He was talking to a not-geographical csv so it wouldn’t make sense to become a layer imho
Francesco
P.S. It is great to have you onboard again
Il 29 mar 2019, 16:21 +0100, Ariel Nunez <ingenieroariel at gmail.com>, ha scritto:
> Fra,
> I think Assefay is referring to having the csv become a Layer. Kind of like:
> http://docs.geonode.org/en/master/tutorials/devel/geonode_apis/importer/rest_examples.html#uploading-a-csv-file-to-postgis-while-transforming-it
> -a
> On Fri, Mar 29, 2019 at 9:52 AM Francesco Bartoli <xbartolone at gmail.com> wrote:
> > Hi,
> > You can upload it under documents.
> > Hope this helps
> > Francesco
> > Il 29 mar 2019, 15:36 +0100, Yewondwossen Assefa <assefay at gmail.com>, ha scritto:
> > Hi Stefan,
> > I am talking of non-geographical CSV (just attributes). For geographical elements, I always use shape files.
> > You mention that It should work with the non-geographical CVS? I get the following message: Only Shapefiles, GeoTiffs, and ASCIIs are supported. You uploaded a .csv file
> > Thanks
> > On Fri, Mar 29, 2019 at 5:32 PM Stefan Steiniger <ssteiniger at uc.cl> wrote:
> > > Hi,
> > > it depends what type of CSV. That is, you mean a file with point coordinates to display it as in a map, or just a spread sheet, as an xls so people can download?The latter is no problem, but a "geographical CSV" is.
> > > stefan
> > > On Fri, Mar 29, 2019 at 11:11 AM Yewondwossen Assefa <assefay at gmail.com> wrote:
> > > > Hi all,
> > > > What would be the way to go to be able to upload CSV file?
> > > > The installation was done using the quick installation.
> > > > I have I tried to set 'BACKEND': 'geonode.importer', in settings.py but that did not help.
> > > > Are there other setting I should look for?
> > > > Thanks
> > > > Y. Assefa
> > > > _______________________________________________
> > > > geonode-users mailing list
> > > > geonode-users at lists.osgeo.org
> > > > https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190329/abae61a4/attachment.html>
More information about the geonode-users mailing list
